IPB
> [F] Wrong path when renaming files
Timbosteron
post Nov 27 2016, 22:56
Post #1
Member
Group: Members
Mp3tag Version: 2.54
When I rename a file using its tags (i.e. creating a folder called "artist" and a subfolder "album") MP3tag doesn't get it right sometimes (see the screenshot).
So instead of drive R:\... MP3tag puts the file in a subfolder \R\...
I think the problem is the slash in the album-tag because a minute earlier it worked fine.
Go to the top of the page
+Quote Post
ohrenkino
post Nov 28 2016, 07:36
Post #2
Member
Group: Full Members
Mp3tag Version: 2.85h
QUOTE (Timbosteron @ Nov 27 2016, 22:56) *
I just tested it - and can partially confirm the bug (which looks like a variation of the 2.78a bug described here https://forums.mp3tag.de/index.php?showtopi...p;#entry91939):
The problem is the combination of path and variable with slash in the data being part of the path (and not just the filename).
If you leave out the variable in the path then MP3tag behaves as it should: no path repetition.
Also, if you treat the whole format string with a $validate()-function then the path comes out correct as well.
But I agree: it looks like a bug.
This post has been edited by ohrenkino: Nov 28 2016, 07:38
+Quote Post
Florian
post Nov 30 2016, 16:06
Post #3
Developer
Group: Admin
I had a look at this and will fix it to the next release. Thanks for reporting!
Kind regards
– Florian
+Quote Post
Florian
post Dec 5 2016, 11:09
Post #4
Developer
Group: Admin
The reported issue is now fixed with the current Development Build (Mp3tag v2.80a).
Thanks again!
Kind regards
– Florian
+Quote Post
0 Members:
RSS Lo-Fi Version Time is now: 16th December 2017 - 06:07
