IPB
> Notice!
Abbreviations: (will be specified by moderators/administrators)
> [F] Sending multiple files from foobar to Mp3tag does not send them all
incifinci
post Jul 7 2016, 19:05
Post #1
Member
Group: Full Members
Mp3tag Version: 2.85k
I saw this behavior in last (3? 6?) month. Win7x64hun, Mp3tag allways the last (beta too), foobar allways the last (beta too). Earlier (through years) scripts worked without problem.
When I send multiple files from foobar2000 (using Run services) to Mp3tag, not all files "landing" in Mp3tag's list, only some (sometime only 1) of them. Repeating 3-6 (!) times the operation in foobar usually resolves the problem.
Sending files from Total Commander I never saw such behavior. I think, it is associated with foo_run (and it is Florian's brilliant work, too - thanks for it!) or with foobar itself.
2 scripts in Run services are:
"C:\Program Files '('x86')'\Mp3tag\Mp3tag.exe" "$substr(%_path%,0,$strrchr(%_path%,'\'))"
and
"C:\Program Files '('x86')'\Mp3tag\Mp3tag.exe" "$left($directory_path(%_path%),$sub($len($directory_path(%_path%)),$len($directory(%_path%))))"
Using the second script (sending folders) the bug seems much less often, not all times. Using the first script (sending files) seems in 95% of cases.
Go to the top of the page
+Quote Post
Zerow
post Jul 25 2016, 22:48
Post #2
Member
Group: Full Members
Mp3tag Version: 2.86
It seems you have similar problems to those of mine of Mp3tag and Free Commander "send to" options
http://forum.audacityteam.org/viewtopic.php?p=309863
http://forum.freecommander.com/viewtopic.php?f=18&t=7106
They most likely have little in common with your issue, but maybe reading those will guide you toward if not explanation then at least a workaround
This post has been edited by zerow: Sep 7 2016, 22:23
+Quote Post
incifinci
post Jul 27 2016, 10:15
Post #3
Member
Group: Full Members
Zerow, thank you for your reply. I read them - but still my workaround left the click-click-clik... smile.gif Or, drag and drop.
+Quote Post
incifinci
post Jul 27 2016, 10:26
Post #4
Member
Group: Full Members
But I see, in my first comment I did an error. Those 2 scripts are not for sending files, or sending folders, but for folders and parent folders. The right ones:
1. Send file(s)
"C:\Program Files '('x86')'\Mp3tag\Mp3tag.exe" "%_path%"
2. Send directory(s)
This post has been edited by incifinci: Jul 27 2016, 10:32
+Quote Post
Zerow
post Sep 8 2016, 10:21
Post #5
Member
Group: Full Members
So did you managed to get rid of the bug?
Or that your solution only work a certain percent of the time?
I've managed to overcome my problem with sending files from FreeCommander to Spek and Spectro [http://forum.freecommander.com/viewtopic.php?p=24094#p24094] but I completely forgot, that I also have a problem when sending files from FreeCommander to Mp3tag [http://forum.freecommander.com/viewtopic.php?f=18&t=7106]
One file is not a problem. But when selecting multiple files for sending, not all of them are loaded to Mp3tag; and that bug doesn't seem to follow a pattern
[I've recently tried different settings if FreeCommander, even more than why I dealt with the Spek and Spectro issue, but It didn't helped]
This post has been edited by Zerow: Sep 23 2017, 14:59
+Quote Post
incifinci
post Sep 8 2016, 15:11
Post #6
Member
Group: Full Members
QUOTE (zerow @ Sep 8 2016, 11:21) *
No, I could not.
My "solution" (click-click-click...) in fact, not a real solution; so much the more, in case of ~10< files does not work.
+Quote Post
incifinci
post Dec 9 2017, 08:36
Post #7
Member
Group: Full Members
Little later: not every time sad.gif -- but in most cases (nearly 99%). Big difference! biggrin.gif
This post has been edited by incifinci: Dec 18 2017, 22:22
+Quote Post
MyAlteredEgo
post Dec 10 2017, 20:51
Post #8
Member
Group: Full Members
QUOTE (incifinci @ Dec 9 2017, 09:36) *
Little later: not every time sad.gif -- but in most cases. Big difference! biggrin.gif
Just out of curiosity, I was reviewing posts and came across something that may be useful to both of you or may not be...you decided but here it is...
https://forums.mp3tag.de/index.php?s=&s...ost&p=69011
+Quote Post
Zerow
post Jan 2 2018, 14:55
Post #9
Member
Group: Full Members
QUOTE (MyAlteredEgo @ Dec 10 2017, 20:51) *
Hmmm
I could switch to Total Commander; or point out the makers of FreeCommander to this TC solution, in hopes of them utilizing it somehow
Thak you
+Quote Post
incifinci
post Jan 2 2018, 15:19
Post #10
Member
Group: Full Members
QUOTE (incifinci @ Dec 9 2017, 08:36) *
Since then, I have not noticed the error. 99% seems to be 100%, so, Florian, in my opinion the original bug (foobar>>Mp3tag) now is fixed ([F]). And thank you for the correction.
+Quote Post
0 Members:
RSS Lo-Fi Version Time is now: 18th January 2018 - 06:35
