IPB
> Notice!
3 Pages V  < 1 2 3 >
> Volumed (multiple part) Compilation Folder Creation, Creating folders for Compilations that have multiple numbered volumes
MyAlteredEgo
post May 6 2017, 15:02
Post #16
Member
Group: Full Members
Mp3tag Version: 2.80
QUOTE (DetlevD @ May 5 2017, 05:29) *
Try again ...
ALBUM       : Cold Hands Seduction Volume 182
Convert     : Tag-Tag
Field       : TEST
Formatstring: [$regexp(%album%,'^.* (Volume \d+).*$','$1')'\']%album%
Result      : Volume 182\Cold Hands Seduction Volume 182
See also ... http://forums.mp3tag.de/index.php?showtopic=20126
DD.20170505.0641.CEST
This works however the results are reversed:
looking for
Result      : Cold Hands Seduction (with Volume and Number removed)\ Volume 182
Go to the top of the page
+Quote Post
MyAlteredEgo
post May 6 2017, 15:53
Post #17
Member
Group: Full Members
QUOTE (MyAlteredEgo @ May 6 2017, 15:02) *
looking for
So I have been able to get the Folder tree desired result now just need to know how to remove the Volume 182 from the original folder?
+Quote Post
DetlevD
post May 6 2017, 18:51
Post #18
Member
Group: Full Members
Mp3tag Version: 2.84e
QUOTE (MyAlteredEgo @ May 6 2017, 16:02) *
... looking for Result: Cold Hands Seduction (with Volume and Number removed)\ Volume 182
Convert     : Tag-Tag
Field       : TEST
Formatstring: $regexp(%album%,'^(.+)\s(Volume\s\d+)$','$1\\$2')
Result      : Cold Hands Seduction\Volume 182
ALBUM       : Cold Hands Seduction 123
Convert     : Tag-Tag
Field       : TEST
Result      : Cold Hands Seduction 123
DD.20170506.1952.CEST
This post has been edited by DetlevD: May 6 2017, 18:52
+Quote Post
MyAlteredEgo
post May 6 2017, 20:38
Post #19
Member
Group: Full Members
QUOTE (DetlevD @ May 6 2017, 18:51) *
Convert     : Tag-Tag
Field       : TEST
Convert     : Tag-Tag
Field       : TEST
Thank you however I am not looking to compromise the Album title...what I am trying to adjust is the DIRECTORY STRUCTURE
end result being...
(folder) Cold Hands Seduction
(sub-folder) Volume #
(sub-folder(s) as required) Disc(s) and associated tracks
+Quote Post
ohrenkino
post May 6 2017, 22:27
Post #20
Member
Group: Full Members
Mp3tag Version: 2.84d
end result being...
That what DetlevD showed does not do anything to the field ALBUM but saves the result in a field called TEST.
Instead of using TEST as target, enter the field that you really want to modify.
+Quote Post
DetlevD
post May 7 2017, 08:49
Post #21
Member
Group: Full Members
QUOTE (MyAlteredEgo @ May 6 2017, 21:38) *
...what I am trying to adjust is the DIRECTORY STRUCTURE ...
You got an example how to do it on a test tagfield as a preview, by applying the converter dialog "Tag-Tag".
To make it permanent in the disk folder system, then instead of tagfield TEST do apply the pseudo-tagfield _DIRECTORY.
It is sufficient to select only one file in the folder, all other files in the folder are automatically moved as well.
DD.20170507.0952.CEST
This post has been edited by DetlevD: May 7 2017, 08:52
+Quote Post
MyAlteredEgo
post Jun 4 2017, 23:03
Post #22
Member
Group: Full Members
QUOTE (DetlevD @ May 7 2017, 08:49) *
So after some playing around with this I have been able to achieve the folder structure that I wanted. The example below is for Roman Numeral compilations hence the \D+ and achieves the desired result...
Format value "TITLESORT": [$regexp(%album%,'^.* (Part \D+).*$','$1')]
Format value "ALBUMSORT": $cutRight(%album%,$len(%titlesort%))
Format value "_FILENAME": F:\Backup Processing\%albumartist%\%albumsort%\%titlesort% %mediatype% %year%\%_filename_ext%
I receive an error if I try simply formating the existing "_DIRECTORY" so I use a "_FILENAME" command using a proper windows filepath and the formatted values. Only issue remains is that I am unable to get the cover art (folder/file) to move with it to the new directory. Now most of my files have the coverart embedded however there are other files such as insert images and back cover and disc photos in some of the files so I would like to have these files/folder go with it to the new directory. Any suggestions would be appreciated.
