Feb 18 2009, 15:48
Post
#1
Member Group: Members Posts: 4 Joined: 18-February 09 Member No.: 8575 Mp3tag Version: 2.42 |
The old Web Source Script for Metal Archives doesn't work for me. So I made a new one. It uses the Album-Search on the Metal Archives Site, not Google, to find the right album.
It just needs the name of the Album to find the right values. I just added a second Plugin. It searches for the band name. It will only find the first 50 albums of the matching artists. I also added a third Plugin. This one searches for the song title. It imports: Artist, Album, Title, Year, Cover, Publisher Note: You can only find real Metal with this Plugin. This post has been edited by mayhemer: Jun 10 2009, 11:43
Attached File(s)
Metal_Archives.src ( 2.19K )
Metal_Archives___Song.src ( 2.19K )
Metal_Archives___Artist.src ( 2.2K )
Number of downloads: 544 |
Mar 11 2009, 15:17
Post
#2
Just added a second Plugin. It searches for the band/artist name.
Mar 11 2009, 15:24
Post
#3
Mar 28 2009, 23:56
Post
#4
![]() Member Group: Full Members Posts: 6 Joined: 13-October 08 From: France Member No.: 7711 Mp3tag Version: 2.52 |
Thank you for this web sources scripts headbanger
Apr 1 2009, 08:17
Post
#5
Member Group: Members Posts: 1 Joined: 1-April 09 Member No.: 9448 Mp3tag Version: 2.42 |
This isn't working for me. I follow the instructions, saving it to: C:\Documents and Settings\*username*\Application Data\Mp3tag\data\sources, but it doesn't work (?)
I tried adding .srs and .ini and it still won't work |
Jun 10 2009, 11:45
Post
#6
This isn't working for me. I follow the instructions, saving it to: C:\Documents and Settings\*username*\Application Data\Mp3tag\data\sources, but it doesn't work (?) I tried adding .srs and .ini and it still won't work Do you use Windows XP? In Windows Vista you have to use an other path: C:\Users\*username*\AppData\Roaming\Mp3tag\data\sources |
Dec 18 2010, 20:19
Post
#7
Member Group: Full Members Posts: 7 Joined: 18-December 10 Member No.: 13428 Mp3tag Version: 2.47b |
I'm using this web source script very often and it works fine in most cases, but I have a problem when I'm looking for split releases with multiple artists. In this case I just retrieve the songs of the first artist. And sometimes it gets very often "user abort" errors on searching. But maybe this is more a hoster problem or is somewhere a timeout counter? Would be great if someone could fix this issue, because I'm not very experienced with scripting. thanks in advance |
Apr 22 2011, 21:14
Post
#8
Member Group: Members Posts: 2 Joined: 22-April 11 Member No.: 14281 Mp3tag Version: v2.48 |
Sadly this doesn't work any more since Metal-Archives updated their layout.
Could someone please fix this? Many thanks in advance. Kind regards, BMirsun |
Apr 29 2011, 14:42
Post
#9
Member Group: Full Members Posts: 11 Joined: 29-January 10 Member No.: 11734 Mp3tag Version: 2.46a |
Sadly this doesn't work any more since Metal-Archives updated their layout. Could someone please fix this? Seems to me that the old site has moved from www.metal-archives.com to v1.metal-archives.com. The following seems to work: For all three .src files: - open in notepad - search/replace all "www.metal" with "v1.metal" |
Apr 29 2011, 16:24
Post
#10
Member Group: Full Members Posts: 5 Joined: 25-August 10 From: Moscow Member No.: 12830 Mp3tag Version: 2.48d |
Apr 29 2011, 20:56
Post
#11
Seems to me that the old site has moved from www.metal-archives.com to v1.metal-archives.com. Ah, yes, of course. I didn't recognize that - open in notepad - search/replace all "www.metal" with "v1.metal" Bingo, works. Many thanks! *thumbs up* Kind regards. |
Lo-Fi Version | Time is now: 21st May 2013 - 18:17 |
