Hi I have windows 10 and my mp3 files on a nas. (i have also tried editing a local file). I have ran the app as administrator, none of the online databases connect:
The error points to a dns issue but my internet access is fine:
freedb: the server failed to return a valid query response code
discogs & discogid" failed to authenticate using oauth (1). the server name or address could not be resolved.
musicbrainz, the server name or address could not be resolved.
i am using 8.8.8.8 for my dns server. Internet access/dns resolution is fine otherwise.
I believe you are correct, checking for updates returns nothing. However I have disabled all forms of AV and firewall as a test, it does not connect to the internet. Everything else on my pc connects fine.
almost the the same problem here running windows xp sp3.
the following messages appear:
discogs: Failed to authenticate using Oauth (1). >>87: Open failed
discogs_release_id: same as above
discogs_pone: same as above
musicbrainz: Fehler beim Verbinden zum Server: misicbrainz.org >>87: Open failed
freedb: The server failed to return a valid queary response code
these errors first appeared with version 2.83c and are still there with version 2.83e.
going back to version 2.83b everything is just perfect.
btw: endless thanks yous to Florian and the members of the amazing forum/support for this unsurpassed masterpiece of a software.
As I said: the discogs server got changed back then.
I have to rely on your statement about the versions although they are not plausible.
As your setup does not meet a basic pre-condition, it is very difficult to do any further debugging - this also in the light of poster poster's post that he does not get any errors.
Well, the TLS version is something installed on the Discogs server (and possibly the other ones as well) and is a feature of the way that Windows access the internet.
So changing the MP3tag version will not help a lot.
So I think it is back to check the local environment first: what does the basic internet access check reveal? Can MP3tag access the internet? Do you get a message box when you look for updates?
Thanks for your patience. It was a tricky issue and based on your description I probably should have spotted it earlier — glad that it's working now for you!
