IPB
5 Pages V  « < 3 4 5
> [WS] vgmdb, videogame music
infocynic
post Jan 11 2016, 23:26
Post #61
Member
Group: Members
Mp3tag Version: 2.73
I am not the original script author, and I have tested this on exactly one album so far. But it's a really simple change you can all make yourselves and report any problems and maybe I'll post an updated version.
Go to the directory where you installed the script originally. Make a copy of any script you're changing (either move it to a new folder or you can just rename the one you change as BETA or something).
This is for the "VGMDB Search by Album" version 0.4 originally dated Jan 2 2013.
Open your favorite text editor. On line 88 you should see a section "coverurl". We're going to change that section down to where the comment #set coverurl is. Replace with this block:
CODE
# Coverurl
outputto "coverurl"
findline "id=\"coverart\""
findinline "background-image: url("
if "'"
    movechar 1
    sayuntil "'"
endif
# set "coverurl"
Save the file. You don't need to restart mp3tag if it's already running, but do at least cancel any open dialogs.
If you find a non-working example, please include the album title, the URL to find it at VGMDB, and a brief description or screenshot of what fields you are getting and what fields are blank.
Go to the top of the page
+Quote Post
secondsabre
post Feb 13 2016, 07:09
Post #62
Member
Group: Members
I was wondering if it would be possible to have the script scrape the track numbers and appropriate disc numbers.
When I try to run a multi-disc batch through the script, it never grabs disc numbers, and the track numbers don't reset for the separate discs. It looks something like:
CODE
Original Disc/Track   -   New Disc/Track
Disc 1/Track 37           No Disc/Track 37
Disc 1/Track 38           No Disc/Track 38
Disc 2/Track 1            No Disc/Track 39
Disc 2/Track 2            No Disc/Track 40
etc etc                   etc etc
I looked through the script and XML, and it looks like it would be possible, but I don't really know enough about scripting to make it *do the work*. I'd also assume it would need some sort of counting/math function to determine what the total number of discs or tracks are, but that seems like gravy. Just raw numbers, like Disc 3/Track 6 would be great.
I looked through a few other scripts for reference, and it seems like most of them don't even grab those values, so I'm not sure if this is even possible, but I figured I'd ask. Would very much appreciate any help with this, thanks in advance.
+Quote Post
Kareha
post Feb 14 2016, 18:25
Post #63
Member
Group: Full Members
Mp3tag Version: 2.52a
QUOTE (infocynic @ Jan 11 2016, 22:26) *
CODE
# Coverurl
outputto "coverurl"
if "'"
    movechar 1
    sayuntil "'"
endif
# set "coverurl"
Just wondering what this change does?
+Quote Post
Redsama
post May 18 2017, 02:06
Post #64
Member
Group: Members
Mp3tag Version: 2.82
The script is broken from my end.
This post has been edited by Redsama: May 18 2017, 02:07
+Quote Post
MDA999
post Jul 9 2017, 17:32
Post #65
Member
Group: Members
Mp3tag Version: 2.77
The script doesn't work anymore, same problem as Redsama. May there be an update?
+Quote Post
MDA999
post Jul 9 2017, 17:55
Post #66
Member
Group: Members
QUOTE (MDA999 @ Jul 9 2017, 18:32) *
https://gist.github.com/PBXg33k/7b80a86d53b922f0873a This one works pretty good. smile.gif
+Quote Post
apples
post Aug 2 2017, 11:07
Post #67
Member
Group: Members
Mp3tag Version: 2.83
this website made an api for vgmdb. (i think they mirrored the site and made an api)
http://vgmdb.info/
https://github.com/hufman/vgmdb
im not good with scripts, but maybe it can be used for this script. biggrin.gif
This post has been edited by apples: Aug 2 2017, 11:12
+Quote Post
5 Pages V  « < 3 4 5
2 User(s) are reading this topic (2 Guests and 0 Anonymous Users)
0 Members:
RSS Lo-Fi Version Time is now: 17th January 2018 - 22:41
