IPB
> Problem with stripping text
Mike_nl
post Aug 17 2016, 12:22
Post #1
Member
Group: Full Members
Mp3tag Version: 2.83f
I am writing a program in VB.NET (Personal Project) and need your guys help with Regex (or another solution), I have been thinking for a solution for days but I can't solve it.
A line which can looks like this (and maybe more)
QUOTE
"ABCDEFGHIJK ~ AB Ab Cdefgh"
"ABCDEFGHIJK AB Abcdefhijklmnopq"
"ABCDEF-GHIJKLMNO Abcdefgh"
"AB.CDEFGHIJKL Mnop"
"ABCD/EFGHIJ A abcdef"
"ABCD EFGH I Abcd efgh
"ABCD-EFGHIJ A abcdef"
"AB.CDEFGHIJ A abcdef"
"ABC-DEFGHIJ a Abcdef"
But I only want the 1st Part so
QUOTE
ABCDEFGHIJK
ABCDEFGHIJK
ABCDEF-GHIJKLMNO
AB.CDEFGHIJKL
ABCD/EFGHIJ
ABCD EFGH
ABCD-EFGHIJ
AB.CDEFGHIJ
ABC-DEFGHIJ
The only common standard about the format is that the text I want starts after a " chr(34) but after that there are (unfortunately) No more common identifiers (only that text I want is in ALL CAPS [A-Z] wink.gif
I can't seem to find a solution to this problem, the text file formatting is just to messed up and to do it manually would take me days and days (60.000 Lines)
This post has been edited by Mike_nl: Aug 17 2016, 14:38
Have fun while it lasts ;)
Go to the top of the page
+Quote Post
ohrenkino
post Aug 18 2016, 06:27
Post #2
Member
Group: Full Members
Mp3tag Version: 2.85k
QUOTE (Mike_nl @ Aug 17 2016, 13:22) *
... No more common identifiers...
In the examples, IMHO the blank is the common separator.
So
$regexp('ABCDEFGHIJK ~ AB Ab Cdefgh"',(.*?) .*,$1)
returns
ABCDEFGHIJK
+Quote Post
Mike_nl
post Aug 18 2016, 07:37
Post #3
Member
Group: Full Members
Thanks for the Reply
But 1 thing.
That would fail if the text has a space in between. For example.
As I would like to get as Result ABCD EFGH
And the regex would only return ABCD
Edit: I came up with this (please don't laugh as I am ABSOLUTELY not a REGEX guy wink.gif )
[A-Z]*(\s)?(-)?(/)?[A-Z]*
But that already fails if the text has Ü (Umlaut) in it wink.gif or will with the text (as it grabs tooo Much)
ABCD EFGH I (and I only want ABCD EFGH)
This post has been edited by Mike_nl: Aug 18 2016, 07:51
+Quote Post
ohrenkino
post Aug 18 2016, 08:08
Post #4
Member
Group: Full Members
QUOTE (Mike_nl @ Aug 18 2016, 08:37) *
But 1 thing.
That would fail if the text has a space in between. ...
That is true, but in your example none of the result examples has a string in it with a blank ... so I can only be as good as the example is.
Perhaps you have to go through the list twice:
first cut all the bits in lower case, then deal with ones in mixed case.
This regexp will leave over anything that starts with capitals:
$regexp('ABCD EFÜGH I Abcd efgh',(?-i)(\u.*) .*,$1)
and this one
$regexp('ABCD EFÜGH I Abcd efgh',(?-i)(\u.*) \u\l.*,$1)
chucks off all strings that start with a captital and continue with a lower case.
+Quote Post
Mike_nl
post Aug 18 2016, 08:12
Post #5
Member
Group: Full Members
QUOTE (ohrenkino @ Aug 18 2016, 14:08) *
<snip>
Are you sure wink.gif ???
Example line Nr 6
QUOTE
And I want as result
QUOTE
ABCD EFGH
Thanks again, will try those Regexes. Great help !!
Good one about stripping first the lower cases and then the mixed cases !!
Edit: I most certainly could do it manually, but this list changes sometimes once a week or sometimes twice and then a long while it doesn't change, so Id rather do it "semi auto"
This post has been edited by Mike_nl: Aug 18 2016, 08:15
+Quote Post
ohrenkino
post Aug 18 2016, 08:15
Post #6
Member
Group: Full Members
QUOTE (Mike_nl @ Aug 18 2016, 09:12) *
Not any more ...
+Quote Post
0 Members:
RSS Lo-Fi Version Time is now: 23rd January 2018 - 05:10
