IPB
> [X] Date tag saved as a year tag
Spider099
post Mar 20 2017, 19:45
Post #1
Member
Group: Full Members
Mp3tag Version: 2.84c
Using 2.81a
Trying to add a date to a MP4 video file and when i save the file and check the tags its been saved as a Year tag as the file now has two year tags.
This is consistent across different machines and installs of MP3Tag
Go to the top of the page
+Quote Post
ohrenkino
post Mar 20 2017, 21:16
Post #2
Member
Group: Full Members
Mp3tag Version: 2.85
ZITAT(Spider099 @ Mar 20 2017, 19:45) *
Using 2.81a
2 things:
Merging YEAR and DATE has happened here:
[2013-10-06] CHG: reverted change: ID3v2.3 TYER/TDAT now merged into one YEAR field formatted as YYYY-MM-DD (due to popular request).
(see the changelog for that: http://www.mp3tag.de/en/changelog.html)
And also see the supported fields: http://help.mp3tag.de/main_tags.html
If you want to save an accurate data, use RELEASETIME
(where there is no DATE field).
This post has been edited by ohrenkino: Mar 20 2017, 21:16
+Quote Post
Spider099
post Mar 21 2017, 16:31
Post #3
Member
Group: Full Members
so why would i get two YEAR fields in the MP4 file?
and if the date field is not "supported" why is it shown?
thanks for the info
+Quote Post
DetlevD
post Mar 21 2017, 17:38
Post #4
Member
Group: Full Members
QUOTE (Spider099 @ Mar 20 2017, 19:45) *
... Trying to add a date to a MP4 video file and when i save the file and check the tags its been saved as a Year tag as the file now has two year tags. ...
You have to do some investigations.
1.
Make sure that there is one column defined in Mp3tag column view:
Name : TagRead (TagTypes)
Value: %_tag_read%[' ('%_tag%')']
Regarding MP4 file, this column should display the text 'MP4 (MP4)'.
2.
Read about "user defined mappings" in "Mp3tag help manual/options/tags/mapping",
and check, ...
if there is an additional mapping defined, ...
within the Mp3tag dialog "Options/Tags/Mapping", ...
which affects the tagfield YEAR.
Note: In "Extended Tags ..." view there is no problem to add multiple YEAR tagfields into the MP4 tag, just by adding so much tagfields with the name YEAR as you want.
Also there is the possibility to create multiple YEAR tagfields, when entering a string of e. g. '2015\\2016\\2017\\2017\\2017', which will create five tagfields with the name YEAR.
Because of the internal mapping from DATE to YEAR any newly added tagfield DATE will be mapped and added to the multiple YEAR taglist.
You can avoid this behaviour by using the action "Format value" or the Converter "Tag-Tag":
Field: YEAR
Formatstring: '2017\\'
This will create one single value tagfield.
DD.20170321.1851.CET
This post has been edited by DetlevD: Mar 21 2017, 18:51
+Quote Post
Florian
post Apr 12 2017, 08:33
Post #5
Developer
Group: Admin
Mp3tag Version: 2.85a
QUOTE (Spider099 @ Mar 21 2017, 17:31) *
If you enter DATE, it currently automatically gets remapped to YEAR for MP4 (which is then internally an ©day MP4 atom). So if you write YEAR and DATE, you'll end up with two YEAR fields.
That's a really good question – I'll remove it from the list.
Kind regards
– Florian
+Quote Post
0 Members:
RSS Lo-Fi Version Time is now: 24th November 2017 - 12:17
