IPB
30 Pages V  < 1 2 3 4 > »
> beatport.com scripts by stevehero (search & direct) - jaimz mod, rips cover, album, year, date, catalog #, publisher, genre, www + more
stevehero
post Dec 12 2011, 00:33
Post #16
Member
Group: Full Members
Mp3tag Version: 2.84
QUOTE (The Sheriff @ Dec 11 2011, 22:29) *
Maybe you can help me with the issue I'm having with the DATE field? It's read in the script in the format MMDD......
To format the DATE in the format DDMM
Enter the following:
CODE
# DATE
outputto "date"
gotoline 1
findline "<dateReleased>"
findinline "<dateReleased>"
findinline "-"
findinline "-"
sayuntil "</"
gotochar 1
findinline "-"
sayuntil "-"
Replacing:
CODE
# DATE
outputto "date"
gotoline 1
findinline "-"
sayuntil "-"
findinline "-"
sayuntil "</"
**EDIT**
@pone, not one little bit :] Just seen you posted. Its a cleaner method but both things do the same @The Sheriff.
This post has been edited by stevehero: Dec 12 2011, 00:37
Go to the top of the page
+Quote Post
The Sheriff
post Dec 12 2011, 01:43
Post #17
Member
Group: Full Members
Mp3tag Version: 2.49a
QUOTE (pone @ Dec 11 2011, 23:26) *
put this line
CODE
regexpreplace "(\d\d\d\d)-(\d\d)-(\d\d)" "$1-$3-$2"
after
CODE
at the DATE section.
or
change this
CODE
indinline "-"
sayuntil "-"
findinline "-"
sayuntil "</"
into this
CODE
findinline "-" 2
sayuntil "</"
findinline "-" -1
movechar -1
sayuntil "-"
at the DATE section
@ stevehero:
pone, you are a genius. Thanks again.
+Quote Post
garves
post Jan 2 2012, 05:02
Post #18
Member
Group: Members
Beatport are now displaying the bpm and song Key info in the API..
Could you please add these tags into the next update of the script?
I've modified my .src files and I now get the bpm.
but I'm struggling with the song key info. (I'm new to this)
thanks
+Quote Post
stevehero
post Jan 2 2012, 10:55
Post #19
Member
Group: Full Members
QUOTE (garves @ Jan 2 2012, 04:02) *
thanks
I've taken a quick look on my phone there and its seems they do have it in the API smile.gif. This will be included in the next update of the script very soon as its the most requested feature from you guys.
Thanks for pointing that out garves.
+Quote Post
stevehero
post Jan 7 2012, 04:54
Post #20
Member
Group: Full Members
Could you please add these tags into the next update of the script?...
I've been very busy (my apologies) so those looking for a quick fix to the BPM and INITIALKEY info. Heres goes.
The INITIALKEY tag is formatted as follows:
C Minor
C♯ Major
A♭ Minor
I have tested the special character '♭' in traktor and it shows up. Any problems for now just find where it says 'replace "1" "♭"' in the code below and change the '♭' to a 'b'.
BTW Any suggestions as to how you would like this formatted please let me know. OR maybe its fine the way it is :]
Just so I can update the next version to how you guys like it
Please place whats in italics between whats in bold in the script, like so:
# _LENGTH
outputto "_length"
findline "<trackLength>"
findinline ">"
sayuntil "</"
say "|"
# BPM
outputto "BPM"
findline "<trackBpm>"
findinline ">"
sayuntil "</"
say "|"
# KEY
outputto "InitialKey"
findline "<trackKey>"
# LETTER
moveline 2
findinline ">"
sayuntil "</"
# SHARP
moveline 1
replace "1" "♯"
findinline ">"
sayuntil "</"
# FLAT
moveline 1
replace "1" "♭"
findinline ">"
sayuntil "</"
# CHORD
moveline 1
replace "minor" "Minor"
replace "major" "Major"
findinline ">"
Say " "
sayuntil "</"
say "|"
# GENRE
outputto "Genre"
findline "<genre"
+Quote Post
garves
post Jan 8 2012, 09:10
Post #21
Member
Group: Members
+Quote Post
stevehero
post Jan 9 2012, 21:23
Post #22
Member
Group: Full Members
Uploaded now is the latest version of 'beatport by stevehero v1.2' scripts (see first post here for full details)
Its includes the BPM and INITIALKEY fields all you you wanted. Along with an action to change the key to the Camelot notation found in the Mixed In Key application. e.g. 'A♭ Minor' would be '1A'. This makes it much easier visually to see what tracks go with what. For all you DJs check the website on how to use this method of mixing.
