IPB
> [X] remove cover does not remove the tag field COVERART, COVERART field (and another one) is ignored!
usamike
post Feb 23 2017, 19:26
Post #1
Member
Group: Full Members
Mp3tag Version: 2.81
hi,
i passed one year to search where that problem came from in my music manager (helium music)
When a mp3 file came with the tag "COVERART" (see in id3 tag from windows properties), my music manager software fails and crashed whereas i always use mptag to clean my tags.
but, i just discover now why.
The feature "remove cover" of mp3tag forgets to remove the field COVERART (and another one i can't see the name, sorry)
here a screen capture of a mp3 properties where i just used the "remove cover" feature :
Even, when i upload a new cover art album with mp3tag, this two fields are not updated , why ?
thanks for help please.
Best regards
Mike
Attached thumbnail(s)
i bought my music from amazon (CD & mp3s), itunes (i convert the m4a), and eMusic.
Go to the top of the page
+Quote Post
ohrenkino
post Feb 23 2017, 21:17
Post #2
Member
Group: Full Members
Mp3tag Version: 2.85h
How do you delete a cover?
The easiest way to do it is to select the files and right-click on the cover in the tag panel and select "Delete cover" and save the modification.
The other field that your program shows is the cover_mime_type which shows the type of an embedded cover.
It is a little puzzling that your program shows the binary of a picture as characters.
+Quote Post
usamike
post Feb 23 2017, 22:21
Post #3
Member
Group: Full Members
QUOTE (ohrenkino @ Feb 23 2017, 21:17) *
i do exactly like you said.
The other fields should be removed too when i saven my modification! But mp3tag let them there ! that is the problem ! i don't want them!
i am not the one who put that fields (i guess it is the plateform where i buy the digital). Because they contains a 600x600 cover art album, i always remove the original cover (with mp3tag) and replace them by my own 1000x1000 that i reupload into the mp3 (using mp3tag too).
Even when i upload it, mp3tag forget to update then (even i'd prefer it will erase them and only keep the normal picture inside the tag).
for me it is a bug that mp3tag forget to take in charge of them while i delete the cover or i update it. if you want, i can send you a exemple of such mp3.
+Quote Post
usamike
post Feb 23 2017, 22:28
Post #4
Member
Group: Full Members
i did a test, i just try to remove the old original one (which was a jpeg embeded picture) and upload a PNG new one.
look at it, mp3tag forget to update the fields ! but it got my PNG file into.
so , the bug is produced!
+Quote Post
ohrenkino
post Feb 23 2017, 22:29
Post #5
Member
Group: Full Members
QUOTE (usamike @ Feb 23 2017, 22:21) *
If MP3tag apparently does not delete tags then you should check which tags you let Mp3tag read, write and delete.
The proper setting would be: read and delete all, write only V1 and V2.
Esp. APE tags are a problem.
If you have these in a file, get rid of them.
If this is not the case, check the file's integrity with mp3val and/or mp3diags.
+Quote Post
ohrenkino
post Feb 24 2017, 15:37
Post #6
Member
Group: Full Members
... if you want, i can send you a exemple of such mp3.
Go ahead.
+Quote Post
usamike
post Feb 24 2017, 17:13
Post #7
Member
Group: Full Members
QUOTE (ohrenkino @ Feb 24 2017, 15:37) *
Go ahead.
here is a trim (3 seconds) of a file with that kind of problem
https://1fichier.com/?3tkupi7mv0
+Quote Post
poster
post Feb 24 2017, 17:47
Post #8
Member
Group: Full Members
QUOTE (usamike @ Feb 24 2017, 17:13) *
You have 2 tag-fields (coverart and covertartmime) in your mp3.
As far that I know these tags belong to OggVorbis.
Maybe an orginal Ogg-file was recoded as mp3 and the tags were taken from these ogg-file.
The cover-file you see in Mp3Tag has nothing to do with theses tag-fields.
As you have a mp3 now you don't need these tags.
Just take the extended tag-menue in MP3Tag (ALT-t) and delete these tags.
But because you mention a crash from your player:
I noticed that your embedded cover has xmp-metadata.
Till now I had no such experience but I heard that some players may have problems with metadata in embedded pictures. Perhaps you should strip the pictures from metadata before you embed them in the mp3-file with Mp3Tag.
+Quote Post
ohrenkino
post Feb 24 2017, 17:57
Post #9
Member
Group: Full Members
You only have V1 and V2 fields in the files. That is good.
You have several user-defined fields in the file
TXXX/COVERART which is shown as COVERART in MP3tag extended tags
TXXX/COVERARTMIME which is shown as COVERARTMIMETYPE in MP3tag extended tags
These fields have nothing to do with embedded covers and their mime type.
Additionally you have a cover APIC with the size 2034250 and the status cover. This represents the actually embedded picture.
The user-defined fields do not get deleted if you remove the cover - which is perfectly possible with MP3tag. Also, these fields do not get updated as they have nothing to do with the embedded picture.
So: whatever software wrote these 2 fields I don't know but I would say that they are absolutely superfluous. You can delete them.
To sum it up: I can see no bug for MP3tag.
This post has been edited by ohrenkino: Feb 24 2017, 17:59
+Quote Post
0 Members:
RSS Lo-Fi Version Time is now: 18th December 2017 - 00:24
