IPB
> Notice!
> freedb option not selectable, Cannot select "determine from selected MP3-files"
Vernon
post Feb 17 2004, 13:40
Post #1
Member
Group: Members
I have a local copy of FreeDB.
I set the local db path as the default option.
I select mp3s from a directory and I choose "freedb ( local )" from the freedb menu, then I want to choose "determine from selected MP3-files" but this option is light grey and I cannot select it.
Help is kindly requested, please.
Go to the top of the page
+Quote Post
Florian
post Feb 17 2004, 13:51
Post #2
Developer
Group: Admin
Mp3tag Version: 2.55a
Vernon,
this option and the query based on a search string are not available for local databases.
The freedb query based on select files option uses a fuzzy matching
algorithm of the remote freedb-server software to get the results. The
option is greyed out at local freedb, because disc-id calculation based on
audio files couldn't be as exact as needed for getting the right album.
Best regards,
~ Florian
+Quote Post
Vernon
post Feb 17 2004, 14:58
Post #3
Member
Group: Members
Thank you very much for your answer.
This software is not as useful as I thought...
Which program can you use to tag songs if you have 10GB of mp3s and you're not online?
+Quote Post
Darren
post Jul 26 2005, 10:51
Post #4
Member
Group: Members
Mp3tag Version: 2.3.2
Hey Florian,
Do you know of any software out there that will do this ?
While MP3Tag is great, I'm in the same situation as this guy, and the prospect of manually typing in all the info isn't all that appealing....
Cheers,
Darren.
+Quote Post
Florian
post Aug 11 2005, 09:52
Post #5
Developer
Group: Admin
QUOTE (Darren @ Jul 26 2005, 11:51)
You can create a local index and search for albums in your local database using a search string.
Regards,
~ Florian
+Quote Post
0 Members:
RSS Lo-Fi Version Time is now: 19th June 2013 - 01:40
