IPB
> [X] WMA -> FLAC AlbumArtist, V2.41b
chrisjj
post Sep 19 2008, 13:32
Post #1
Member
Group: Full Members
Mp3tag Version: -
In WMAs, Mp3tag %band% shows my WM/AlbumArtist - fine.
By when I convert WMA -> FLAC, faithfully transferring WMA/AlbumArtist to vorbis comment ALBUMARTIST=, Mp3tag %band% fails to show the value.
Even though Mp3tag's FLAC mapping is undefined (well, I cannot find a definition in the docs), I'm guessing this is a bug.
Is there a workaround? I don't want to have to retag all 16K files.
And is a fix planned?
Go to the top of the page
+Quote Post
Hubird
post Sep 25 2008, 14:32
Post #2
Member
Group: Full Members
Mp3tag Version: 2.41b
Off Topic:
I might have misunderstood your post.
But....
Are they "Windows Media Audio 9 Lossless" files you are converting ? If not I do not see the point in converting them in the first place.
+Quote Post
chrisjj
post Sep 25 2008, 22:03
Post #3
Member
Group: Full Members
Mp3tag Version: -
Yes.
FLAC has advantages.
+Quote Post
Florian
post Sep 26 2008, 10:33
Post #4
Developer
Group: Admin
Mp3tag Version: 2.55a
This won't be changed, because changing this mapping would only create further confusion.
The last time I've touched the mapping of this fields I had to revert the change due to massive negative feedback from the users.
A workaround would be to create an action that copies the value of BAND to ALBUMARTIST and removes the BAND field afterwards. This action needs to applied only once after conversion of your WMA files.
+Quote Post
chrisjj
post Sep 29 2008, 02:36
Post #5
Member
Group: Full Members
Mp3tag Version: -
Thanks Florian, but it's not acceptable to change the files' tags just to get Mp3tag to show them properly.
OK, then why not then add a new placeholder that does work properly? I.e. shows the Album Artist consistently across the various formats? This is a pretty reasonable requirement of a 'universal' tag editor.
This post has been edited by chrisjj: Jan 4 2009, 03:21
+Quote Post
chrisjj
post Jan 4 2009, 03:23
Post #6
Member
Group: Full Members
Mp3tag Version: -
Please? I really would like to have one column showing/editing Album Artist independent of audio format, and since Mp3tag is trying to give independence of format... can't it help here?
+Quote Post
0 Members:
RSS Lo-Fi Version Time is now: 19th June 2013 - 19:17
