IPB
19 Pages V  « < 16 17 18 19 >
> [WS] iTunes, web sources script
ohrenkino
post May 9 2017, 18:22
Post #256
Member
Group: Full Members
Mp3tag Version: 2.85
OK.
Try an action of the type "Format value" for YEAR
Format string: $left(%year%,4)
Go to the top of the page
+Quote Post
gabotojojo
post May 9 2017, 19:18
Post #257
Member
Group: Full Members
Mp3tag Version: v2.80
QUOTE (ohrenkino @ May 9 2017, 14:22) *
OK.
It works great! Thanks!
+Quote Post
ms6676749
post May 28 2017, 02:10
Post #258
Member
Group: Full Members
Mp3tag Version: 2.75
QUOTE (gabotojojo @ May 9 2017, 03:18) *
I was wondering if there's an easy way to modify the script to grab only the year. I don't like the whole release date, just the year. I'm just getting started, don't know much about editing src's.
Thanks!
This may or may not apply to you. Just a FYI for anyone else who simply wants the four-digit year. Use the following in place of the "# YEAR" section (modified from Stevehero's src):
CODE
# YEAR
    outputto "YEAR"
    regexpreplace "(\d{4}-\d{2}-\d{2})" "<<<$1>>>"
    sayregexp "(?<=\"releaseDate\":\"<<<).+?(?=-\d{2}-\d{2}>>>)" ", " "}"
+Quote Post
MvT
post Jun 12 2017, 18:11
Post #259
Member
Group: Members
Mp3tag Version: 2.82
Hello,
Is it possible to integrate, that "TRACK" lists the TRACKNUMBER and the TOTALTRACKS like "2/14"?
I tried this for disc numbers (see below) and it worked, but when I implement the same part for "TRACK" it overwrites the title of the song.
Any guess on what I could do?
CODE
outputto "DISCNUMBER"
FindLine "\"discNumber\":"
FindInLine "\"discNumber\":"
SayUntil ", \""
Say "/"
FindLine "\"discCount\":"
FindInLine "\"discCount\":"
SayUntil ", \""
Say "|"
CODE
outputto "TRACK"
FindLine "\"trackNumber\":"
FindInLine "\"trackNumber\":"
SayUntil ", \""
Say "/"
FindLine "\"trackCount\":"
FindInLine "\"trackCount\":"
SayUntil ", \""
Say "|"
+Quote Post
yourdadsmusic
post Jun 13 2017, 23:26
Post #260
Member
Group: Full Members
curious if someone could help me with this, I want [Search By] to remove additional tags often found in the %title%
so far this is what I have
CODE
[SearchBy]=%title%
    replace " (Clean)" ""
    replace " (Clean) (Extended)" ""
    replace " (Instrumental)" ""
I do not know how to make the replace action act on %title% so that the search will prompt the title without the aditional (Clean) (Extended) tags for example. Thanks!
This post has been edited by yourdadsmusic: Jun 13 2017, 23:26
+Quote Post
ms6676749
post Jun 14 2017, 18:20
Post #261
Member
Group: Full Members
QUOTE (yourdadsmusic @ Jun 13 2017, 23:26) *
CODE
[SearchBy]=%title%
Try this:
CODE
[SearchBy]=$regexp($replace($replace($replace(%title%,'(Clean)',),'(Extended)',),'(Instrumental)',),'(^.*[^ ])(.*$)',$1)
Basically, $replace removes those "additional tags" and $regexp eliminates the trailing spaces.
This post has been edited by ms6676749: Jun 14 2017, 18:50
+Quote Post
yourdadsmusic
post Jun 16 2017, 17:03
Post #262
Member
Group: Full Members
QUOTE (ms6676749 @ Jun 14 2017, 19:20) *
Try this:
CODE
Thanks! this works perfectly! for anyone having trouble with this, if you want to add another word to remove from the query you have to add another ($replace to the line. so if you are removing 10 words, you should have 10 instances of ($replace also.
My final search query looks like this, you can see that i added "feat." and "&" to be filtered out of the artist section also
CODE
[SearchBy]=$regexp($replace($replace(%artist%,' feat.',),' &',),'(^.*[^ ])(.*$)',$1) $regexp($replace($replace($replace($replace($replace(%title%,'(Clean)',),'(Dirty)',),'(Extended)',),'(Radio Edit)',),'(Short Edit)',),'(Instrumental)',),'(^.*[^ ])(.*$)',$1)
+Quote Post
DetlevD
post Jun 16 2017, 17:18
Post #263
Member
Group: Full Members
QUOTE (yourdadsmusic @ Jun 16 2017, 18:03) *
... if you are removing 10 words, you should have 10 instances of ($replace ...
To minimize the complexity of the formatstring, ...
see "Mp3tag/help/main_scripting.html" ...
the function $replace allows to add "from-to-pairs" within the function parameter list, ...
