IPB
> Notice!
> Can't run 285 version on High Sierra
xemi
post Jan 6 2018, 13:50
Post #1
Member
Group: Members
Mp3tag Version: 285
Hi, I had an old version of mp3Tag on my iMac, working properly.
Yesterday I decided to upgrade to 285 version.
I kept all steps :
- Download mp3tagv285-macOS-Wine.zip
- Delete the previous version
- Allow applications from verified developers at System Settings > Security
- Delete previous settings from /Users/<Your Name>/Library/Application Support/de.mp3tag.Mp3tag_*
- Unzip mp3tagv285-macOS-Wine.zip, copy Mp3tag.app to your Applications folder and run it from there
Restarted my Mac several times and nothing.
I try to run the app from Applictions folder and it seems to run for a second but then it disappears.
Help please.
Go to the top of the page
+Quote Post
Florian
post Jan 6 2018, 14:04
Post #2
Developer
Group: Admin
Mp3tag Version: 2.85k
There are two things people keep missing, maybe you can check:
Make sure you copy Mp3tag.app over to the Applications folder before executing — otherwise macOS will prevent it from running.
And the folder
CODE
is different from
CODE
Make sure you're deleting from the former (/Users/<Your Name>/Library/Application Support/). If you don't see the "Library" folder in your user's home directory, you'd need to make hidden files visible via Terminal.app and the command line
CODE
defaults write com.apple.finder AppleShowAllFiles YES
– Florian
+Quote Post
xemi
post Jan 6 2018, 15:27
Post #3
Member
Group: Members
Mp3tag Version: 285
QUOTE (Florian @ Jan 6 2018, 14:04) *
And the folder
CODE
is different from
CODE
CODE
– Florian
Hi, Florian.
I did everything you wrote.
I checked carefully that I deleted every folder from the right folder.
After that restarted and re-download the zip file.
Moved the app file to Applications folder and then nothing happens.
Just it appears again /Users/<Your Name>/Library/Application Support/de.mp3tag.Mp3tag_* that I deleted before restarting, but nothing about mp3tag running.
And worst, the old version that I was using until yesterday, doesn`t work as well sad.gif
Any further idea?
+Quote Post
xemi
post Jan 7 2018, 19:04
Post #4
Member
Group: Members
Mp3tag Version: 285
Are there any other files that are involved in running mp3tag on MacOs High Sierra?
I did every step carefully and keep without being able to use the app.
ideas?
+Quote Post
stephnach
post Jan 8 2018, 10:30
Post #5
Member
Group: Banned
Mp3tag Version: 2.84a
QUOTE (xemi @ Jan 7 2018, 19:04) *
ideas?
I am also using a mac and had the same problem - luckily the suggestion from Florian did work for me... not sure, maybe you want to check again if all the steps you applied are correct? Check this one out: https://www.mp3tag.de/en/mac-osx.html - maybe you want to delete the old one and download it again if nothing else works....
Best,
Steph
Steph
+Quote Post
xemi
post Jan 14 2018, 16:13
Post #6
Member
Group: Members
Mp3tag Version: 285
QUOTE (stephnach @ Jan 8 2018, 10:30) *
Best,
Steph
Thanks Steph.... I did every step for many times. I'm quite sure I did it correctly.
Deleted, installed, delete again, download again... The mp3Tag icon appears for one second and then it disappears......
ideas?
+Quote Post
ohrenkino
post Jan 14 2018, 16:51
Post #7
Member
Group: Full Members
It is a little tricky to look over your shoulder from the distance to help you.
Here is another thread: https://forums.mp3tag.de/index.php?showtopic=21565&st=30
+Quote Post
0 Members:
RSS Lo-Fi Version Time is now: 16th January 2018 - 22:26
