IPB
2 Pages V   1 2 >
> GetMp3tagFormatStrings, Extract format strings and save them to text file.
DetlevD
post Mar 12 2010, 21:26
Post #1
Member
Group: Full Members
Mp3tag Version: 2.85
I have created a simple tool - nothing fancy - just a quick release of an idea - maybe a one shot.
This "Mp3tagGetFormatStrings" tool extracts user created format strings out of Mp3tag filter- and convert-dialogs and saves them to a text file.
This tool is freeware without any warranty. Tested with Mp3tag v2.45d on Windows XP SP3. Use at your own risk.
Installation instructions:
Make sure to install the "Mp3tag" application made by Florian Heidenreich before running this tool.
This tool "Mp3tagGetFormatStrings.exe" expects that the "Mp3tag" application is properly installed and that there exist a user related "%AppData%\Mp3tag\data" folder.
Put this "Mp3tagGetFormatStrings.exe" file into a new folder with a name of your will and run it.
When "Mp3tagGetFormatStrings.exe" file runs the first time, it extracts two helper runtime module files (*.dll) from its own - this is normal and has no risk.
The user will be asked by dialog to search for the installation location of "Mp3tag.exe".
For later usage, the "Mp3tag.exe" install path will be stored into a ini text file, which is stored in the same folder where this tool is located.
The resulting text file, which contains the format strings, will be stored in the user related "%AppData%\Mp3tag\data" folder.
At end, an Explorer window will pop up in this folder.
And please take into account and keep in mind, that Mp3tagGetFormatStrings is a GUI control program, that means:
While Mp3tagGetFormatStrings is running: !!! Hands off from keybord and mouse. !!!
Enjoy!
DD.20100312.2127.CET
Version 1.03 is available.
Note:
There is still a quirk in the moment, when Mp3tag is launched by Mp3tagGetFormatStrings and Mp3tag just receives it's update info message from the Internet.
The upcoming update dialog cannot be handled at this time.
Appropriate workaround is: close Mp3tag and close Mp3tagGetFormatStrings, process the Mp3tag update, then start Mp3tagGetFormatStrings again.
DD.20100314.1830.CET
Edit.DD.20111210.0854.CET
Mp3tagGetFormatStrings Version 1.04 is available.
Added support for converter "Tag - Tag", new in Mp3tag v2.50.
DD.20120504.1830.CEST
Mp3tagGetFormatStrings Version 1.06 is available.
Should support Mp3tag v2.51 .. v2.54 .. 2.69a
DD.20130123.1800.CET, DD.20150330.1917.CEST
Download Mp3tagGetFormatStrings
This post has been edited by DetlevD: Mar 30 2015, 18:17
Go to the top of the page
+Quote Post
eichenwurm
post Mar 12 2010, 22:22
Post #2
Member
Group: Full Members
Mp3tag Version: 2.70
Hallo DetlevD,
vielen Dank für Deine erachtlichen Beiträge. Es ist für mich immer lobenswert auf die Hilfe von Dir zurückzugreifen.
Leider sind viele Beiträge in englischer Sprache, so auch dieses.
Mein Englisch ist nicht sehr gut und ich nuß zumeist auf viele Beiträge verzichten, da mein Browser bei den speziellen Fachausdrücken kapituliert.
Es wäre lobenswert, diese Beschreibung von GetMp3tagFormatStrings auch in deutscher Sprache, hier in das Forum zu bringen.
Vielen Dank für Deine Arbeit hier im Forum.
mfg
unsure.gif Habe das Programm heruntergeladen und versucht zu Installieren (Win XP Sp3) und Mp3tag 2.45d)
Habe folgende Fehlermeldung!
Versuche den Screenshot mitzusenden, funktionierte beim letzten mal leider nicht.
Vielleicht, ist ja etwas damit anzufangen.
This post has been edited by eichenwurm: Mar 12 2010, 22:49
Attached thumbnail(s)
eifersucht ist die leidenschaft die mit eifer sucht was leiden schafft.
