IPB
> Notice!
> Removing a tag that has whitepace as its first character eg % artist%
egd
post May 4 2008, 12:26
Post #1
Member
Group: Full Members
Mp3tag Version: 2.46a
I've been cleaning up my collection and standardizing tags across all albums and in the process discovered that some albums (which I don't know) have an " ALBUM" as well as an "ALBUM" tag.
Rather than unleash a remove tag operation across my entire library I tried to add a custom field " album", defined as % album%, however no data is ever present in this column/ field. Is there some way to get mp3tag to display and operate on a tag with whitespace preceding the rest of the tag name?
This post has been edited by egd: May 4 2008, 12:36
Go to the top of the page
+Quote Post
Florian
post May 4 2008, 13:19
Post #2
Developer
Group: Admin
Mp3tag Version: 2.55a
I think you can add this field as a new column at View > Columns....
+Quote Post
egd
post May 4 2008, 14:26
Post #3
Member
Group: Full Members
QUOTE (Florian @ May 4 2008, 22:19) *
Hi Florian. That's exactly what I tried to do - the column shows up, but no content is displayed.
If it is possible to define criteria for the filter, how would one go about defining a criteria for field !="" ?
+Quote Post
egd
post May 4 2008, 15:05
Post #4
Member
Group: Full Members
I've crashed mp3tag 2.40 twice trying to delete the tags in question (close to 90k files may be the cause), so I've resorted to using metaflac from the Linux command line.
CODE
find . -iname "*.flac" -exec metaflac --remove-tag=" artist" {} \;
does the trick, albeit there must be a workable solution in mp3tag?
This post has been edited by egd: May 4 2008, 15:06
+Quote Post
Florian
post May 4 2008, 15:07
Post #5
Developer
Group: Admin
You can remove the field in the extended tag dialog at [Alt+T].
+Quote Post
egd
post May 4 2008, 22:42
Post #6
Member
Group: Full Members
QUOTE (Florian @ May 5 2008, 00:07) *
Hi, that's what I'd tried on both occasions I crashed mp3tag. Unfortunately I wasn't able to get an error log file as mp3tag enters an "unknown state" and won't shut down other than by way of Task Manager End Task. Until it is shut down the log file is locked and after it is shut down nothing is written to the file.
+Quote Post
egd
post May 5 2008, 02:19
Post #7
Member
Group: Full Members
Florian, I think the problem is that I've exceeded the number of tracks mp3tag can deal with in one operation. I just tried to run a different action and also crashed:
Runtime error
mtmainframe.cpp line 1499
+Quote Post
egd
post May 5 2008, 06:54
Post #8
Member
Group: Full Members
QUOTE (egd @ May 5 2008, 11:19) *
Runtime error
Definitely the case as the operations work fine on a smaller subset of the library. No biggie, it's ludicrously large anyhow.
+Quote Post
0 Members:
RSS Lo-Fi Version Time is now: 24th May 2013 - 14:29
