IPB
2 Pages V   1 2 >
> MP3 tagged podcasts Itunes Display, MP3's tagged as podcasts after importing into Itunes
Jimmy Bob
post Sep 26 2017, 11:41
Post #1
Member
Group: Full Members
Mp3tag Version: 2.66
I download audio MP3's tagged from the internet (talk show). I used MP3TAG to change to podcast type, author, title, and picture. After importing into Itunes, they initially display correctly, but later change to Uploads by YouTube Help. The underlying files are still named the same and the tags have not been altered but they are displayed in Itunes incorrectly. Is there anything I can do to the files to prevent this? I've reported to Apple but it is like dropping your feedback into a black hole never to be heard from again.
Go to the top of the page
+Quote Post
ohrenkino
post Sep 26 2017, 12:13
Post #2
Member
Group: Full Members
Mp3tag Version: 2.85k
see the help for possible fields, e.g. PODCAST (whether it is there with value 1)
http://help.mp3tag.de/main_tags.html#PCST
Also, MEDIATYPE could be a field to influence the section where a track appears in iTunes.
If you can't see the tag fields in the file list, use the extended tags dialogue (Alt-T).
+Quote Post
Jimmy Bob
post Sep 26 2017, 12:34
Post #3
Member
Group: Full Members
I already have PODCAST set to 1. I see MEDIATYPE and ITUNESMEDIATYPE neither of which I am setting. What would I set either or both of them to?
+Quote Post
ohrenkino
post Sep 26 2017, 12:51
Post #4
Member
Group: Full Members
QUOTE (Jimmy Bob @ Sep 26 2017, 13:34) *
I do not think that anything besides PODCAST has to be set.
Do you have a problem with the iTunes database?
Then either you have script to update the database or you delete the files from the database (only) and add them again (File menu).
I know that iTunes e.g. never updates a compilation once it has detected the COMPILATION field no matter if it still exists or not.
+Quote Post
Jimmy Bob
post Sep 26 2017, 13:06
Post #5
Member
Group: Full Members
QUOTE (ohrenkino @ Sep 26 2017, 06:51) *
Once again, they initially show up as correct in ITunes. It is either after a device is sync'd and/or ITunes program is closed and reopened. That is when I see the the change to "Uploads by YouTube Help". Subsequent syncs to device also changes the title on the device too. How would I edit the database?
Attached thumbnail(s)
+Quote Post
ohrenkino
post Sep 26 2017, 19:04
Post #6
Member
Group: Full Members
Perhaps it is easier if you rename the files.
+Quote Post
Jimmy Bob
post Sep 26 2017, 19:06
Post #7
Member
Group: Full Members
QUOTE (ohrenkino @ Sep 26 2017, 13:04) *
What are you talking about? It has nothing to do with names of files.
+Quote Post
ohrenkino
post Sep 26 2017, 19:27
Post #8
Member
Group: Full Members
QUOTE (Jimmy Bob @ Sep 26 2017, 20:06) *
It could well be that I do not understand what your problem is.
This is what I have understood so far:
You have some files and they feature the field PODCAST. None of the fields for MEDIATYPE or ITUNESMEDIATYPE are filled.
You add the files to iTunes and first they appear where you want them and then they appear somewhere else where you don't want them in iTunes and the iTunes support is a black hole.
As I do not know what you do exactly and whether that what you tell us is that what you actually do, I can only follow a more general approach:
If iTunes has to treat the files as any ordinary audio file plus the tag field PODCAST but it treats them in a different way than expected, then every reference to former data should be removed. This looked like the filename to me as you say
QUOTE
The underlying files are still named the same ...
But it could still be that I did not get at all what the problem could be.
+Quote Post
Jimmy Bob
post Sep 26 2017, 22:29
Post #9
Member
Group: Full Members
QUOTE (ohrenkino @ Sep 26 2017, 13:27) *
Did you read the initial report and look at the screen capture?
+Quote Post
Florian
post Sep 27 2017, 06:58
Post #10
Developer
Group: Admin
Hi Jimmy,
can you check via the extended tag dialog whether those files have any other identifying fields set — PODCASTID, PODCASTDESC, and so on.
Maybe there are some leftovers which are then picked up by iTunes.
Kind regards
– Florian
+Quote Post
Jimmy Bob
post Sep 27 2017, 13:03
Post #11
Member
Group: Full Members
QUOTE (Florian @ Sep 27 2017, 00:58) *
Hi Jimmy,
Kind regards
– Florian
I guess I'm looking for something better than maybe and might. I got plenty of that from Apple (crappy) Support.
I am setting ALBUM, ARTIST, ALBUMARTIST, GENRE, PODCAST, POSTCASTCATEGORY, PODCASTDESC, PODCASTURL, RELEASETIME, TITLE, YEAR
+Quote Post
Florian
post Sep 27 2017, 14:47
Post #12
Developer
Group: Admin
QUOTE (Jimmy Bob @ Sep 27 2017, 14:03) *
It's the human dilemma.
You could start with showing more details smile.gif That can be a screenshot of the extended tag dialog or, even more helpful, an option to download the file in questions for analyzing purposes.
Without more information you'd only get others guessing at what might be causing the issue.
+Quote Post
Jimmy Bob
post Sep 27 2017, 15:10
Post #13
Member
Group: Full Members
QUOTE (Florian @ Sep 27 2017, 08:47) *
I'm not convinced this is a TAG issue.. was hunting if anyone else experienced this.
+Quote Post
Florian
post Sep 27 2017, 15:13
Post #14
Developer
Group: Admin
QUOTE (Jimmy Bob @ Sep 27 2017, 16:10) *
OK, I'm moving this thread to Off-Topic then.
+Quote Post
Jimmy Bob
post Sep 28 2017, 00:19
Post #15
Member
Group: Full Members
QUOTE (Florian @ Sep 27 2017, 09:13) *
thanks
+Quote Post
2 Pages V   1 2 >
0 Members:
RSS Lo-Fi Version Time is now: 18th January 2018 - 14:22
