IPB
58 Pages V  « < 55 56 57 58 >
> [WS] Discogs (pone mod), all discogs information in tags & lyrics, based on dano's scri
Zwanzig
post May 8 2017, 23:19
Post #841
Member
Group: Members
Mp3tag Version: 2.82
Hello
I have some questions to configure.
At the beginning of:
1. How to disable save in tags: artist, album and titles.
Part of the music is well tagged and I just want to upgrade with additional information from the discogs.
2. Format settings - Format (complete) -
In the list of results shows: ... Vinyl, LP, Remastered, Compilation
And writes to the tags: ......... 2 x Vinyl, LP,, "Compilation", Remastered,, "Compilation", Compilation,, 180g, ...... (I prefer the version from the list of results)
3. How to set Releasetype (eg Album, Compilation) and Releasestatus (eg Official, Unofficial Release)
Greeting
Zwanzig
EDIT:
2 and 3 SOLVED
This post has been edited by Zwanzig: May 12 2017, 09:21
Go to the top of the page
+Quote Post
djcaesar9114
post Jun 16 2017, 12:15
Post #842
Member
Group: Full Members
Hi, do you plan on publishing it on github?
+Quote Post
djcaesar9114
post Jun 18 2017, 08:39
Post #843
Member
Group: Full Members
Another question: can you make a tutorial to explain how we can fect info from a release ID?
I really don't understand the explanations you give in the first post...
+Quote Post
pone
post Jul 25 2017, 21:34
Post #844
Member
Group: Full Members
Mp3tag Version: 2.59b
QUOTE (djcaesar9114 @ Jun 18 2017, 09:39) *
No tutorial, sorry. I started something like that several times. To messy for me,too.
+Quote Post
pone
post Jul 25 2017, 21:56
Post #845
Member
Group: Full Members
QUOTE (Zwanzig @ May 9 2017, 00:19) *
Hello
In the settings file, you can leave every place for tag field names empty. These tag fields are not written at all.
In your case, at "ARTIST NAMES":
Artist - Primary Name: >
Artist - Name Variation: >
and at "OTHER FIELDS & OPTIONS":
Album: >
Title: >
+Quote Post
pone
post Jul 25 2017, 22:46
Post #846
Member
Group: Full Members
QUOTE (jono @ Mar 15 2017, 23:39) *
In UPDATE (v2.7) a new tag field called CHAPTER was introduced.
The chapters or disc names found as headlines above or between the tracklist at discogs.
Look at this pages for examples:
http://www.discogs.com/Joy-Division--Singl...release/2586049
http://www.discogs.com/Kraftwerk-Der-Katalog/release/1996371
http://www.discogs.com/Erykah-Badu-Mamas-G.../release/424341
It works fine but I don't understand how to make use of it or which software makes use of it.
I can't get it to work in Logitech Media Server / Slimserver?
Is there a way?
Kind Regards
Johan
I use foobar2000 which can show every custom mp3 field you want.
Another option would be to use COMMENT for this information (it's called track index at discogs).
Go to "OTHER FIELDS & OPTIONS" and write:
Track Index: >COMMENT
Or you add it to the ALBUM tag field with an mp3tag action.
Format Tag-Field: ALBUM
$if(%chapter%,%album% '('%chapter%')',%album%)
I thought I would have built some option into the script to combine Album and Track Index into one field. But I can't find that now. If there is a purpose for that mybe a can make an update.
But I guess I won't find the time
This post has been edited by pone: Jul 25 2017, 22:48
+Quote Post
pone
post Jul 25 2017, 23:07
Post #847
Member
Group: Full Members
QUOTE (detone @ Mar 8 2017, 21:30) *
Hello everybody,
Does anyone have any Discogs script that does the search by artist name and music? I'm trying to adapt what I have here, but it's complicated and I'm running out of time.
Thanks all!
What do you mean by "music". Genre or Style?
If you adapt the script you can search for all categories you see here: https://www.discogs.com/search/advanced
Here is a little explanation with the right trigger words:
https://www.discogs.com/developers/#page:da...database-search
- take the .src file one of the existing "Search by (Album)Artist + ..." scripts
- go to the line which starts with "[SearchBy]="
- replace the part after "&" with "&genre=%GENRE%" or (maybe better): "&style=%GENRE%"
+Quote Post
pone
post Jul 25 2017, 23:21
Post #848
Member
Group: Full Members
QUOTE (stevehero @ Mar 8 2017, 01:40) *
Any way to combine each set of the tracks below of disc two in this release?
See CD2: https://www.discogs.com/Stephan-Bodzin-vs-M...release/2760764
Such as combining:
a, b & c of 2.5
a & b of 2.7
a & b of 2.12
The tracks are:
2.5a Callisto
2.5b Callisto (Joris Voorn Remix)
2.5c Callisto (Dominik Eulberg Remix)
2.7a Phobos (Pan-Pot Remix)
2.7b Phobos (Synthapella)
2.12a The Alchemist
2.12b The Alchemist (Robag's Kopakkmuuf-Rekksmo)
No sorry.
The track number format used here isn't covered by the "discogs pone/tracklist for albums with multi song track" script.
I won't have the time to debug this. Especially because when I try to do this, various other track numbering format would be read wrong.
You could go to discogs and format the page like this one:
https://www.discogs.com/release/5553165
+Quote Post
pone
post Jul 25 2017, 23:23
Post #849
Member
Group: Full Members
QUOTE (venvaneless @ Feb 21 2017, 18:29) *
I noticed that most of the composer/written by tags don't load to the tag filed "composer" although I set it to do it as extra fields. For some reason one to three show up, the rest looks like it hasn't been pulled from discogs. Any suggestions?