+Quote Post
DetlevD
post Mar 13 2010, 07:07
Post #3
Member
Group: Full Members
QUOTE (eichenwurm @ Mar 12 2010, 22:22) *
Hallo DetlevD, vielen Dank für Deine erachtlichen Beiträge. Es ist für mich immer lobenswert auf die Hilfe von Dir zurückzugreifen. ...
eichenwurm, vielen Dank für dein Lob.
... Leider sind viele Beiträge in englischer Sprache, so auch dieses....
Ja, hier ist der internationale Forensektor in englischer Sprache.
Ausnahmsweise antworte ich in deutscher Sprache.
... unsure.gif Habe das Programm heruntergeladen und versucht zu Installieren (Win XP Sp3) und Mp3tag 2.45d)
Habe folgende Fehlermeldung! ...
Die Fehlermeldung zeigt an, dass das Tool GetMp3tagFormatStrings von einem neu gestarteten Mp3tag.exe Prozess keine gültige "Processnummer" und demzufolge keine gültige "Fensternummer" zurückerhalten hat.
Ich frage mich: warum dieser Fehler?
Vielleicht laufen zwei Mp3tag.exe Prozesse gleichzeitig, aber wieso?
Gibt es vielleicht noch einen Mp3tag.exe Prozess (z. B. noch sichtbar in der Prozessliste im Taskmanager), der voher "abgestürzt" war (oder mehrere)?
Bitte prüfe das bei deiner Maschine.
Tritt dieser Fehler auch nach einem Neustart deiner Maschine auf, ohne Mp3tag jemals selbst oder automatisch gestartet zu haben?
DD.20100313.0707.CET
+Quote Post
DetlevD
post Mar 13 2010, 11:49
Post #4
Member
Group: Full Members
GetMp3tagFormatStrings.v101.exe is avaliable:
http://cid-387b58366897ac93.skydrive.live....trings.v101.exe
DD.20100313.1150.CET
Edit. DD.20111210.0830.CET
This post has been edited by DetlevD: Dec 10 2011, 08:30
+Quote Post
eichenwurm
post Mar 13 2010, 16:57
Post #5
Member
Group: Full Members
Hallo DetlevD,
danke für die Arbeit! Habe das mit dem Taskmanager überprüft, es wurde kin 2. Task in den Prozessen angezeigt.
Auch ein Neustart zeigte mir das gleiche Problem.
Habe jetzt die letzte Vers. installiert, allerdings ohne Mp3tag zu deinstallieren.
Anbei der Screenshot und der Error.log
mfg
Attached File(s)
Attached File  GetMp3tagFmtStr.LastError.txt ( 499bytes ) Number of downloads: 391
+Quote Post
DetlevD
post Mar 13 2010, 17:42
Post #6
Member
Group: Full Members
QUOTE (eichenwurm @ Mar 13 2010, 16:57) *
... Habe jetzt die letzte Vers. installiert, allerdings ohne Mp3tag zu deinstallieren. ...
Hoho, wer hat denn etwas von Mp3tag De-Installation gesagt?!?!?
Die Voraussetzung zur Benutzung von "GetMp3tagFormatStrings.exe" ist, dass Mp3tag korrekt installiert ist.
Danke für den Error Report, werde ich mir 'mal genauer anschauen.
In der Zwischenzeit kannst du eine leicht modifizierte Version 1.01c herunterladen, und mir den damit erzeugten Error Report zusenden an, dann direkt an:
xxxxxxxxxxxxxxxxxxxxxx@xxxxxxx.
In der Zwischenzeit habe ich das Progrämmle auf anderen XP Maschinen laufen lassen, ohne Probleme.
Es wird sich in deinem Fall vermutlich um eine etwas ganz besonders ungewöhnliche Konstellation von Maschine und Benutzer ;-) handeln.
Gruß
Detlev
DD.20100313.1741.CET
Email Link removed.
DD.20140302.1205.CET
This post has been edited by DetlevD: Mar 2 2014, 12:06
+Quote Post
eichenwurm
post Mar 13 2010, 18:31
Post #7
Member
Group: Full Members
Hallo DetlevD,
ich schrieb doch, letzte Installation von deinem kleinen Progrämmchen "GetMp3tagFormatStrings.v101" habe ich heruntergeladen und installiert. Natürlich weis ich, dass ich mp3tag nicht deinstalliert werden muß, sonst konnte eine Installation gar nicht erfolgen.
