IPB
> Notice!
> Action Submenus
Paul_Hossler
post Aug 29 2017, 16:04
Post #1
Member
Group: Full Members
Mp3tag Version: v2.65
I discovered that I accidently created an empty submenu in my Actions list so I realized it was possible
I could not find it in the documentation, but Googling I found:
https://forums.mp3tag.de/lofiversion/index.php?t22589.html
While I personally find the technique a little counter intuitive, it works well using the actions dropdown
Suggestion - if it's not in the documentation, it should be added since it's very useful
Suggestion - if it IS in the documentation, it should be made a little more prominent
Suggestion - what would be much easier to setup would be a real multi-level menu where you can insert a new sub-menu and drag actions into it
Paul
Valley Forge, PA, USA
Go to the top of the page
+Quote Post
ohrenkino
post Aug 29 2017, 16:30
Post #2
Member
Group: Full Members
Mp3tag Version: 2.84a
Did you know that if you add an & in front of any letter in the name of the action then the letter becomes a hotkey that can be addressed in a combination with Alt+Menu hotkey+user-defined action hotkey?
+Quote Post
Paul_Hossler
post Aug 30 2017, 01:39
Post #3
Member
Group: Full Members
QUOTE (ohrenkino @ Aug 29 2017, 11:30) *
Yes, but what I did not know was that MP3TAG uses # to create a submenu entry, even without the &
Silly example: If I have 3 actions:
Change &Title#From Artist
Change &Title#From Album
Change &Title#From Filename
The actions dropdown will show
[Change Title] >
[From Artist]
[From Album]
[From Filename]
This submenu capability is a pretty handy feature that I had been looking for and couldn't find in the documentation
This post has been edited by Paul_Hossler: Aug 30 2017, 01:40
Paul
+Quote Post
DetlevD
post Aug 30 2017, 07:05
Post #4
Member
Group: Full Members
QUOTE (Paul_Hossler @ Aug 30 2017, 02:39) *
... MP3TAG uses # to create a submenu entry ... This submenu capability is a pretty handy feature that I had been looking for and couldn't find in the documentation
See also ...
https://forums.mp3tag.de/index.php?showtopi...ost&p=34328
I do not remember from where I have got it before.
DD.20170830.0805.CEST
+Quote Post
0 Members:
RSS Lo-Fi Version Time is now: 20th September 2017 - 04:44
