IPB
> Batch processing with an Export Config
rko31415
post May 18 2016, 02:38
Post #1
Member
Group: Full Members
Mp3tag Version: 2.58
I recently realized you can run batch operations within an export configuration. This makes the export function very powerful. For example, below I test each of my podcasts against a standardized list of album names. My file naming convention is album - title, and this validates the album portion of the filename.
I use standard Export looping operations to build a temporary folder of files entitled album.txt and then check for the existence of the album portion of the podcast filename against these folder files.
Perhaps this is not the most elegant programming, but it illustrates how you can integrate tag names into a batch executable.
Basically I used Export looping to build an expanded batch file. Note: you need to double the batch variable percentage signs beyond the normal batch doubling of percentage signs for this to work.
CODE
$filename($getEnv('USERPROFILE')'\desktop\AlbumTagChk.bat',ANSI)
@Echo Off
chcp 1254
if NOT EXIST g:\trashit\ mkdir g:\trashit\
$loop(%album%)
echo. 2>g:\trashit\"$replace(%album%,'%','%%')".txt
$loopend()
echo The following process takes about 15 minutes. Go get a coffee.
setlocal DisableDelayedExpansion
for /r "G:\itunes\Podcasts\" %%%%i in (*.*) do (
  set "buffer=%%%%~nxi"
  setlocal EnableDelayedExpansion
  for /f "tokens=1* delims=¬" %%%%j in ("!buffer: - =¬!") do (
  endlocal
  set "input=%%%%j"
  set "file=%%%%i"
  if NOT EXIST G:\trashit\!input!.txt echo !file!
  endlocal
for /r "H:\itunes\Podcasts\" %%%%i in (*.*) do (
  endlocal
  set "input=%%%%j"
  set "file=%%%%i"
  endlocal
rmdir g:\trashit\ /s/q
pause
$puts(REM,'Reads the Albumtags folder & creates disposable folder filled with 1 .txt file 4 ea. album')
$puts(REM,'Recurses the Main Library checking the Album in the Album - Title.mp3 naming convention')
$puts(REM,'Displays filenames where the Album portion of filename not found in the disposable folder')
$puts(REM,'The Albumtags folder s.b. the only folder in Mp3tag for this Export Config to work properly')
Hope this is helpful for some folks.
rko
Go to the top of the page
+Quote Post
0 Members:
RSS Lo-Fi Version Time is now: 22nd November 2017 - 00:05
