IPB
> Web Sources if findline doesn't find anything, is there a way to allow the script to continue running
pints1ze
post Nov 3 2017, 20:04
Post #1
Member
Group: Members
Mp3tag Version: 2.84a
I'm writing a web source script, but in some cases the page I'm searching doesn't contain the data I'm looking for. When this happens the script fails and none of the other pieces of data populate, even though they ARE on the page I'm scraping.
If looked at If, IfNot, IfOutput, IfNotOutput, but they don't seem to fit my use.
Is there a way around this problem?
Go to the top of the page
+Quote Post
Fatduckz
post Jan 11 2018, 02:15
Post #2
Member
Group: Members
Mp3tag Version: 2.81
QUOTE (pints1ze @ Nov 4 2017, 05:04) *
I've been having the same problem for a couple of weeks but just stumbled across the answer. Add a 3rd parameter to the findline command. eg
findline "certificates=ZZ" 1 fails with an error if certificates=ZZ is not found, but
findline "certificates=ZZ" 1 1 allows the script to continue
hope this helps
+Quote Post
pints1ze
post Jan 12 2018, 02:21
Post #3
Member
Group: Members
QUOTE (Fatduckz @ Jan 10 2018, 17:15) *
hope this helps
Thank you! I will have to try that out.
+Quote Post
0 Members:
RSS Lo-Fi Version Time is now: 16th January 2018 - 22:23
