IPB
> Notice!
> Filename to releasetime - a little help?
earbox
post Jan 9 2018, 18:53
Post #1
Member
Group: Members
Mp3tag Version: 2.56
Hi, folks--forgive me my naivete, since I barely speak regex.
I have a lot of files--NPR stories, to be specific--where the filename begins with a 8-character string that is the release date in YYYYMMDD form. I'd like to create an action to insert this string into the releasetime field as MM/DD/YYYY so that I don't have to adjust each day's worth of files manually.
The filenames all look like this: 20171201_atc_the_disaster_artist_is_the_best_movie_about_a_bad_movie
Is this something that can be done? Thanks.
Go to the top of the page
+Quote Post
stevehero
post Jan 9 2018, 18:59
Post #2
Member
Group: Full Members
Mp3tag Version: 2.84
Try
(Format action)
Format : RELEASETIME
$regexp(%_filename%,^([19|20]\d{2})(\d{2})(\d{2}).*,$2/$3/$1)
Or you could add this to a new column for easy sorting using (in the sort part of the new column ui)
This post has been edited by stevehero: Jan 9 2018, 19:19
+Quote Post
ohrenkino
post Jan 9 2018, 19:07
Post #3
Member
Group: Full Members
Mp3tag Version: 2.85k
Actually, the field RELEASETIME has the format
yyyy-mm-ddThh:mm:ssZ
So a transformation into MM/DD/YYYY would create an invalid releasetime.
If you want to get it right, then proceed as follows:
Create an action group with several actions as follows:
Format value for RELEASETIME
Format string: $regexp(%_filename%,^(\d+).*,$1)
This imports the leading number from the filename into RELEASETIME
Then insert the separators and a dummy time at the end:
Format string: $regexp(%releasetime%,(\d\d\d\d)(\d\d)(\d\d),$1-$2-$3T00:00:00Z)
+Quote Post
earbox
post Jan 10 2018, 17:05
Post #4
Member
Group: Members
Thank you both--I'll give those a try!
+Quote Post
0 Members:
RSS Lo-Fi Version Time is now: 18th January 2018 - 12:57