Es wird ja der Programm-Ordner bei der Installation abgefragt.
mfG
eichenwurm
P.S. Der letzte Fehlerreport war mit der Vers. 101c
This post has been edited by eichenwurm: Mar 13 2010, 18:36
+Quote Post
DetlevD
post Mar 13 2010, 20:19
Post #8
Member
Group: Full Members
Version 1.02 is available:
http://bzqyjq.bay.livefilestore.com/y1pxFy...trings.v102.exe
DD.20100313.2018.CET
Edit.DD.20111210.0832.CET
This post has been edited by DetlevD: Dec 10 2011, 08:32
+Quote Post
Sebastian Mares
post Mar 13 2010, 20:42
Post #9
Moderator
Group: Full Members
Mp3tag Version: 2.73
Version 1.02, Mp3tag 2.45d and Windows 7:
QUOTE
[2010:03:13:20:41:32| 120410900]
WbErrLastError=204
WbErrLine=window2 = cWndbyid (intHwndMain, 59422)
WbErrOffset=3913
WbErrAssignment=window2
WbErrFile=20100310.GetMp3tagFormatStrings
WbErrTextString=204: Specified parent window doesn't exist
WbErrAdditionalInfo=
WbErrInSegment=
WbErrLineNumber=143
WbErrUdfLineNumber=0
WbErrAccurateLineNumber=1
WbErrUdfReturnValue=0
WbErrTickCount=120410900
WbErrYmdHms=2010:03:13:20:41:32
VersionGMFS=1.02
VersionMp3tag=v2.45d
There are 10 types of people in this world: those who understand binary, and those who don't.
+Quote Post
eichenwurm
post Mar 13 2010, 21:01
Post #10
Member
Group: Full Members
Danke!
Version 1.02 funktioniert super.
Es ist immer wieder erstaunlich, was aus diesem mp3tag Programm alles machbar ist!
Es macht mir immer mehr Spass.
Liebe Grüsse
eichenwurm
+Quote Post
foo_peter
post Mar 14 2010, 01:53
Post #11
Member
Group: Full Members
Mp3tag Version: 2.57
QUOTE
Hallo DetlevD,
da schließe ich mich doch glatt an mit dem zusatz ein Glück für uns User solche Leute onBoard zu haben.
Das Tool läuft 1a auch mit MP3TAG 2.46 !
mach einen Dummen nicht schlau du bekommst ihn nie wieder dumm
+Quote Post
DetlevD
post Mar 14 2010, 18:39
Post #12
Member
Group: Full Members
QUOTE (Sebastian Mares @ Mar 13 2010, 20:42) *
Sebastian, thank you for the report.
The crux is, that I have no W7 machine at hand.
GetMp3tagFormatStrings might have timing problems on rather slow or too fast machines,
The error report, you've send me, shows that Mp3tag has been already started, but the "Filter" dialog window was not loaded at the time the error occurred.
The only thing I can do is to give Mp3tag a few more seconds to establish itself.
I've just released GMFS v1.03.
Please try itnout and give feedback by forum private mail or standard email.
Regards.
Detlev
DD.20100314.1840.CET
+Quote Post
DetlevD
post Mar 14 2010, 18:40
Post #13
Member
Group: Full Members
GetMp3tagFormatStrings Version 1.03 is available:
Download link see post #1 in this thread
http://forums.mp3tag.de/index.php?showtopi...ost&p=45353
Edit.DD.20111210.0838.CET
This post has been edited by DetlevD: May 27 2012, 11:41
+Quote Post
Sebastian Mares
post Mar 21 2010, 22:02
Post #14
Moderator
Group: Full Members
Works fine with 2.46a under Windows 7.
+Quote Post
DetlevD
post Mar 23 2010, 18:14
Post #15
Member
Group: Full Members
QUOTE (Sebastian Mares @ Mar 21 2010, 22:02) *
Sebastian, thank you for testing and feedback!
DD.20100223.1814.CET
+Quote Post
2 Pages V   1 2 >
0 Members:
RSS Lo-Fi Version Time is now: 23rd January 2018 - 05:10
