IPB
> Notice!
> Downloading cover art from web, How do I download the cover art from web sources?
cianoz
post Sep 2 2017, 08:34
Post #1
Member
Group: Members
Mp3tag Version: 2.84a
Hello
In previous versions of mp3tag I could download the cover art from a couple of web sources, Amazon and another. It was quick and easy. In recent versions I can't see this item in the list of web sources anymore. Was it removed?
Is it still possible to download cover arts from web? Is there something to do, like setting some preference or download a plugin or other?
Thanks
This post has been edited by cianoz: Sep 2 2017, 08:35
Go to the top of the page
+Quote Post
Florian
post Sep 2 2017, 11:15
Post #2
Developer
Group: Admin
Mp3tag Version: 2.85k
Amazon as Tag Source has been removed after they've terminated my associate accounts. You can use "Cover > Discogs" to download cover art with the current version you're using.
Kind regards
– Florian
+Quote Post
ubermorgan
post Sep 3 2017, 04:46
Post #3
Member
Group: Members
Mp3tag Version: 284a
Hi guys. I just updated to v2.84a i can't download cover art. I keep getting a dialog box that asked for discogs authorisation code. It's really annoying. When i am able to search without discogs, i never seem to get any art covers, only text
+Quote Post
Florian
post Sep 3 2017, 12:29
Post #4
Developer
Group: Admin
QUOTE (ubermorgan @ Sep 3 2017, 05:46) *
QUOTE (Florian @ Aug 25 2017, 14:33) *
Maybe I can help you there:
  1. Register an account at Discogs: https://www.discogs.com/users/create
  2. Login to Discogs: https://www.discogs.com/login?return_to=%2Fmy
  3. Use Mp3tag to query via a Discogs Tag Source
  4. Allow access for Mp3tag in the Browser window that opens automatically
  5. Enter the authorization code that is displayed on the Discogs website in Mp3tag's input field
+Quote Post
roelibex
post Sep 5 2017, 20:19
Post #5
Member
Group: Members
I have a similar problem.
I search for artwork for via Cover Art-> Discogs. I then fill in the correct album title and it shows me a couple of hits. I then select one of them, it opens a new window, but the artwork frame remains empty. It does so with all hits, but i know the discogs page itself does contain artwork. Pretty weird.
Previous version (i dont know the number) i had installed had the same problem so i thought i update to this version. Too bad its not fixed. The version before my previous version worked correctly.
+Quote Post
roelibex
post Sep 5 2017, 20:22
Post #6
Member
Group: Members
I dont get these steps (a window doesnt open automatically
I do have a Discogs account which is always logged in
+Quote Post
bobbydriver
post Sep 11 2017, 13:46
Post #7
Member
Group: Full Members
Mp3tag Version: 2.47b
I get the same issue
QUOTE
Mp3tag v2.84a
Failed to authenticate using OAuth (1).
» 12175: 12175: A security error occurred
It works fine from my home PC but not my work PC (which is behind a proxy)
The 12175 error seems to be related to the proxy, but not all calls to the web are failing
For example, the check for updates works fine, Musicbrainz tag sources and Freedb tag sources all work fine - just Discogs.
I have a Discogs account that is logged in on the same PC
+Quote Post
ohrenkino
post Sep 11 2017, 14:06
Post #8
Member
Group: Full Members
See Tools>Options>Network
to enter settings to access the internet via a proxy.
+Quote Post
Schof
post Sep 14 2017, 21:15
Post #9
Member
Group: Members
Mp3tag Version: 2.83
I too had issues with Discogs so ended up using the Tools option to integrate with Album Art Downloader.
It has many commandline options which made the integration a breeze.
The parameter I used was:
/artist "%artist%" /album "%album%" /path "%_folderpath%\folder.jpg" /minSize 500 /maxSize 500
I believe it is pretty self explanatory but if not, it searches for all 500x500 images for the artist & album and when you click on the desired image saves it to the album's directory as "folder.jpg".
+Quote Post
bobbydriver
post Sep 14 2017, 21:49
Post #10
Member
Group: Full Members
QUOTE (ohrenkino @ Sep 11 2017, 14:06) *
Sorry - in case it wasn't clear from my post - the proxy is set and working fine for some calls to the internet
eg check for updates works fine, Musicbrainz tag sources and Freedb tag sources all work fine - just Discogshat gives the error
+Quote Post
M3Rocket
post Oct 6 2017, 19:26
Post #11
Member
Group: Full Members
QUOTE (Schof @ Sep 14 2017, 12:15) *
AlbumArtDownloader is awesome for cover art. Just FYI, the commandline options doesn't need the "\" in "%_folderpath%\folder.jpg". I also added autoclose so AlbumArtDownloader will close automatically once you save the cover art with right-click, save. My commandline is:
CODE
/artist "%artist%" /album "%album%" /path "%_folderpath%folder.jpg" /minSize 500 /maxSize 3000 /ac
+Quote Post
Ekmek
post Jan 3 2018, 20:25
Post #12
Member
Group: Full Members
Mp3tag Version: 2.68
So I've been using google and then copying and pasting covers to my mp3s.
I wonder if that can be added where we just put the song detail or whatever in the cover art option and a window pops up with google images and then you can click and add that as album art?
+Quote Post
ohrenkino
post Jan 3 2018, 20:34
Post #13
Member
Group: Full Members
For the specific Google web source see this thread:
https://forums.mp3tag.de/index.php?showtopic=12596
+Quote Post
0 Members:
RSS Lo-Fi Version Time is now: 17th January 2018 - 22:58
