IPB
> release:txt, Capture a formatted text version of discogs.com, beatport.com, + more
ketamine powder
post Dec 15 2013, 11:15
Post #1
Member
Group: Full Members
Mp3tag Version: 2.58
Hello there, i'm wondering if this is possible to some how transfer this script in mp3tag.
http://userscripts.org/scripts/show/156420
Some previews:
Go to the top of the page
+Quote Post
DetlevD
post Dec 15 2013, 11:54
Post #2
Member
Group: Full Members
Mp3tag Version: 2.85
QUOTE (ketamine powder @ Dec 15 2013, 11:15) *
Hello there, i'm wondering if this is possible to some how transfer this script in mp3tag. ...
You can put the text content, which you get from "release:txt", into a temporary user defined tag-field.
Then use the Mp3tag functions to split the text into "key=value" pairs in order to format the desired tag-fields. Afterwards remove the temporary tag-field.
The simplest way is to put the entire text content, which you get from "release:txt", e. g. into the tag-field UNSYNCEDLYRICS.
Another way to go could be to use the entire "release:txt" javascript program together with the Mp3tag export feature, that means automatical writing the javascript to export output file and afterwards executing the export script using the Windows Scripting Host.
This could also give the chance to create a user defined and fitting data file for importing data into the files and their tag-fields, managed by the Mp3tag import feature.
DD.20131215.1224.CET
This post has been edited by DetlevD: Dec 15 2013, 12:24
+Quote Post
ketamine powder
post Dec 15 2013, 15:07
Post #3
Member
Group: Full Members
QUOTE (DetlevD @ Dec 15 2013, 12:54) *
Thanks, for the tips, i'm not so good at scripting stuff but i will try...
+Quote Post
xaoc2012
post Jul 18 2016, 08:44
Post #4
Member
Group: Full Members
plz fix junodownload.com!!!!
+Quote Post
0 Members:
RSS Lo-Fi Version Time is now: 22nd January 2018 - 15:07
