IPB
> Notice!
4 Pages V  < 1 2 3 4 >
Closed TopicStart new topic
> Regular Expressions, Examples of actions with Regular Expressions
Fan o blues
post Mar 25 2007, 20:05
Post #16
Member
Group: Members
Mp3tag Version: 2.37a
It's taken me far too long to figure it out but I've finally got it working.
To change Horne, Lena to Lena Horne or
Hawkins, Coleman With Manny Albam & His Orchestra to Coleman Hawkins With Manny Albam & His Orchestra
Field: ARTIST
Regular Expression: ^([\w]+),\s([\w]+)
Replace Matches with: $2 $1
I hope I didn't miss the answer in here somewhere. If there's an easier or better way please feel free to help.
Go to the top of the page
+Quote Post
neilpa
post Nov 20 2007, 07:16
Post #17
Member
Group: Members
Mp3tag Version: 2.39
This regex can remove/replace all but the last dot from a string. It's useful for people like me who prefer to limit filename chars to a-z, 0-9, '_', and '-'. We need to save that last dot for file extensions.
Regex: [.](?![\w]{2,4}$)
Assumes file extensions are 2-4 chars long (not including the dot). If you are curious how this works google regex lookaround.
This post has been edited by neilpa: Nov 20 2007, 07:18
+Quote Post
Nathan
post Jan 22 2008, 01:13
Post #18
Member
Group: Members
I recently converted all my wma files to mp3 only to realize that all the tags were lost. My music is in the form:
...\artist\album\track title.mp3
MP3TAG came to my rescue! Not sure whether there was an easier way to do this, but I got started by reading this. Sorry if these are lame ways of doing it, but it's my 1st experience with regexp.
format artist:
$regexp(%_folderpath%,.+\\(.+)\\(.+)\\,$1)
format album:
$regexp(%_folderpath%,.+\\(.+)\\(.+)\\,$2)
Next 2 I got from ThurstonX in this post.
format track:
$regexp(%_filename%,(\d*)\s?(.+),$1)
format title:
$regexp(%_filename%,(\d*)\s?(.+),$2)
This program saved me TONS of time...
+Quote Post
Harakiri
post Sep 1 2008, 23:02
Post #19
Member
Group: Full Members
Mp3tag Version: 2.48
Another member helped me creating one of the most useful REGEXP that i use so far:
From this:
Röyksopp - Beautiful DAY withOUT yoU (Rex The Dog Remix)
To this:
Röyksopp - Beautiful day without you (Rex The Dog Remix)
USING:
Action type: Replace with regular expression
Field: TITLE
Regular expression: ^(.*?)(\(|$)
Replace matches with: $caps3($1)$2
[ ] case-sensitive comparison
See the original thread here
Pedro Vieira
+Quote Post
KCE
post Oct 24 2008, 23:08
Post #20
Member
Group: Members
Mp3tag Version: 2.41
Really simple but this will remove any parenthesis and its contents in any part of the string
Example:
Blah (blah1) (blah 2)
Result:
Blah
Regular expression: \(.+?\)
This post has been edited by KCE: Oct 24 2008, 23:08
+Quote Post
captainmidnight
post Dec 5 2008, 04:56
Post #21
Member
Group: Full Members
Mp3tag Version: 243
I dislike it when a leading zero appears in the track number of the track tag (or when the total track count is added after a '/' char).
[Aside: It seems like a bad idea to pollute a nice simple tag like the track with extra information like this. My intuition is that the information in each tag should be kept as simple and pure as possible. In databases there is a similar concept: you usually want to achieve what is called a normalized design. But if someone has a good reason for doing otherwise, please educate me!
Note that I only have a problem with leading zeroes in the track TAGS. In contrast, when I use tracks in filenames, I DO like a leading zero if there are > 9 tracks on the CD because that causes the filenames to be lexicographically ordered, which is critical for proper sorting by your file system, as well as it visually looks better when filenames are displayed in a list.]
Earlier in this thread, phoenixdarkdirk pointed out how to remove any '/' char and following digits.
