IPB
> [F] "MM Rating" field needs updating
Mizery_Made
post Jun 23 2009, 20:57
Post #1
Member
Group: Full Members
Mp3tag Version: 2.52
During the MediaMonkey 3.1 development cycle, some changes were made to MediaMonkey's Ratings values to fall more in line with WMP/Windows/etc. As a result, this feature in your program has been thrown off. Some ratings in MM appear lower in your program, while other MM ratings aren't shown under the MM Rating field, but rather as a normal POPM entry.
Seeing as 3.1 has been officially released and this change is now out in the wild, you might want to look into adjusting things within MP3Tag, if you plan to continue to support this feature. It doesn't contain information about what the values were changed to, but the relevant MediaMonkey bug entry for this change is here, I believe.
Go to the top of the page
+Quote Post
dano
post Jun 24 2009, 23:05
Post #2
Moderator
Group: Moderators
Mp3tag Version: 2.55a
Interesting. I checked it, these should be the new values Florian:
252
242
196
186
128
118
64
54
23
13
0
+Quote Post
Mizery_Made
post Jun 24 2009, 23:36
Post #3
Member
Group: Full Members
Dano looks to be correct.
+Quote Post
Florian
post Jun 26 2009, 09:55
Post #4
Developer
Group: Admin
Thanks dano for the new values. I'll update them with the next build.
Kind regards,
Florian
+Quote Post
chrisjj
post Jun 29 2009, 18:30
Post #5
Member
Group: Full Members
Mp3tag Version: -
Er, Florian, PLEASE do not break compatibility for people remaining on previous MM versions.
If Mp3tag is to accomodate MM's new back-incompatible ratings levels, it should be WITHOUT messing with the existing %rating mm%. E.g. should be by a new %rating mm 2%.
+Quote Post
Florian
post Jun 30 2009, 16:09
Post #6
Developer
Group: Admin
Sorry, but I don't plan to maintain multiple versions of that field.
+Quote Post
chrisjj
post Jun 30 2009, 17:43
Post #7
Member
Group: Full Members
Mp3tag Version: -
How then Florian will you avoid your proposed change messing up the majority of MM users - those on previous versions?
+Quote Post
Mizery_Made
post Jun 30 2009, 18:54
Post #8
Member
Group: Full Members
QUOTE (chrisjj @ Jun 30 2009, 11:43) *
Proof?
It's not like they would be unable to edit ratings anymore. They would be available just as they appeared before Florian implemented the MM Rating 'field,' as standard POPM entries. Florian doesn't have to even offer this feature, but he chose to. 3.1 has been released and is the official version now, as a result, I feel if Florian wants to continue to support this field, it should reflect the current official build, not an outdated one that some may continue to use.
This post has been edited by Mizery_Made: Jun 30 2009, 18:55
+Quote Post
chrisjj
post Jun 30 2009, 19:30
Post #9
Member
Group: Full Members
Mp3tag Version: -
No-one suggested that.
That is no use or relevence to users of Rating MM.
He's not 'offering' it. It is a defined facility of Mp3tag. See http://help.mp3tag.de/en/main_tags.html .
That would break compatibility with existing scripts. I.e. the same script on the same rating values would give different output.
I wonder if you'll be here proposing compatibility breakage every time the MediaMonkey developers change their mind about their official ratings coding...
This post has been edited by chrisjj: Jun 30 2009, 20:07
+Quote Post
Mizery_Made
post Jun 30 2009, 19:52
Post #10
Member
Group: Full Members
Yes, I'll be here proposing a change every time a change in MM's ratings values make it into the official release. It's not as if I was here months ago when the change was first implemented into the Betas, only when 3.1 went official and was released to the general public did I come here and suggest this change.
+Quote Post
chrisjj
post Jun 30 2009, 20:13
Post #11
Member
Group: Full Members
Mp3tag Version: -
Again, no-one suggested that.
I am sad to see you MediaMonkey people are not satisfied to keep breakages of back-compatability to your own product.
+Quote Post
Mizery_Made
post Jun 30 2009, 20:16
Post #12
Member
Group: Full Members
If you have such a problem with MediaMonkey, perhaps it would just be easier for you to discontinue use of it?
+Quote Post
chrisjj
post Jun 30 2009, 22:49
Post #13
Member
Group: Full Members
Mp3tag Version: -
You are wrong.
+Quote Post
Florian
post Jul 12 2009, 20:22
Post #14
Developer
Group: Admin
I've updated the internal mapping to MediaMonkey 3.1 values with the current Development Build.
+Quote Post
0 Members:
RSS Lo-Fi Version Time is now: 24th May 2013 - 21:51
