IPB
> [X] Discnumber Field won't "Sort", All the numbers will not be sorted
sterredag
post Oct 11 2017, 00:01
Post #1
Member
Group: Members
Mp3tag Version: 2.84a
As the titles says
Tilte, Album everything sorts fine. But my Discnumber Field won't sort. So In stead of:
CD1
CD1
CD2
CD2
They are still al mixed up. I'm using the latest version
Go to the top of the page
+Quote Post
ohrenkino
post Oct 11 2017, 05:58
Post #2
Member
Group: Full Members
Mp3tag Version: 2.85h
The field DISCNUMBER is supposed to be numeric. So, "CD" is not a valid amendment. You should remove that.
A column for DISCNUMBER is not part of the standard delivery, so you must have defined it some time ago yourself.
Check the column definition if you have ticked the option for numeric contents and see if changing the setting helps you.
+Quote Post
sterredag
post Oct 11 2017, 09:54
Post #3
Member
Group: Members
QUOTE (ohrenkino @ Oct 11 2017, 06:58) *
Ah, I can try that! smile.gif Thank you. I wil tell if that worked or not. (Yeah I adjusted the columns myzelf)
(That worked! Many thnx a lot of work has been spared biggrin.gif )
This post has been edited by sterredag: Oct 11 2017, 13:10
+Quote Post
0 Members:
RSS Lo-Fi Version Time is now: 15th December 2017 - 11:24
