IPB
30 Pages V  « < 25 26 27 28 29 > »
> beatport.com scripts by stevehero (search & direct) - jaimz mod, rips cover, album, year, date, catalog #, publisher, genre, www + more
stevehero
post Mar 21 2017, 22:52
Post #391
Member
Group: Full Members
Mp3tag Version: 2.84
QUOTE (ivana @ Mar 21 2017, 14:37) *
hi, i use your script v4.2on win xp sp3, before few days when i use single track search, script can't save cover in id tag of mp3 , but in process of search i see it in right window, even if i left click on cover ,save image in tag option is on. i search in script cover field and here is the copy
CODE
# COVERURL
    outputto "COVERURL"
    say "http://"
    sayregexp "(?<=data-full-image-url=\"//).+?\.jpg"
maybe beatport something change
thank you for answer
If it's appearing in that information window then the script is working. Something else is wrong or at fault. Not sure what it's causing that. Maybe the file has APE tags?
Go to the top of the page
+Quote Post
ivana
post Mar 22 2017, 00:56
Post #392
Member
Group: Full Members
Mp3tag Version: 2.81b
huh i check now in winamp...and woow cover is there but when i open file in mp3tag i can't see cover in tag panel cover window, so i think is mp3tag bug not your script. And if i remove ape tags, now i see cover in mp3tag panel window. Is this bug of mp3tag, feature or what smile.gif before it was working with ape tags
This post has been edited by ivana: Mar 22 2017, 01:00
+Quote Post
stevehero
post Mar 22 2017, 01:20
Post #393
Member
Group: Full Members
QUOTE (ivana @ Mar 21 2017, 23:56) *
I couldn't tell you. Maybe post in the support section of the forum or do a quick search. Just glad it's not my fault tongue.gif
My script has had no issues in two years and long may it continue. If you feel it's good a kind donation is always nice smile.gif
+Quote Post
ivana
post Mar 22 2017, 19:44
Post #394
Member
Group: Full Members
no problem, thank you !
+Quote Post
ohrenkino
post Mar 22 2017, 19:52
Post #395
Member
Group: Full Members
Mp3tag Version: 2.85k
QUOTE (ivana @ Mar 22 2017, 00:56) *
I would say that your tags are out of sync and that you stored the picture in ID3V2 tags and left the APE tags empty.
And as APE overwrites V2 tags, you don't see a picture (even though it is there).
I would get rid of the APE tags altogether as they cause more trouble than do good.
+Quote Post
ivana
post Mar 23 2017, 21:36
Post #396
Member
Group: Full Members
thank you for the tip ! i already disable APE tags, and now using ID3V2
+Quote Post
djepeto
post Apr 13 2017, 21:45
Post #397
Member
Group: Full Members
Now I have problem with files tagged in the last month. When I played them with Windows Media Player in Now Playing Mode doesn't show covers.
I'm confused because for ex. VLC and Winamp show artworks without any problem. huh.gif
After tagging, files get covers, I see them with mp3 tag software, that is ok... but when I play them in WMP I dont see covers. When I add cover from BP manualy problem is same, but when I add picture from other sources WMP shows covers on played files.
So... files tagged in last month only played in WMP doesnt show covers.
For ex. I also used discogs script by Pone in last month, but everything with artworks in WMP is OK.
It seems that something happend with BP pictures...or wmp has problem...
club music makes me happy
+Quote Post
ohrenkino
post Apr 13 2017, 21:47
Post #398
Member
Group: Full Members
could you check if the folders of the files have the file
and what happens if you create one?
+Quote Post
djepeto
post Apr 13 2017, 22:11
Post #399
Member
Group: Full Members
Yes, I checked that. I haven't folder.jpg. When I make this file, mp3 without cover get that cover picture. That is ok.
In WMP:
Add local media files to library when played - unchecked
Add remote media files to library when played - unchecked
Only, but only BP pictures for files tagged in last month have problems in wmp.
+Quote Post
ohrenkino
post Apr 13 2017, 22:25
Post #400
Member
Group: Full Members
QUOTE (djepeto @ Apr 13 2017, 23:11) *
In WMP:
I think that you can set the behaviour of saving graphics after the execution of a web source script in the Utils-Menu that is hidden in the button at the bottom of the web sources dialogue.
Perhaps you have unchecked the option to save the picture not only in the files but also in the file system and you have modified the default file name for artwork from folder. jpg to something else.
+Quote Post
djepeto
post Apr 13 2017, 23:34
Post #401
Member
Group: Full Members
Bottom of web source dialog:
Save image to tag - checked
I have changed nothing in file system, because everything works very well.
Shorter description:
WMP (Now playing mode) shows covers for files tagged with discogs script.
WMP (Now playing mode) shows covers for files tagged with BP script except for files tagged in last month.
VLC and winamp shows covers for all files anyway.
When I manualy add picture from BP and save tag, wmp doesnt show the cover again, except if picture from other source is.
+Quote Post
ohrenkino
post Apr 14 2017, 11:14
Post #402
Member
Group: Full Members
To be honst: WMP does not remember the tag sources that you have used for tagging.
And as I cannot look over your shoulder and find out what the differences are, you have to be as cunning as possible to find the cause.
I would check the tag versions that are in the files (APE usually causes trouble), I would check the files themselves for integrity, and I would check if there are more than one embedded picture in the files and perhaps one of them is invalid/empty, whatever.
Or the picture type is not quite right: bmp instead of png or jpg.
+Quote Post
djepeto
post Apr 14 2017, 16:15
Post #403
Member
Group: Full Members
Yes, you're right about everything. My pictures in tags are jpg and only one picture. Tag version is ID3v2.3. Mp3 files is full correct, checked in mp3val.
Please, for test, if you could manualy put any beatport cover picture to any mp3 file (drag and drop way) and play it in wmp to see what will happen?
+Quote Post
ohrenkino
post Apr 14 2017, 18:10
Post #404
Member
Group: Full Members
QUOTE (djepeto @ Apr 14 2017, 17:15) *
... and play it in wmp to see what will happen?
This is what happens:
I d&d (which I usually never do) a picture from BP to Mp3tag's tag panel and save the modification.
The file has now 2 embedded covers.
I delete the old one in MP3tag.
I switch to WMP - it still shows the old picture.
I delete the track only from the library.
I restore deleted files.
(The preview now shows already the new picture)
I play the track and see the new picture in the "now playing" window.
+Quote Post
djepeto
post Apr 14 2017, 19:50
Post #405
Member
Group: Full Members
Thank you very much!
I see I have problem with only JPG from beatport.
For testing I used image resizer and I converted that jpg to another jpg, I used new jpg file, and finally I can see cover in wmp. My new converted cover has same size 500x500, and amost same file size - about 3 KB more.
Conclusion is everything works very well, but still dont know why my new files get different type of jpg from BP whether I use the BP script or manualy put the cover directly from BP.
+Quote Post
0 Members:
RSS Lo-Fi Version Time is now: 19th January 2018 - 22:23