Here is how to remove any leading zeroes (as well as trimmable whitespace):
Regex:
CODE
\s*0(\d+)\s*
Replace with:
CODE
$1
+Quote Post
captainmidnight
post Dec 5 2008, 05:17
Post #22
Member
Group: Full Members
Mp3tag Version: 243
Actually, here is a single regex that does everything that I want:
Regex:
CODE
\s*0?(\d+)(\s*/\s*\d+)?\s*
Replace with:
CODE
$1
[/quote]
This will remove any trimable whitespace around the number (which will be the track tag in my case), remove any leading zero from the number, and remove any suffix after the number that starts with a '/' char (e.g. the total track count).
This post has been edited by captainmidnight: Dec 5 2008, 05:18
+Quote Post
Craig
post Mar 14 2009, 14:59
Post #23
Member
Group: Members
QUOTE (Fan o blues @ Mar 25 2007, 19:05) *
Field: ARTIST
I've just spent a while figuring this out myself, and came on here to post it only to find someone else already has smile.gif
Mine is quite similar
Filed: ARTIST
RegExp: ^(.+),\s+(\w*)
Replace With: $2 $1
Seems to work the same
+Quote Post
Lebon14
post Nov 8 2009, 05:23
Post #24
Member
Group: Full Members
Mp3tag Version: 2.80
QUOTE (KCE @ Oct 24 2008, 17:08) *
Example:
Result:
Blah
+Quote Post
Florian
post Nov 8 2009, 20:43
Post #25
Developer
Group: Admin
Mp3tag Version: 2.85k
I've split some off-topic posts to Problem with Actions and Regular exp​ressions.
+Quote Post
MatthiasM
post Nov 19 2009, 10:48
Post #26
Member
Group: Full Members
This is not a regular expression for mp3tag, but a link to a page which contains lots of information about creating and using regular expressions.
www.regular-expressions.info
kind regards,
Matthias
+Quote Post
incifinci
post Feb 19 2010, 10:24
Post #27
Member
Group: Full Members
Switches first and last names
QUOTE (areve @ May 30 2004, 21:20) *
Another one, that switches first and last names (for instance, Jacques Brel will become Brel, Jacques):
Regular Expression: ^(.+)\s(.+)$
Replace with: $2, $1
Thank you!
I developed it a little.
Variant A
It will not change those artists, where the conversion already done (artist has comma).
Example: Brel, Jacques William remains Brel, Jacques William
Action
: regular expression
Field: ARTIST
Regular expression: ^([^,]+)\s([^,]+)$
Variant B
It handles multipled for WMP artists (in format "artist1/artist2/artist3"), possible nicknames at the end in square brackets and trims unnecessary white spaces.
Example:
Elvis Presley /Brel, Jacques/ Gabriele Susanne Kerner [Nena ]
will
Presley, Elvis/Brel, Jacques/Kerner, Gabriele Susanne [Nena]
Action group
1. action
: regular expression (trim white spaces)
Field: ARTIST
Regular expression: ^\s+|\s+$
Replace with: (nothing)
2. action: regular expression (multiple white spaces replace to 1)
Field: ARTIST
Regular expression: \s{2,}
Replace with: " " (whitout quotation marks)
3. action: replace (delete white space after opening bracket)
Field: ARTIST
Replace: "[ " (whitout quotation marks)
Replace with: [
4. action: replace (delete white space before closing bracket)
Field: ARTIST
Replace: " ]" (whitout quotation marks)
Replace with: ]
5. action: split fields by separator (for the next actions)
Field: ARTIST
Separator: /
6. action: regular expression (switches names without nickname)
Field: ARTIST
Regular expression: ^([^,[]+)\s([^,[]+)$
7. action: regular expression (switches names with nickname)
Field: ARTIST
Regular expression: ^([^,[]+)\s([^,[]+)\s(\[.+\])$
Replace with: $2, $1 $3
8. action: merge duplicate fields (...back)
Field: ARTIST
Separator: /
This post has been edited by incifinci: Feb 19 2010, 11:05
+Quote Post
Zoofield
post Jun 27 2010, 19:34
Post #28
Member
Group: Full Members
Mp3tag Version: 2.49
These are my Reg-Expressions there may be duplicates to what have previously been posted, or there are small changes to fix the many errors that the posted Reg-Expressions create. I have done a lot of testing to make sure these do what they say they do and nothing else. I hope this also allows me a place to create a back up.
