IPB
> Notice!
> What Happened (Moreover) where's my Tag Info?
Beluna
post Apr 20 2017, 00:44
Post #1
Member
Group: Full Members
Mp3tag Version: 2.45b
I have several albums (Folders) where the meta data no longer showing or hidden in MP3 Tag Editor. The information is still embeded in the files, but will not show in the Editor.
There seems to be no logic as to which folders are impacted. Not sure how long this has been going on.
See samples attached.
Sample 1.. shows meta data in MP3 Tag Editor
Another folder shows only the file name... all data is invisible / hidden
However, the data is still visible in a Media Info Viwer.
Any ideas
This post has been edited by Beluna: Apr 20 2017, 05:37
Go to the top of the page
+Quote Post
DetlevD
post Apr 20 2017, 06:59
Post #2
Member
Group: Full Members
Mp3tag Version: 2.85
QUOTE (Beluna @ Apr 20 2017, 01:44) *
I have several albums (Folders) where the meta data no longer showing or hidden in MP3 Tag Editor. The information is still embeded in the files, but will not show in the Editor. ...
Please show us which tag types are present in the file.
Which tag type is currently read with Mp3tag?
Which tag-type is currently written with Mp3tag?
DD.20170420.0758.CEST
+Quote Post
Beluna
post Apr 20 2017, 20:20
Post #3
Member
Group: Full Members
QUOTE (DetlevD @ Apr 20 2017, 07:59) *
I think i found the issue. A[[arently in previous formating I was reading/ writing APE.... those were the files i could not see... So far the issue has been resolved for the few files I've found.
Thanks
+Quote Post
theocoog
post May 10 2017, 13:57
Post #4
Member
Group: Members
Mp3tag Version: 2.82
Deleted - Had the same problem but found the solution.
This post has been edited by theocoog: May 10 2017, 13:58
Attached thumbnail(s)
+Quote Post
ohrenkino
post May 10 2017, 13:59
Post #5
Member
Group: Full Members
ZITAT(theocoog @ May 10 2017, 14:57) *
I am having the same problem. ...
If you have the same problem then it should be easy to apply the same solution.
So: what are the settings as DetlevD wrote in post #2?
What happens if you disable to read APE?
see e.g. here: https://forums.mp3tag.de/index.php?showtopic=5176
This post has been edited by ohrenkino: May 10 2017, 14:01
+Quote Post
0 Members:
RSS Lo-Fi Version Time is now: 21st November 2017 - 23:57