+Quote Post
pinknoise
post Jan 26 2012, 07:00
Post #23
Member
Group: Members
Mp3tag Version: 2.94b
Registered to say thank you!
are you planning on eventually integrating the Camelot scale into the Main source script? I was trying to figure it out all day but couldn't figure out how to output the formated Key (A Minor) as a temporary value so that I could then run a couple replace actions (replace "A Minor" "8A") and then set that to the InitialKey
Any help would be appreciated!
+Quote Post
chriswike
post Jan 28 2012, 02:28
Post #24
Member
Group: Members
Mp3tag Version: 2.49b
Damn stevehero, this last update made my favorite Script even better....
I purchased mixed in key around a year ago and very quickly learned the importance of harmonic mixing. I stuck the Camelot wheel to the top of my controllers flight-case and after a few mixing sessions harmonic mixing was as natural as beat-matching. If there are any other DJ types here give it a shot, stevehero already did the hard part for you biggrin.gif
One Issue I'm having with the action script - the Camelot scale doesn't have a number for G# Minor, A# Minor, or C# Minor, like it does on the Circle of Fifths, so when I use the action script on say, this song it doesn't change.
The correct way to label these on a Camelot wheel is:
A-sharp Minor = B-flat Minor (3A)
G-sharp Minor = A-flat Minor (1A)
C-sharp Minor = D-flat Minor (12A)
I had a look at the Action Script and it looks like I was able to fix it by adding these to it.
CODE
[#25]
T=2
F=INITIALKEY
1=A\u266f Minor
2=3A
3=0|0
[#26]
T=2
F=INITIALKEY
1=C\u266f Minor
2=12A
3=0|0
[#27]
T=5
F=COMMENT
1=%initialkey% - %comment%
[#28]
T=4
F=COMMENT
1=^\\s+-\\s+$|\\s+-\\s+$|\\s+-\\s+\\d{1,2}[A-B]\\s+-\\s+$|\\s+-\\s+\\d{1,2}[A-B]$|^(\\d{1,2}[A-B]\\s+-\\s+)\\d{1,2}[A-B]\\s+-\\s+(\\d{1})
2=$1$2
3=0
I attached my fixed action script as well.
Again, thanks a ton for this awesome script!
This post has been edited by chriswike: Jan 28 2012, 23:40
Attached File(s)
Attached File  Key_to_Camelot_Notation.zip ( 558bytes ) Number of downloads: 703
+Quote Post
stevehero
post Feb 1 2012, 04:12
Post #25
Member
Group: Full Members
QUOTE (pinknoise @ Jan 26 2012, 06:00) *
are you planning on eventually integrating the Camelot scale into the Main source script? I was trying to figure it out all day but couldn't figure out how to output the formated Key (A Minor) as a temporary value so that I could then run a couple replace actions (replace "A Minor" "8A") and then set that to the InitialKey....
Thank you 'pinknoise'. I am in the process of doing so. :]
But I need a little help first.
What I have is a list of replaces below in the test script.
CODE
# INITIAL KEY TO CAMELOT NOTATION # DO NOT CHANGE VALUES OR DELETE BETWEEN THESE LINES IF NOT NEEDED #
    replace "A♭ Minor" "1A"
    replace "E♭ Minor" "2A"
    replace "B♭ Minor" "3A"
    replace "F Minor" "4A"
    replace "C Minor" "5A"
    replace "G Minor" "6A"
    replace "D Minor" "7A"
    replace "E Minor" "9A"
    replace "B Minor" "10A"
    replace "F# Minor" "11A"
    replace "D♭ Minor" "12A"
    replace "B Major" "1B"
    replace "F# Major" "2B"
    replace "D♭ Major" "3B"
    replace "A♭ Major" "4B"
    replace "E♭ Major" "5B"
    replace "B♭ Major" "6B"
    replace "F Major" "7B"
    replace "C Major" "8B"
    replace "G Major" "9B"
    replace "D Major" "10B"
    replace "A Major" "11B"
    replace "E Major" "12B"
### MISSING CAMELOT SCALES ###
    replace "G# Minor" "1A"
    replace "A# Minor" "3A"
    replace "C# Minor" "12A"
What I need is all the remaining Camelot notations to match the missing scales. So.....
