IPB
> Notice!
> File Modified Dates updated Unnecessarily
Paul_Hossler
post Sep 10 2017, 22:27
Post #1
Member
Group: Full Members
Mp3tag Version: v2.65
I've noticed that if I have a group of files selected in the MP3Tag window and apply a change that only affects some, the Windows modified date/times for all the selected files are updated
I had a few files that had an extended tag set wrong, and rather that search one at a time, I selected the whole folder and set the proper tag, expecting that only a few files would be modified
Example:
1. Copy a group of files to a temp folder (Comment field in all was blank)
2. Apply MP3Tag to the folder and add a comment to one file
3. Modify date for that file is updated
4. Select all files
5. Make Comment = <blank> and Save (ctrl-S)
6. Modify dates for all files are updated
Doing a backup that compared modify dates to determine which files have change take a LOT longer since so many unchanged files are backed up
Paul
Valley Forge, PA, USA
Go to the top of the page
+Quote Post
ohrenkino
post Sep 11 2017, 06:03
Post #2
Member
Group: Full Members
Mp3tag Version: 2.85
You have described the behaviour accurately.
Yet, MP3tag does not compare the already existing data with the modified but simply writes whatever it finds into the tags.
This means, that the files get actually rewritten even though you do not see a lot of difference between the current and the former state.
The only way around this would be to use filters or other selective mechanisms to pinpoint only those files that need the update.
+Quote Post
DetlevD
post Sep 11 2017, 06:15
Post #3
Member
Group: Full Members
QUOTE (Paul_Hossler @ Sep 10 2017, 23:27) *
I've noticed that if I have a group of files selected in the MP3Tag window and apply a change that only affects some, the Windows modified date/times for all the selected files are updated ... I selected the whole folder and set the proper tag, expecting that only a few files would be modified ...
The [Ctrl+S] command executed by the user acts as a forced storage against all selected files, therefore the underlying disk system changes the modified date time stamp as usual.
Within the dialog "Mp3tag/Tools/Options/Tags" you can advice Mp3tag to keep the "existing file modification time".
DD.20170911.0715.CEST
+Quote Post
Paul_Hossler
post Sep 11 2017, 13:37
Post #4
Member
Group: Full Members
QUOTE (ohrenkino @ Sep 11 2017, 01:03) *
I suspected that it was just a case where the 'new values' were forced in, even if the value was already there
As suggestion, it would be very nice if the current tag value(s) were checked against the potential new tag value(s) and only if necessary rewrite the file
Since I didn't realize the way it worked, I had 25GB-30GB of MP4s that had to be backed up since I globally applied 'Movie' to a folder that only had 2-3 incorrectly tagged files
Paul
+Quote Post
Paul_Hossler
post Sep 11 2017, 13:39
Post #5
Member
Group: Full Members
QUOTE (DetlevD @ Sep 11 2017, 01:15) *
Thanks, but unfortunately my backup program goes by modification date and it would miss them sad.gif
Paul
+Quote Post
0 Members:
RSS Lo-Fi Version Time is now: 22nd November 2017 - 13:34