$replace(string,from1,to1,from2,to2,...)
DD.20170616.1818.CEST
+Quote Post
yourdadsmusic
post Jun 16 2017, 21:38
Post #264
Member
Group: Full Members
QUOTE (DetlevD @ Jun 16 2017, 18:18) *
oh awesome Ill try that out thanks! If anyone could help me with this last adjustment it would be awesome. I'm trying to get publisher field to only display record label info, no date or distributor. In trying to get rid of the date i figured the following would work:
CODE
outputto "PUBLISHER"
FindLine "\"copyright\":\""
FindInLine "\"copyright\":\""
SayUntil "\", \""
regexpreplace "℗ (\d{4})" ""
but it seems unable to grab the date, should I be putting this under # COPYRIGHT instead? i think my best option would be to use $cutLeft and specify 7 spaces to be removed, but i havent been able to properly integrate it
as for the following distributor info, I would like to make a rule that anything starting with and following a "/" or " ," would be removed.
An example of my ideal Publisher field; ℗ 2017 Kemosabe Records/Columbia Records, a Division of Sony Music Entertainment
would turn into Kemosabe Records
sorry for the ignorance! I really appreciate the help
This post has been edited by yourdadsmusic: Jun 16 2017, 21:39
+Quote Post
ms6676749
post Jun 18 2017, 01:45
Post #265
Member
Group: Full Members
QUOTE (yourdadsmusic @ Jun 16 2017, 22:38) *
Try this (just some of my modifications to the script I use personally):
CODE
# PUBLISHER
    regexpreplace "\,\s[Uu]nder\s[Ee]xclusive\s[Ll]icense.*?(\",)" "$1"
    regexpreplace "(?:(?<=\"copyright\":\")(?:[^A-Za-z0-9]\s)?\d{4}\s([^/]*).*?(\",))" "$1$2"
    sayregexp "(?<=\"copyright\":\").+?(?=\")" ", " "}"
This post has been edited by ms6676749: Jun 18 2017, 02:22
+Quote Post
yourdadsmusic
post Jun 21 2017, 20:06
Post #266
Member
Group: Full Members
QUOTE (ms6676749 @ Jun 18 2017, 02:45) *
CODE
# PUBLISHER
Thanks so much again, its working perfectly. learning from what you gave me I added a line to remove ", a division of" clauses that come up alone sometimes; example- Epic Records, A Division of Sony.... you can see how i added below. It's amazing how helpful you guys are on this forum
CODE
regexpreplace "\,\s[Aa]\s[Dd]ivision.*?(\",)" "$1"
regexpreplace "(?sad.gif?<=\"copyright\":\")(?:[^A-Za-z0-9]\s)?\d{4}\s([^/]*).*?(\",))" "$1$2"
I am curious about the indentation of some lines though, is this just for organization or does mp3tag actually read the indented lines differently? my script seems to be working fine without the indentation
This post has been edited by yourdadsmusic: Jun 22 2017, 00:40
+Quote Post
yourdadsmusic
post Jun 21 2017, 20:13
Post #267
Member
Group: Full Members
has anyone changed this window to automatically prompt "No" instead of "Yes" to increase workflow speed? I've tried to find this window in Resource Hacker but haven't been able to
+Quote Post
ohrenkino
post Jun 21 2017, 20:27
Post #268
Member
Group: Full Members
If you press Alt-N on the keyboard (or perhaps even only "N") you can close the window almost as easy as pressing enter.
Also, there are some options in Tools>Option>Messages where you can tune which messages you want to see.
+Quote Post
ms6676749
post Jun 21 2017, 23:37
Post #269
Member
Group: Full Members
QUOTE (yourdadsmusic @ Jun 21 2017, 20:06) *
Organization. It is easier for me to find stuff I need to edit that way.
This post has been edited by ms6676749: Jun 21 2017, 23:38
+Quote Post
yourdadsmusic
post Jun 27 2017, 00:37
Post #270
Member
Group: Full Members
QUOTE (ohrenkino @ Jun 21 2017, 21:27) *
works great thanks a million
QUOTE (ms6676749 @ Jun 22 2017, 00:37) *
ah makes sense.
Ok this is likely my last question so I can finally stop bothering you guys. Regarding the [IndexUrl] and [AlbumUrl], I want the script to search a different index by the track name not the album name, so that when entering my SearchBy prompt of "%artist% %title%" the result will come up with the album containing that track even if the %title% isn't present in the album name.
I've tried some combinations of entity=musicTRACK and adding some attributes but no combinations i've used have gotten results so I'm wondering if i could get some help here as well. Thank you again
+Quote Post
3 User(s) are reading this topic (3 Guests and 0 Anonymous Users)
0 Members:
RSS Lo-Fi Version Time is now: 22nd November 2017 - 15:29