QUOTE (chriswike @ Jan 28 2012, 01:28) *
Damn stevehero, this last update made my favourite Script even better....
Thanks 'chriswike' for pointing that out. I had already noticed that but not gotten round to modifying the action which will no longer be needed once I have the script finished. I have everything working.
I just need to find out:
How you came about these values?
The other values I have noticed missing such as 'D# Minor'?
Are there other values that I should be aware of that are missing?
+Quote Post
DetlevD
post Feb 1 2012, 05:35
Post #26
Member
Group: Full Members
Mp3tag Version: 2.85
QUOTE (stevehero @ Feb 1 2012, 04:12) *
... I just need to find out:
How you came about these values? The other values I have noticed missing such as 'D# Minor'?
It sounds that You have to learn some basics of musical theory.
There are many sources to hear and read about, e. g. school lessons and ... wikipedia.
The sharp version ...
http://de.wikipedia.org/wiki/Quintenzirkel
http://en.wikipedia.org/wiki/Circle_of_fifths
Especially understand "Relation with chromatic scale" and "Enharmonics".
The flat version ...
http://www.musicians-place.de/harmonielehr...ntenzirkel.html
http://www.musicians-place.com/harmonics/c...-of-fifths.html
DD.20120201.0535.CET
This post has been edited by DetlevD: Feb 1 2012, 05:36
+Quote Post
chriswike
post Feb 1 2012, 13:02
Post #27
Member
Group: Members
CODE
Major
1B      B/H
2B      F#
3B      D♭/C#
4B      A♭/G#
5B      E♭/D#
6B      B♭/A#
7B      F
8B      C
9B      G
10B     D
11B     A
12B     E
Minor
1A      a♭/g#
2A      e♭/d#
3A      b♭/a#
4A      f
5A      c
6A      g
7A      d
8A      a
9A      e
10A     b/h
11A     f#
12A     d♭/c#
Basically, notes that sound the same are written differently because they have a different function beyond just sound.
http://en.wikipedia.org/wiki/Enharmonic_change
That should explain some
Please ask any questions you have about
This post has been edited by chriswike: Feb 1 2012, 13:11
+Quote Post
stevehero
post Feb 1 2012, 21:31
Post #28
Member
Group: Full Members
QUOTE (DetlevD @ Feb 1 2012, 04:35) *
Thanks DetlevD, I have studied music production, only for a 13 weeks on a 1 week basis. Maybe I was asleep during the Music Theory class :] only joking. I got it now its basically the fact that there not listed on the Mixedinkey wheel which threw me slightly.
An example of a beatport lists a track as been in the key
D♯ Minor (Harmonic Scale) = E♭ Minor (Harmonic Scale) = 2A (Camelot Notation)
Its the same root key. Different function. Different name. Its all coming back to me now.
Here is the list I have below in the script (Should be finished tonight 01.02.2012):
replace "G♯ Minor" "1A" # SAME KEY #
replace "D♯ Minor" "2A" # SAME KEY #
replace "A♯ Minor" "3A" # SAME KEY #
replace "F♯ Minor" "11A"
replace "C♯ Minor" "12A" # SAME KEY #
replace "F♯ Major" "2B"
replace "C♯ Major" "3B" # SAME KEY #
replace "G♯ Major" "4B" # SAME KEY #
replace "D♯ Major" "5B" # SAME KEY #
replace "A♯ Major" "6B" # SAME KEY #
This post has been edited by stevehero: Feb 2 2012, 04:26
+Quote Post
stevehero
post Feb 1 2012, 21:37
Post #29
Member
Group: Full Members
QUOTE (chriswike @ Feb 1 2012, 12:02) *
I think my mind had brain freeze. I have studied Electronic music Production. Problem solved. Thanks for your help.
+Quote Post
lalaland
post Feb 2 2012, 20:24
Post #30
Member
Group: Full Members
QUOTE (stevehero @ Oct 5 2011, 00:07) *
V1.3
ADDED: camelot notation change to INITIAL KEY field. e.g. 'G♯ Minor' becomes '1A'.
But i dont see download link...
This post has been edited by lalaland: Feb 2 2012, 20:28
+Quote Post
0 Members:
RSS Lo-Fi Version Time is now: 17th January 2018 - 22:49
