IPB
> [X] folder dialogs freezing, windows 10 creators edition
Prz
post May 1 2017, 12:16
Post #1
Member
Group: Members
Mp3tag Version: 2.82
I updated to windows 10 creators edition, and now all of the dialog popup's are freezing, they all used to work fine in windows 10 version 1511
Go to the top of the page
+Quote Post
ohrenkino
post May 1 2017, 12:34
Post #2
Member
Group: Full Members
Mp3tag Version: 2.85k
QUOTE (Prz @ May 1 2017, 13:16) *
Works fine with my creators version of W10.
Havew you changed the way to install MP3tag (from local to portable or vice versa)?
If so: do you have sufficient access rights for the installation folder and all the other possible locations (see here for options: https://forums.mp3tag.de/index.php?showtopic=976 )
Have you tried to rename the file mp3tag.cfg and start MP3tag with a fresh configuration?
This is what I would check right now.
+Quote Post
Kingclay196
post May 1 2017, 16:56
Post #3
Member
Group: Members
Mp3tag Version: 2.80c
I'm having the same problem on the latest version of mp3tag and I don't have the update yet. It has nothing to do with I. It started happening when k got the latest version of mp3tag.
+Quote Post
ohrenkino
post May 1 2017, 18:22
Post #4
Member
Group: Full Members
QUOTE (Kingclay196 @ May 1 2017, 17:56) *
And what are your findings to the checks I suggested?
PS: I don't understand what "I" and "k" should mean, though.
This post has been edited by ohrenkino: May 1 2017, 18:23
+Quote Post
Prz
post May 1 2017, 22:17
Post #5
Member
Group: Members
I have it working for now, I just uninstalled it, deleting all files in the appdata folder, then reinstalled the standard version without unchecking any options
thanks
+Quote Post
Prz
post May 1 2017, 22:29
Post #6
Member
Group: Members
or maybe not, its something todo with the mp3tag folder in your user :\temp folder, already existing or being deleted when mp3tag is open, then the dialogs start to freeze again
+Quote Post
0 Members:
RSS Lo-Fi Version Time is now: 19th January 2018 - 22:33
