IPB
> [X] Can't remove album tag from flac
Apology11
post Feb 12 2017, 14:00
Post #1
Member
Group: Members
Mp3tag Version: 2.80
I have a problem with the album tag on a flac file.
I have a flac file with an album tag.
I tried to remove it with MP3tag, either by selecting the delete option or just deleting all the charecters from the box. I can save the file and MP3tag shows that tehere is no album tag anymore.
But when I open the file in vlc media player or check the information using MediaInfo tool, the album is still there.
When I override the tag, vlc and MediaInfo show the new tag. But when I remove the new tag again and save, vlc and MediaInfo show the original album tag again.
This post has been edited by Apology11: Feb 12 2017, 14:01
Go to the top of the page
+Quote Post
ohrenkino
post Feb 12 2017, 14:40
Post #2
Member
Group: Full Members
Mp3tag Version: 2.83
So to sum it up: you modify a flac file with MP3tag and MP3tag shows the correct information.
Only if you try to see the new information in other programs you don't see it?
Actually: could you check if you have FLAC tags or ID3 tags in the files? There should only be FLAC tags.
+Quote Post
Apology11
post Feb 20 2017, 18:43
Post #3
Member
Group: Members
QUOTE (ohrenkino @ Feb 12 2017, 14:40) *
The other programs see the information if i change the tag, but not if I remove it, to be precise.
MP3 Tag says:
TAG
Version: FLAC (FLAC ID3v2)
I'm not sure if this means FLAC and ID3 are present?
+Quote Post
ohrenkino
post Feb 20 2017, 19:20
Post #4
Member
Group: Full Members
ZITAT(Apology11 @ Feb 20 2017, 18:43) *
...MP3 Tag says:
TAG
Yes, that means that both tag versions are present. FLAC files should have only FLAC tags.
So cut the tags until only the flac tags are left.
Or, if you see that cutting a tag leaves the ID3 tags, then delete these and paste the flac tags back again.
+Quote Post
0 Members:
RSS Lo-Fi Version Time is now: 24th June 2017 - 13:16
