Apr 21 2008, 07:47
Post
#1
Member Group: Full Members Posts: 129 Joined: 12-June 06 From: Australia Member No.: 3286 Mp3tag Version: 2.52 |
I noticed when running actions on a tag field if the field does not exist in the tag, the action will create the field anyway with nothing in it!
Actions such as Replace or Case Conversion seem to imply that they will affect only existing fields whereas Format Value you would imagine will always result in a field being written. Should some actions only write to the field if the tag already contains that particular field to prevent the empty fields being created? |
Apr 28 2008, 22:37
Post
#2
![]() Developer Group: Admin Posts: 7621 Joined: 12-December 01 From: Germany, Dresden Member No.: 203 Mp3tag Version: 2.55a |
This sounds like a good idea too me.
Can you give an example of such an action? -------------------- |
May 1 2008, 07:22
Post
#3
These actions should only affect existing fields and not create empty fields in the tag
Case conversion Convert codepage Replace Replace with regular expression e.g. Replace "The" => "the" in comment field. Run on a group of files. Any file which didn't already have a comment field will now have an empty comment field. Maybe its not such a big deal? This sounds like a good idea too me.
Can you give an example of such an action? |
May 2 2008, 00:31
Post
#4
![]() Moderator Group: Moderators Posts: 5506 Joined: 4-September 03 From: Germany Member No.: 201 Mp3tag Version: 2.55a |
An empty tag field is displayed, but no actual tag field is created. Some visual bug.
May 2 2008, 11:37
Post
#5
Member Group: Full Members Posts: 1239 Joined: 25-October 05 Member No.: 2273 Mp3tag Version: - |
Big enough. Here on a 10K-track set it caused bloat of files and massive bloat of the backup. Anyone know a workaround? Extended Tags won't show the tag for me to delete it. An empty tag field is displayed, but no actual tag field is created. Some visual bug. I get the reverse - no display (see http://forums.mp3tag.de/index.php?showtopic=7685) but yes tag (see same).
This post has been edited by chrisjj: May 4 2008, 13:29 |
May 2 2008, 13:35
Post
#6
I get the reverse - no display (see http://forums.mp3tag.de/index.php?showtopic=7685) but yes tag (see same). That is a different case. -------------------- |
May 2 2008, 16:50
Post
#7
These actions should only affect existing fields and not create empty fields in the tag OK. Thanks for reporting, I'll fix it to the next release (though the empty fields are not written to the tags). Kind regards, Florian -------------------- |
May 3 2008, 23:26
Post
#8
May 7 2008, 05:36
Post
#9
An empty tag field is displayed, but no actual tag field is created. Some visual bug. I noticed that visual glitch too but that is not what I am reporting. I have 100s of files with empty TIT3 tags to prove it! It seems to only happen if action is part of an action group but I am having trouble replicating the issue. Will report back if I can narrow it down. |
May 7 2008, 21:27
Post
#10
It seems to only happen if action is part of an action group I thought actions had to be!QUOTE but I am having trouble replicating the issue. FWIW the recipe here (V2.41) is simply1 Load an mp3 having no CJJTEMP tag 2 Convert Actions with an Action Group containing one Action: Replace "CJJTEMP": "a" -> "a" (case-sensitive comparison) Now the file has an empty CJJTEMP tag. Every time. |
May 9 2008, 06:47
Post
#11
Now the file has an empty CJJTEMP tag. Every time. Not quite What I am seeing is this. After the action is run, the extended tags dialog shows the empty field but it is not written into the tag yet. If you OK out of the extended tags dialog the tag is updated - the empty field disappears and is not written into the tag. However if you cancel out of the extended tags dialog and then click save button the empty field disappears from the extended tags dialog but is written into the tag. |
May 12 2008, 14:55
Post
#12
> is not written into the tag yet. Confirmed. > However if you cancel out of the extended tags dialog and then click save > button the empty field disappears from the extended tags dialog but is written into the tag. Confirmed - my recipe needs a final Save to be correct. Nice catch Oblio! |
Jun 6 2008, 21:02
Post
#13
OK. Thanks for reporting, I'll fix it to the next release (though the empty fields are not written to the tags). This is now fixed in the latest Development Build Mp3tag v2.41a. Kind regards, Florian -------------------- |
Lo-Fi Version | Time is now: 23rd May 2013 - 11:39 |
