IPB
> [X] MP3Tag Not reading all mp3 files
TranceDaddy
post Apr 23 2017, 21:40
Post #1
Member
Group: Members
Mp3tag Version: 2.81C
While trying to import 17 mp3 files via from Foobar2000 or from the directories mp3tag will only display 3 out of the 17 files. I have check to confirm it is not due to long file/folder names. I have also tried to fix VBR Header and rebuild mp3 but the issue is the same
Thanks
TD
Attached thumbnail(s)
Go to the top of the page
+Quote Post
LyricsLover
post Apr 23 2017, 22:22
Post #2
Member
Group: Full Members
Mp3tag Version: 2.83e
If you let me download one of your not listed songs, I could check it if this happens on another windows version and environment.
You can write the DL link in a PM or if you don't mind make it public here (usable for others too).
+Quote Post
ohrenkino
post Apr 24 2017, 06:00
Post #3
Member
Group: Full Members
You could check how many files get loaded when you look at the status bar (unfortunately, this is not quite visible in the screendump): this tells you how many files are loaded and how many are displayed. It could then be that you have set (unvoluntarily) a filter.
+Quote Post
TranceDaddy
post Apr 25 2017, 04:43
Post #4
Member
Group: Members
QUOTE (LyricsLover @ Apr 23 2017, 17:22) *
Send me your email in a PM and I will WeTransfer them to you give you a couple that work and dont
+Quote Post
TranceDaddy
post Apr 25 2017, 04:50
Post #5
Member
Group: Members
QUOTE (ohrenkino @ Apr 24 2017, 01:00) *
Well don't I feel like an arse dry.gif , found out that my filter was on from my last search enhance why it was only showing the 3 was filtered for feat
+Quote Post
0 Members:
RSS Lo-Fi Version Time is now: 28th July 2017 - 03:51
