IPB
> [X] Filter MISSING
chrisjj
post Aug 7 2017, 11:39
Post #1
Member
Group: Full Members
Mp3tag Version: -
Florian
Just to let you know, in:
QUOTE
<field> MISSING
Returns all files where tag field named <field> is missing.
<field> PRESENT
Returns all files where tag field named <field> is present.
I think (in program and docs) MISSING should be ABSENT. Perhaps this is a translation error.
This post has been edited by chrisjj: Aug 7 2017, 11:40
Go to the top of the page
+Quote Post
ohrenkino
post Aug 7 2017, 13:28
Post #2
Member
Group: Full Members
Mp3tag Version: 2.85
ZITAT(chrisjj @ Aug 7 2017, 12:39) *
Florian
Looking at a translation web site, the original German "fehlen" leads to the following suggestions:
http://dict.leo.org/englisch-deutsch/fehlen
which delivers more or less only "absent", "missing", "lacking".
Checking "absent" http://dict.leo.org/englisch-deutsch/absent
transports the connotation of "is not there but should better be" like in "absent-minded" or "absent without leave" which (as far as I understand it) implies some kind of bad intention.
"Missing" (http://dict.leo.org/englisch-deutsch/missing) has the connotation of "not there" but this time without any deliberation but more or less accidental.
I am not sure if this is also the case in English.
A check on wordhippo for the opposite of "PRESENT" offers "absent".
https://www.wordhippo.com/what-is/the-oppos...of/present.html
and also the reverse check of the opposite of "absent" offers "present" - but only as second best choice.
If you check the opposite of MISSING on the same site
https://www.wordhippo.com/what-is/the-oppos...of/missing.html
the first choice is "present".
So, what made you reconsider the function (almost) 8 years after its initial introduction?
This post has been edited by ohrenkino: Aug 7 2017, 13:29
+Quote Post
chrisjj
post Aug 7 2017, 14:28
Post #3
Member
Group: Full Members
Mp3tag Version: -
QUOTE (ohrenkino @ Aug 7 2017, 13:28) *
I didn't reconsider. This is the first time I've come to use ABSENT.
I've used <field> PRESENT, so today when I needed the opposite, I tried <field> NOT PRESENT and then <field> ABSENT.
In British English, the word for NOT PRESENT is ABSENT https://www.google.co.uk/search?q=define+absent
To be MISSING the thing has the be absent and expected. https://www.google.co.uk/search?q=define+missing
+Quote Post
poster
post Aug 7 2017, 15:22
Post #4
Member
Group: Full Members
NOT <field> PRESENT
would have worked.
+Quote Post
chrisjj
post Aug 7 2017, 16:00
Post #5
Member
Group: Full Members
Mp3tag Version: -
QUOTE (poster @ Aug 7 2017, 15:22) *
NOT <field> PRESENT
would have worked.
Yes - in Mp3tag. Thanks.
I guess the reason I didn't try that is that its English meaning is definitely not what I wanted Mp3tag to do.
In English, NOT <field> PRESENT refers to all fields that are not <field>.
So is very different from <field> NOT PRESENT (or NOT (<field> PRESENT) ) , which refers to only the specified field.
+Quote Post
ohrenkino
post Aug 7 2017, 19:24
Post #6
Member
Group: Full Members
ZITAT(chrisjj @ Aug 7 2017, 17:00) *
...So is very different from <field> NOT PRESENT (or NOT (<field> PRESENT) ) , which refers to only the specified field.
It is fairly astounding that you did not use the "NOT" in the correct fashion as we discussed that at length in
https://forums.mp3tag.de/index.php?showtopic=17344
That thread also referenced the help on filters so that the keywords for the existence or non-existence of fields should not have been such a new topic.
Considering the length of time that this feature has been around I would consider it a customary feature. Changing to other keywords would probably cause more hickups than good.
+Quote Post
chrisjj
post Aug 7 2017, 19:55
Post #7
Member
Group: Full Members
Mp3tag Version: -
QUOTE (ohrenkino @ Aug 7 2017, 19:24) *
NOT wasn't useful to me then and I've has no use for it since ... except now as reported here.
+Quote Post
Florian
post Aug 17 2017, 16:57
Post #8
Developer
Group: Admin
QUOTE (chrisjj @ Aug 7 2017, 12:39) *
Back in the days where I've implemented the filter query syntax, I was inspired by foobar2000's query syntax (which also uses MISSING). I wasn't aware of the subtle differences between those two words, so thanks for pointing.
QUOTE (chrisjj @ Aug 7 2017, 17:00) *
I think comparing the query language to English gives a little too much honor to this very limited language. It has a documented syntax which serves as a reference.
QUOTE (ohrenkino @ Aug 7 2017, 20:24) *
Yes, and I don't consider this a bug. However, I'll add ABSENT as a synonym with the next release. This way all of us that are used to use MISSING can use it — and ABSENT also works.
Kind regards
– Florian
+Quote Post
chrisjj
post Aug 18 2017, 01:24
Post #9
Member
Group: Full Members
Mp3tag Version: -
QUOTE (Florian @ Aug 17 2017, 16:57) *
Accepted, but I think Mp3tag's choosing to use English words invites the user to think they might operate as do like English words, esp. since the extra typing of e.g. AND over & is worth having only if English is somehow better.
.. I'll add ABSENT as a synonym with the next release. This way all of us that are used to use MISSING can use it — and ABSENT also works.
Thanks.
An idea for future: Allow English-like locating of NOT e.g.
NOT TITLE IS Yesterday
TITLE IS NOT Yesterday
+Quote Post
Florian
post Aug 18 2017, 11:15
Post #10
Developer
Group: Admin
QUOTE (chrisjj @ Aug 18 2017, 02:24) *
NOT likely to happen.
Kind regards
– Florian
+Quote Post
0 Members:
RSS Lo-Fi Version Time is now: 22nd November 2017 - 13:55
