IPB
> [X] Slight duration discrepancy?
Lozzy
post Aug 16 2017, 06:18
Post #1
Member
Group: Full Members
Mp3tag Version: 2.83
I was processing some 56k bitrate mono mp3 files, and noticed a discrepancy of around 10 secs in the duration reported by mp3tag compared to the actual playing time from foobar or mp3directcut.
I duly checked the files with both mp3VAL checker and VBR fix but no issues reported.
It's not a major problem really, but I thought I'd mention it as I'm curious to know why.
Screengrab is attached for clarity
regards
Lozzy
Attached thumbnail(s)
Go to the top of the page
+Quote Post
poster
post Aug 16 2017, 06:25
Post #2
Member
Group: Full Members
Mp3tag Version: 2.85
As you mention Mp3DirectCut:
Did you perhaps truncate the file with Mp3Directcut and after that did not refesh the view of Mp3Tag?
+Quote Post
ohrenkino
post Aug 16 2017, 06:28
Post #3
Member
Group: Full Members
In regular intervals, you find reports about the variation in bitrate for VBR files.
Apparently, the first few frames are important for MP3tag to calculate the length. If these are longer or shorter than the rest in average, you get an inaccurate result.
This is nothing to worry about. It is just that MP3tag simply does not look at the whole audio part.
If MP3val and Mp3diags have not reported anything, fine.
If you want to get matching results, transform the file into a CBR file (e.g. winmp3packer).
BTW: reports about the length differences have so far been categorized as "no bug".
This post has been edited by ohrenkino: Aug 16 2017, 06:29
+Quote Post
Lozzy
post Aug 16 2017, 06:32
Post #4
Member
Group: Full Members
QUOTE (poster @ Aug 16 2017, 05:25) *
No, the files were untouched by me at this point
+Quote Post
Lozzy
post Aug 16 2017, 06:33
Post #5
Member
Group: Full Members
QUOTE (ohrenkino @ Aug 16 2017, 05:28) *
In regular intervals, you find reports about the variation in bitrate for VBR files...
...If you want to get matching results, transform the file into a CBR file
I should have mentioned these are CBR already
This post has been edited by Lozzy: Aug 16 2017, 06:37
+Quote Post
ohrenkino
post Aug 16 2017, 06:57
Post #6
Member
Group: Full Members
Please try MP3diags and see if you have stacked tags or unidentified streams in the file or something like that.
+Quote Post
Florian
post Aug 16 2017, 13:14
Post #7
Developer
Group: Admin
Can you send me one of those files for analyzing purposes?
Kind regards
– Florian
+Quote Post
0 Members:
RSS Lo-Fi Version Time is now: 22nd November 2017 - 13:48
