IPB
> command "KillTag"?
Pufas
post Nov 5 2007, 23:34
Post #1
Member
Group: Full Members
Mp3tag Version: 2.49a
ok,
first of all what it doesand where do i use it? (yes, i've read Web sources framework help, but that was not useful.)
second, i'm writing websource script, and i have 2 unwanted temp tags call "TMP1" and "TMP2".
i use them during script, but in the end i want them removed. is this when should i use killtag? i've tryed
killtag "TMP1"
killtag "TMP2"
but that did not help.
and the last, i've checked other scripts (i.e. discogs) and there are a lot of killtag "*" lines and i can't figure out what do they do.
thanks!
( '.') <( MP3TAG kicks ass! )
Go to the top of the page
+Quote Post
Florian
post Nov 7 2007, 20:32
Post #2
Developer
Group: Admin
Mp3tag Version: 2.85k
If you want to remove the two tag fields TMP1 and TMP2 you can use an action mt_format.png Remove fields.
Kind regards,
Florian
+Quote Post
Pufas
post Nov 9 2007, 14:07
Post #3
Member
Group: Full Members
QUOTE (Florian @ Nov 7 2007, 21:32) *
Kind regards,
Florian
yes, but is there a way to do this within websource, so that i would not have to use actions, just websource.
and could anyone explain me what "killtag" comand does and how it is used?
This post has been edited by Pufas: Nov 9 2007, 14:25
+Quote Post
Victor Kostas
post Aug 31 2016, 21:42
Post #4
Member
Group: Full Members
Mp3tag Version: 2.80c
QUOTE (Pufas @ Nov 9 2007, 15:07) *
Maybe you have found already the solution (maybe not).
Nevertheless, KILLTAG removes xml tags (and not audio ones).
All you need is SET "tagname" command (SET "TMP1").
+Quote Post
0 Members:
RSS Lo-Fi Version Time is now: 23rd January 2018 - 08:41