Thank-you! Updated: (June/10/2011) Mp3tag 2.49
Action Group:Aa
CODE
RE: Remove track number from title, ex."1 - Title" < "Title".
Field:TITLE
re:^\s*\d+\s*-\s*
Nothing:
RE: Remove "The" from artist, ex."The Artist" < "Artist".
Field:ARTIST
re:^The\s+
Nothing:
Case conversion:
Field:_TAG
Case conversion:Mixed Case
/[({"-_
RE:Capitalize Roman Numerals up to 399. (trimmed down from 3999
RE:to reduce false positives) - http://bit.ly/lZdZsj
Field:_Tag
re:(?<!')\b(?=[CLXVI])((C{0,3})?((X[LC])|(L?X{0,3})|L)?((I[VX])|(V?(I{0,3}))|V)?)\b
$upper($0)
RE: Capitalize Zero stop Acronyms and Initialisms. - http://bit.ly/jADbI6
Field:_Tag
re:(?sad.gif?<=[^\w\']|\_)|(?<=^))(ac|ad|afi|aol|asap|atm|bbc|bc|bce|blt|btw|cc|cia|crc|cst|csv|dc|dfa|dj|d
mv|doa|dst|eod|ep|est|et|faq|fbi|fm|gi|glc|gmo|imo|imho|iq|ira|jc|irs|krs|la|lp|
m
c|mst|mtd|nasa|oj|pc|pi|pj|pm|ps|qed|rv|sos|ssr|usa|ussr|tba|tbd|teotwawki|tlc|t
v
|ufo)(?=[^\w\']|\_|$)(\.*)
$upper($1)
RE: Capitalize the Letter Infront of a period. A.B.C.
Field:_Tag
re:(?<=\.)([^\W\d\_])
$upper($1)
RE: Capitalize the Letter Infront of a Space and Apostrophe.
Field:_Tag
re:(?<=\s')([^\W\d\_])
$upper($1)
RE: Lower Case Prepositions, Articles and, Coordinating Conjunctions.
Field:_Tag
re:(?<=\w\s)(a|as|at|an|about|above|across|after|against|along|alongside|although|amo
ng|and|around|as|at|because|before|behind|below|beneath|beside|between|beyond|bu
t
|by|de|despite|down|during|even|except|excepting|for|from|if|in|inside|into|like
near|next|nor|of|off|on|onto|or|out|outside|over|past|regarding|round|since|so|t
h
an|the|through|throughout|till|to|toward|under|underneath|unlike|until|up|upon|v
o
n|when|while|with|within|without|yet)(?=\s\w)
$lower($0)
RE: Lower Case Abbreviations, Add Stop.
Field:_Tag
re:(?<=[^\w\']|\_)(alt|ave|capt|cent|corp|div|ed|eg|etc|fag|feat|gen|hr|ie|inc|inst|lb|ltd|
min|mt|op|pl|pop|pseud|pt|pub|rev|sec|ser|sgt|st|univ|vs|vol)(?=[^\w\']|\_)(\.*)
$lower($1).
RE: Add Space Before, & ( { [ + =
Field:_Tag
re:([^\W\_])([&\(\{\[\+\=])
$1 $2
RE:Add Space After, & ) } ] ; : , ! + =
Field:_Tag
re:([&\)\}\]\;\:\,\!\+\=])([^\W\_])
$1 $2
RE: Add Space After, . http://bit.ly/jADbI6
Field:_Tag
re:(?<!^)(?<!\d|\s|\.)(\.)([^\W\d\_])(?!\.|\s|$)
$1 $upper($2)
RE: Add Space After, " "
Field:_Tag
re:(".*?")([^\W\_])(?!$)
$1 $2
RE: Add Space Before, " "
Field:_Tag
re:([^\W\_])(".*?")
$1 $2
RE: Remove Spaces After, ( [ { Before, ] } ) ? : ; , ! .
Field:_Tag
re:([\(\[\{])\s+|\s+([\]\}\)\?\:\;\,\!\.])
