IPB
2 Pages V   1 2 >
> [X] Windows "Snap" feature is not working with Mp3tag, you'd think it would but it's not
Solance
post Apr 27 2017, 07:18
Post #1
Member
Group: Full Members
Mp3tag Version: 2.81
When you drag window to the edge of the screen it should snap to it taking half of screen space, but with Mp3tag it does not work. wacko.gif
______________
Windows 7 / Mp3tag 2.81 & 2.81c
Go to the top of the page
+Quote Post
ohrenkino
post Apr 27 2017, 07:21
Post #2
Member
Group: Full Members
Mp3tag Version: 2.84a
______________
It works in Windows 8.1, though.
+Quote Post
Florian
post Apr 27 2017, 09:26
Post #3
Developer
Group: Admin
Hi Solace,
it also works here on my Windows 7 test system.
Kind regards
– Florian
+Quote Post
Solance
post Apr 28 2017, 07:32
Post #4
Member
Group: Full Members
QUOTE (Florian @ Apr 27 2017, 11:26) *
Hi Solace,
Kind regards
– Florian
that's strange, Win 7 all of the latests updates are installed..
here is video proof Firefox vs. Mp3tag - https://ufile.io/03tz3
+Quote Post
ohrenkino
post Apr 28 2017, 08:23
Post #5
Member
Group: Full Members
The snap function is set in the "Center for easier handling" (my crude translation)>Using the mouse>Managing Windows>Stop arranging windows.
So perhaps you have to untick that option.
(I also checked on a W7 system and a W10 OS - MP3tag snaps)
This post has been edited by ohrenkino: Apr 28 2017, 08:24
+Quote Post
Solance
post Apr 28 2017, 10:10
Post #6
Member
Group: Full Members
QUOTE (ohrenkino @ Apr 28 2017, 10:23) *
it was unchecked, so not applicable here.
I've tried all the apps I could - all of them do snap except Mp3tag, oh well I guess it is some weird special bug just for me smile.gif
This post has been edited by Solance: Apr 28 2017, 10:20
+Quote Post
ohrenkino
post Apr 28 2017, 10:20
Post #7
Member
Group: Full Members
ZITAT(Solance @ Apr 28 2017, 11:10) *
that's for disabling Snap feature completely. (it was unchecked)
(I have tried the snap feature on machines that are miles apart and I could not reproduce the behaviour that you observed... So I was really trying))
Just guessing:
Have you tried to start with a "fresh" MP3tag and renamed the mp3tag.cfg file before you start MP3tag? (Honestly: I don't know if that does anything good but there were weird cases where shortcuts did not work any more..)
Or: Have you set MP3tag to run in some kind of compatibility mode like XP?
This post has been edited by ohrenkino: Apr 28 2017, 10:23
+Quote Post
Solance
post Apr 28 2017, 12:52
Post #8
Member
Group: Full Members
Ok so I've done some HARDCORE clean install..
1. Uninstalled Mp3tag (with confirmation to remove all of the files)
2. Reboot
3. CCleaner -> Registry Cleaning
4. Reboot
5. Mp3tag installation (with Admin rights)
6. renamed mp3tag.cfg (in AppData\Roaming\Mp3tag)
7. run the app
but during my attempts to stick it to the edge I discovered one weird thing -
if I grab it by the part that is closer to the top right corner (screen: https://s11.postimg.org/fzgcvs6wz/123123.png )
then it does transform to take half of the screen (screen: https://s2.postimg.org/5akcmq4w9/4234243.png ).
BUT.
first - it does not stick to the edge. (instead it appears to be more or less in the middle of the screen)
and second - if I try to move it somewhere (even a little bit) it resets back again (screen: https://s2.postimg.org/u7f0vvth5/234234343.png ).
QUOTE (ohrenkino @ Apr 28 2017, 12:20) *
nope
+Quote Post
DetlevD
post Apr 28 2017, 15:16
Post #9
Member
Group: Full Members
QUOTE (Solance @ Apr 28 2017, 13:52) *
... but during my attempts to stick it to the edge ... it does transform to take half of the screen ...
Maybe ... have a look there ...
https://www.sevenforums.com/tutorials/3069-...p-turn-off.html
DD.20170428.1617.CEST
+Quote Post
Solance
post Apr 28 2017, 18:39
Post #10
Member
Group: Full Members
QUOTE (DetlevD @ Apr 28 2017, 17:16) *
(but I've tried even that. when OFF = it doesn't work with any window/app, when ON it does work with all windows/apps except Mp3tag.)
+Quote Post
DetlevD
post Apr 28 2017, 19:45
Post #11
Member
Group: Full Members
QUOTE (Solance @ Apr 28 2017, 19:39) *
no, turning Snap feature off doesn't help to make it work ... when ON it does work with all windows/apps except Mp3tag.)
Mp3tag on Windows 10 seems to have no problem with snapping.
Did you read the section "Warning - Aero Requirements to be Enabled in Windows 7"?
DD.20170428.2045.CEST
+Quote Post
Solance
post Apr 28 2017, 20:38
Post #12
Member
Group: Full Members
QUOTE (DetlevD @ Apr 28 2017, 21:45) *
yes, requirements are met.
+Quote Post
ohrenkino
post May 18 2017, 13:55
Post #13
Member
Group: Full Members
This is more guess work - you may have gathered, that I think we have a very local problem here.
So: could it be that MP3tag cannot write the mp3tag.cfg? Checking access rights and ownership of folders, even those in %appdata% is a precaution.
Is there some other application running occupies some screen areas like a hidden windows start bar? This could be a special toolbar or a panel to operate e.g. the camera, something like that.
So you have to investigate what might be the special circumstances on your machine.
+Quote Post
Solance
post May 29 2017, 14:00
Post #14
Member
Group: Full Members
QUOTE (ohrenkino @ May 18 2017, 15:55) *
I use only one user profile on this PC and it has admin rights, so there should be no problems with that.
(but I did check just in case - yep, I have access)
no, nothing like that.
here are all of the processes that are active while only mp3tag is running:
explorer.exe
csrss.exe
CCC.exe (Video Drivers)
Mp3tag.exe
MOM.exe (Video Drivers)
taskhost.exe
taskmgr.exe
dwm.exe
msseces.exe
Ati2evxx.exe (Video Drivers)
SOUNDMAN.exe (Audio Drivers)
winlogon.exe
Pretty clean, also no viruses or any other crap, I keep check on that.
Maybe it is somehow related to screen resolution it is 5:4 (1280x1024) or because of an old video card - Radeon X700 SE (Driver version 2010.0210.2339.42455). Really weird puzzle wacko.gif
+Quote Post
ohrenkino
post May 29 2017, 18:20
Post #15
Member
Group: Full Members
ZITAT(Solance @ May 29 2017, 15:00) *
I use only one user profile on this PC and it has admin rights, so there should be no problems with that....
No, it is not enough to have admin rights, you should actually be the owner of that folder. or alternatively: install MP3tag with the same user id with which it should run eventually.
Also you should be sure that MP3tag really uses the %appdata% folder and not the program folder or some other installation folder as a leftover from a previous installation.
Esp. if you have a migrated windows it could be that the access rights and ownerships are not quite what they should be.
+Quote Post
2 Pages V   1 2 >
0 Members:
RSS Lo-Fi Version Time is now: 20th September 2017 - 01:17