Can you give the release IDs of a few examples?
Maybe I can look into this.
+Quote Post
pone
post Jul 25 2017, 23:26
Post #850
Member
Group: Full Members
QUOTE (Lee R @ Jan 20 2017, 02:09) *
Can I run these scripts as a batch, rather than one song at a time? Billiant work, can finally get Genre.
No. Discogs scripts work only one release (album/single/ep/compilation) at a time.
+Quote Post
pone
post Jul 25 2017, 23:37
Post #851
Member
Group: Full Members
QUOTE (GaryG45 @ Oct 10 2016, 22:41) *
I recently used the Direct by Discogs ID script on an album where a CHAPTER was assigned to a multi song track. The release ID used was 6518000, for The Rocky Horror Picture Show. Discogs tracks B3a, B3b, and B3c are part of chapter "Rose Tint My World". I have these as separate tracks/files.
When I run the script, CHAPTER "Rose Tint My World" is assigned to the three tracks, and it is assigned to the remaining 3 tracks for the album. Discogs does have a "-" after the B3c track, which indicates the end of the chapter. Is the script working correctly? Do I have to create an action group to remove the CHAPTER from the last 3 tracks of the album?
Gary
I remember eliminating things like "-", "CD1" to avoid redundant information which is sometime given as track index at discogs.
I don't know why it leads to a problem here. Maybe I find the time to look into this
+Quote Post
pone
post Jul 26 2017, 00:03
Post #852
Member
Group: Full Members
QUOTE (JmmyBoy @ Feb 19 2017, 03:03) *
mp3tag - v2.80
pone - 4.4 Update 1
Everything works fine, except for certain search criteria which results in a 401: UNAUATHORIZED.
I have followed all previous steps with regards to [OAuth] etc.
For example, perform a standard search for the following.
P.O.S. Gravity (Original Mix) = 401
P.O.S. Gravity = 401
P.O.S. = 401
POS = No 401, but not finding relavent results.
The discogs ID that I am trying to get a result for is : 363202
Essentialy, whenever there is a period (.) (hex code 2e) in the search query, my search will fail. Maybe this is an issue some others are reporting with 401's, not realising the period in the search query is giving them this error.
PS. Awsome script.
PPS. Would be cool if there was an option to specify the Genre seperator in the .mp3 settings file - ie pone gives 'House\\Trance\\Techno' - i Prefer 'House / Trance / Techno'
I did manually do this for anyone interested, with the following code change (but would be nice as a settings option)
CODE
#< ## GENRE #
outputto "GENRE"
findinline "\"genres\":" 1 1
sayregexp "(?<=\")[^,].+?(?=\")" " \\u002f " "],"
gotochar 1#>
Your 401 problem is a known bug. Maybe a find the time to fix it. I help myself by replaceing special character with white scpaces.
Can somebody give me a list with the characters that are giveing proplems in the search bar?
For your second problem:
Have you looke into the "GENRE & STYLE" field in the setting file.
You have the standard setting which looks like this:
CODE
Genre:                >GENRE
if more than one genre:
- only the first            >no
- multivalue tag field        >yes
- list of names            >no
  - seperating characters used in list    >,
Style:                >GENRE
if more than one style:
- list of names            >no
______________________________________________
Help:
You can combine Genres & Styles in one tag field if you use the same name.
you want:
CODE
- multivalue tag field        >no
- list of names            >yes
  - seperating characters used in list    > /
+Quote Post
pone
post Jul 26 2017, 00:22
Post #853
Member
Group: Full Members
QUOTE (BoostMan @ Oct 23 2016, 19:54) *
I am having some problems with images.
I am using the latest MP3TAG version (2.79) and the latest Discogs script (4.4joker01).
When I try to tag the following Discogs release, the last image will be shown in the 'Adjust tag information' dialog:
https://www.discogs.com/Aztec-Death-Demo/release/8352476
It is not the front cover that is shown on the Discogs page, it is the disc label - the last of the 3 available release images.
Is there still a bug in the script or does anyone knows how to fix it?
And a second (more general) question: in MP3TAG I will only see one image in the cover section in the 'Adjust tag information' dialog. Is there a way to step thru all available images on Discogs. I think some (long) time ago I read something here it is possible, but I have never seen back/forward buttons.
Thanks for your time and any help...
The problem is that at this release, none of the pictures are tagged as "primary image", which is the normal attribute for a cover picture at the discogs API.
I don't know how the website is showing the correct picture.
I think I won't have time to look into this as I don't know how to start there, sorry.
I also have no solution for you second question. It's no possible within the framework of Mp3Tag's web sources.
+Quote Post
flex
post Aug 28 2017, 17:07
Post #854
Member
Group: Members
Mp3tag Version: 2.79
QUOTE (Florian @ Sep 26 2016, 15:33) *
Can you try again?
I've noticed that my Discogs image proxy wasn't working as expected and I've just fixed that.
Kind regards
– Florian
I think we may have the same issue with images again as none are getting pulled in currently.
Anyone else having this issue?
+Quote Post
blackbeen
post Sep 15 2017, 14:40
Post #855
Member
Group: Full Members
Mp3tag Version: v2.77
MP3Tag will not connect to Discogs with any script, does anyone know what's going on???
+Quote Post
0 Members:
RSS Lo-Fi Version Time is now: 17th January 2018 - 22:53
