IPB
> Notice!
> REQUEST: drop files anywhere, Files cannot be dropped anywhere outside the main window
Zerow
post Sep 20 2017, 18:05
Post #1
Member
Group: Full Members
Mp3tag Version: 2.84
I would like to be able to drag and drop my files anywhere within Mp3tag
I just do not understand, what is the purpose of blocking a drop down on Tag Panel of Filter Box? The files are to be loaded [and shown as a list in the min window] and not pasted as a text to some tag field or into the Filter Box
Go to the top of the page
+Quote Post
ohrenkino
post Sep 20 2017, 18:35
Post #2
Member
Group: Full Members
Mp3tag Version: 2.84a
D&D works if the target object knows what to do with the object being dragged.
So if an audio object is dragged to a text box then this text box does not know what to do with the audio file.
Tag panel and filter box feature mainly text accepting objects - but no audio objects.
The Tag panel accepts a picture object as album art, though.
A target object cannot transfer the dragged object to the next object like e.g. the file list - which would accept the audio object and its tag data.
Coming back to your idea: the objects could very well contain text - which would then be used as filter or tag panel data... Is that what you want?
You see that a lot of programs still have not achieved to realize the DWIM concept ("do what i mean").
+Quote Post
Zerow
post Sep 20 2017, 19:52
Post #3
Member
Group: Full Members
QUOTE (ohrenkino @ Sep 20 2017, 19:35) *
And so it should know: just put them on the list as files
And so when that happens- redirect them to the main window
But I bet it checks if this is an object; or when if it a file, what extension it has
And so when seeing an audio extension it could simply treat it as something to be added to the list of files
I want Mp3tag to recognize that I am dragging audio files and allow me them to drop then anywhere. It already recognizes them, because when I hoover with them over the Tag Panel / Filter Box, icons / menu, then the mouse pointer is in form of a circle with a line going through it [indicating elarly a no-go performance]- but the moment I start to hoover over the main window, the pointer changes to a default one
Right now I often have a lot of open windows and so when I select and files that I want to load to Mp3tag, instead of circling through positions with ALT + TAB, I drag them onto the Mp3tag icon pinned to my vertical taskbar. But instead of moving them later on a little to the right, I have to move them a lot to the right- because on the left is the he Tag Panel. And if the Tag Panel happens to be wider, that the movement is bigger. And so when I am dragging files from ride side of my ultrawide screen to the left side where the Mp3tag icon is and then back to the middle of the screen- I perform unnecessary movements and thinking. Multiply them by even up to dozens per day by days and then by years- and you'll get simply frustrated and annoyed with them
This post has been edited by Zerow: Sep 20 2017, 19:53
+Quote Post
ohrenkino
post Sep 20 2017, 20:26
Post #4
Member
Group: Full Members
It would be so much easier if you knew much more about object-oriented programming.
Looking at it from a workflow point of view:
If an object would pass on a dragged object to the next entity in a GUI, e.g. the menu bar which would not accept it. So the menu bar passes it on to the filter box which cannot deal with it so it passes it on to the files list which detects an unsupported file and so passes it on to the tag panel.
And like that the object gets passed around and MP3tag simply stops working. And you do not get any user feedback that you just tried to d&d an illegal object into MP3tag.
So I would say: let us keep it as safe as it is with a decent user-action-feedback. I am sure you will be able to hit the biggest area in MP3tag.
Of if that is not feasible, use the "open folder" function to get to the file.
Or copy&paste the path from the explorer window into the tag panel directory box and press enter.
How come that you always have such difficulties in handling the GUI?
Grabbing the tag panel, for instance: https://forums.mp3tag.de/index.php?showtopic=21985
Using menu functions: https://forums.mp3tag.de/index.php?showtopic=19749
Using custom menus: https://forums.mp3tag.de/index.php?showtopic=21715
+Quote Post
0 Members:
RSS Lo-Fi Version Time is now: 22nd September 2017 - 03:38
