IPB
> [F] Discogs fetch for artist adds comma to name field
MarkC
post May 11 2017, 16:22
Post #1
Member
Group: Full Members
Mp3tag Version: 2.82a
I've just tagged my first album using the 2.82 release and see that the bug detailed in this field is still there.
I realized it wasn't listed here in the bug reports forum.
https://forums.mp3tag.de/index.php?showtopi...&hl=discogs
Go to the top of the page
+Quote Post
ohrenkino
post May 11 2017, 18:07
Post #2
Member
Group: Full Members
Mp3tag Version: 2.85k
QUOTE (MarkC @ May 11 2017, 17:22) *
I still think that discussions about the advantages and shortcomings of web source scripts should be held in the corresponding web sources forum.
There are at least 2 discogs web source scripts so it is a little guess work which one you could mean.
Web sources scripts are not updated automatically: so did you implement the fix that was mentioned in the thread that you referenced?
This post has been edited by ohrenkino: May 11 2017, 18:09
+Quote Post
MarkC
post Jun 15 2017, 00:31
Post #3
Member
Group: Full Members
QUOTE (ohrenkino @ May 11 2017, 19:07) *
No I didn't try it.
The discogs feature I'm trying to use is the ONE shipped with MP3TAG. I've been a user for so long, that I wasn't sure if I'd installed a plugin to get discogs functionality, so I did an install on a different machine. I had not, the discogs I'm trying to use is shipped embedded in MP3TAG.
So it seemed reasonable to report here, so it could be fixed at source. Sorry if I wasn't clear originally.
+Quote Post
DetlevD
post Jun 15 2017, 11:12
Post #4
Member
Group: Full Members
I've just tagged my first album using the 2.82 release and see that the bug detailed in this field is still there. ...
Just to make sure, that you apply the last version of the Mp3tag standard script "discogs.src":
Mp3tag version: 2.82a, script size: 4193 Byte.
Inner change log entry: # [2016-01-31] v1.03
Within this export script there is a code line ...
CODE
json_select_many "artists" "name" ", "
and a following block of related commands ...
which in my opinion, can handle trailing ", ".
You should check your Mp3tag installation, working with the newest version of the source script "discogs.src".
DD.20170615.1212.CEST
This post has been edited by DetlevD: Jun 15 2017, 11:15
+Quote Post
Florian
post Jun 15 2017, 13:31
Post #5
Developer
Group: Admin
QUOTE (MarkC @ Jun 15 2017, 01:31) *
Thanks for taking the time and for bringing this to my attention. I'll fix it with the next release.
Kind regards
– Florian
+Quote Post
Florian
post Jun 17 2017, 09:33
Post #6
Developer
Group: Admin
This is now fixed with the latest Development Build Mp3tag v2.82b.
Kind regards
– Florian
+Quote Post
0 Members:
RSS Lo-Fi Version Time is now: 17th January 2018 - 22:37