+Quote Post
DetlevD
post Jun 5 2017, 07:38
Post #23
Member
Group: Full Members
QUOTE (MyAlteredEgo @ Jun 5 2017, 00:03) *
... I have been able to achieve the folder structure that I wanted. ... I receive an error if I try simply formating the existing "_DIRECTORY" so I use a "_FILENAME" command using a proper windows filepath and the formatted values. Only issue remains is that I am unable to get the cover art (folder/file) to move with it to the new directory. ... I would like to have these files/folder go with it to the new directory. Any suggestions would be appreciated.
You can take and move all files in the directory folder, when you edit the pseudo tagfield _DIRECTORY.
Try to "format value" the pseudo tag field _DIRECTORY instead of the pseudo tag field _FILENAME.
This will cause a MOVE of the complete folder.
When you load the track files, respectively the parent folder, respectively the root folder, into Mp3tag, you should have a closer look to the fact where is the Mp3tag workfolder situated (should be read in Mp3tag window title).
In relation to this workfolder you can assemble a relative folderpath which points to the place where you want to create the new subfolder of your wish.
As an alternative way you can use an absolute path starting at the drive root, carrying the complete folderpath which points to the new folder.
See also ...
https://forums.mp3tag.de/index.php?showtopic=19805
https://forums.mp3tag.de/index.php?showtopi...ost&p=76784
DD.20170605.0838.CEST
+Quote Post
MyAlteredEgo
post Jun 9 2017, 02:46
Post #24
Member
Group: Full Members
QUOTE (DetlevD @ Jun 5 2017, 07:38) *
See also ...
So attempting use the _DIRECTORY suggestions above I have run into the following error which I am unable to resolve.
"Unable to create folder. They system can not find the path specified"
Yet if I use the _FILENAME version all works? Am stymied by this....
+Quote Post
ohrenkino
post Jun 9 2017, 06:01
Post #25
Member
Group: Full Members
This is an OS message, right?
So either you have not got the sufficient access rights or the total filename (with all the path components) is too long or you have illegal characters in it.
+Quote Post
DetlevD
post Jun 9 2017, 10:28
Post #26
Member
Group: Full Members
QUOTE (MyAlteredEgo @ Jun 9 2017, 03:46) *
So attempting use the _DIRECTORY suggestions above I have run into the following error which I am unable to resolve. "Unable to create folder. They system can not find the path specified" ...
Note: When formatting the pseudo tag-field _DIRECTORY, then only the target folder needs to defined, therefore apply a formatstring, which has no filename component.
DD.20170609.1128.CEST
+Quote Post
MyAlteredEgo
post Jun 9 2017, 13:16
Post #27
Member
Group: Full Members
QUOTE (DetlevD @ Jun 9 2017, 10:28) *
So this is what I have and I also tried replacing some of the variables with definative file paths with similar results...
%albumartist%\%albumsort%\%titlesort% %mediatype% %year%/
+Quote Post
DetlevD
post Jun 9 2017, 14:39
Post #28
Member
Group: Full Members
QUOTE (MyAlteredEgo @ Jun 9 2017, 14:16) *
Hmm, you offer a relative path, starting from which drive:\folder?
Format the pseudo-tagfield _DIRECTORY ...
try out a formatstring like the following, ...
replace 'drive:\path' with your environment, ...
make sure to have all parts filled with fitting text, ...
_DIRECTORY <== $validate('drive:\path\'%albumartist%'\'%albumsort%'\'$trim(%titlesort%' '%mediatype%' '%year%),'_')
DD.20170609.1539.CEST
This post has been edited by DetlevD: Jul 3 2017, 09:49
+Quote Post
MyAlteredEgo
post Jun 11 2017, 20:18
Post #29
Member
Group: Full Members
QUOTE (DetlevD @ Jun 9 2017, 15:39) *
Thank you this now works as I wanted. All assistance appreciated and thanka again.
+Quote Post
MyAlteredEgo
post Jul 2 2017, 15:46
Post #30
Member
Group: Full Members
QUOTE (MyAlteredEgo @ Jun 11 2017, 21:18) *
Have hit a snag with a variant I have been able to configure this script for "Festivals, Compilations,Volumes (numbered and Roman Numerals) however am stuck with one type....
The one that is causing me issue now is one that is an number followed by a " | " than a number?
For example File 13 | 3 now I can get it to create a folder similar to what I want but it removes the | 3 and cuts it down to File 13. Which would be fine if there isn't any other versions...but there could be a File 13 | 4 which than would create a file already exists error...?
Suggestions?
I have tried using [$regexp(%album%,'^.* (File \D+).*$','$1')] however this does nothing due to the number 1st and as indicated if I use the [$regexp(%album%,'^.* (File \d+).*$','$1')] it cut out the " | 3" which I would ultimately like to keep.
+Quote Post
3 Pages V  < 1 2 3 >
0 Members:
RSS Lo-Fi Version Time is now: 22nd October 2017 - 16:47