$1$2
RE: Remove Spaces Before / After.
Field:_Tag
re:\s+(\/)\s+
$1
RE: Remove Spaces inside, " "
Field:_Tag
re:"\s*(.*?)\s*"
"$1"
RE: Remove Spaces Before and After String.
Field:_Tag
re:^\s+|\s+$
Nothing:
RE: Remove all Double+ Spacing.
Field:_Tag
re:\s{2,}
One Space:
RE: Add Apostrophe to Are Contractions.
Field:_Tag
re:\b(how|they|what|when|where|why|you)re(?=[^\w\']|\_|\$)
$1're
RE: Add Apostrophe to Had/Would Contractions.
Field:_Tag
re:\b(he|how|i|it|she|they|we|what|where|who|why|you)d(?=[^\w\']|\_|\$)
$1'd
RE: Add Apostrophe to Have Contractions.
Field:_Tag
re:\b(could|how|i|might|must|should|we|what|when|where|would|you)ve(?=[^\w\']|\_|\$)
$1've
RE: Add Apostrophe to Is Contractions.
Field:_Tag
re:\b(he|here|how|it|let|she|that|there|two|what|when|where|who|why)s(?=[^\w\']|\_|\$)
$1's
RE: Add Apostrophe to Not Contractions.
Field:_Tag
re:\b(ain|aren|can|couldn|didn|doesn|don|hadn|hasn|haven|isn|mightn|mustn|shoul
dn|wasn|weren|won|wouldn)t(?=[^\w\']|\_|\$)
$1't
RE: Add Apostrophe to Will Contractions.
Field:_Tag
re:\b(how|i|it|she|that|there|they|what|when|where|who|why|you)ll(?=[^\w\']|\_|\$)
$1'll
RE: Add Apostrophe to Am Contractions.
Field:_Tag
re:\b(i)m(?=[^\w\']|\_|\$)
$1'm
RE: Add Apostrophe to Do Ya Contraction.
Field:_Tag
re:\b(D)ya(?=[^\w\']|\_|\$)
$1'ya
RE: Add Apostrophe to Do You Contraction.
Field:_Tag
re:\b(D)you(?=[^\w\']|\_|\$)
$1'you
RE: CamelCase Mc Words.
Field:_Tag
re:\bMc(?=.)
Mc$upper($1)
RE:CamelCase O' Words.
Field:_Tag
re:\bO'([^\W\d\_e])
O'$upper($1)
This post has been edited by Zoofield: Jun 11 2011, 05:18
Attached File(s)
+Quote Post
d003232
post Aug 16 2010, 11:38
Post #29
Member
Group: Full Members
My title and/or filename looks like:
Gospel&spiritual 1 - Track 03.[128kb 44khz 2'34]
I want to delete the suffix: '.[128kb 44khz 2'34]'.
I do it the way:
Field: TITLE
RegExp: (.*)\.\[[0-9]+kb\s[0-9]+khz.*\]
Replace with: $1
Just change that to the field _FILENAME if you want to do it for the filename.
If you want to take a more easy solution (for example delete everything after the first dot, ...) see the next posts from DetlevD or RevRagnarok.
Update: Added a '\' befor the dot, to make sure, only a real dot before the '[' will be replaced, thx to RevRagnarok for the hint.
This post has been edited by d003232: Aug 17 2010, 15:35
+Quote Post
DetlevD
post Aug 16 2010, 17:22
Post #30
Member
Group: Full Members
QUOTE (d003232 @ Aug 16 2010, 12:38) *
...Gospel&spiritual 1 - Track 03.[128kb 44khz 2'34] ... I want to delete the suffix: '.[128kb 44khz 2'34]' ...
This is a good example for the situation, where someone does not really need to learn the regular expression language, but instead use a simple action.
Actiontype 7: Import tag fields (guess values)
Source format: %TITLE%
Guessing pattern: %TITLE%.%DUMMY%
To:
DD.20100816.1822.CEST
This post has been edited by DetlevD: Aug 16 2010, 17:23
+Quote Post
0 Members:
RSS Lo-Fi Version Time is now: 17th January 2018 - 22:59
