REQUEST: Change inconsistent behavior of movement of files
I would like to report an inconsistency when moving files
If folder A and B were loaded to Mp3tag, then movement [with Mp3tag] of files from folder B to A will leave them displayed on the list of files
But when only folder B was read by Mp3tag, then when files from it are move to folder A, then they "disappear"- because they entirely removed from the list
I would like to retain the view of moved files on the list in both situations
see this thread on a similar description of the problem:
[X] Move .MP4 Files
I just did; post a question there
Thank you
This issue is no longer valid:
Case closed
