IPB
30 Pages V  < 1 2 3 4 5 > »
> beatport.com scripts by stevehero (search & direct) - jaimz mod, rips cover, album, year, date, catalog #, publisher, genre, www + more
stevehero
post Feb 2 2012, 23:38
Post #31
Member
Group: Full Members
Mp3tag Version: 2.84
QUOTE (lalaland @ Feb 2 2012, 19:24) *
But i dont see download link...
Thank you. Link is now available in the starting post here.
Go to the top of the page
+Quote Post
bmfholland
post Feb 6 2012, 21:47
Post #32
Member
Group: Full Members
Mp3tag Version: 2.47a
Wow, amazing script!
only darktechno..
+Quote Post
stevehero
post Apr 12 2012, 00:51
Post #33
Member
Group: Full Members
v2.0 NOW HERE >>>> Click here for starting post
Single track parsing of beatport.com
It will grab info much the same as my previous version for releases. See example track page here:
www.beatport.com/track/funky-vodka-original-mix/3289193
It will enable single track parsing with:
- SINGLE TRACK Direct by BEATPORT_TRACK_ID
- SINGLE TRACK Direct by WWW(URL)
- SINGLE TRACK Search by (Album)Artist + Title
- SINGLE TRACK Search by Title
This post has been edited by stevehero: May 3 2012, 02:06
+Quote Post
stevehero
post May 1 2012, 02:14
Post #34
Member
Group: Full Members
Download 'beatport_by_stevehero_v2.0' at starting post here.
This post has been edited by stevehero: May 1 2012, 05:34
+Quote Post
Purpleasbestos
post May 3 2012, 17:30
Post #35
Member
Group: Members
Mp3tag Version: 2.50
thank you for the excellent script! I've been using a couple other ones but nothing works as well for my d&b collection smile.gif
I've been trying to remove the total tracks after the track number and can't seem to figure it out...so I am getting:
Track:
01/04
02/04
03/04
04/04
where I am trying to remove the 04 from each track number, but I have tried adding the # in front of the totaltrack's output and also removing the # at the bottom of the script from the totaltracks, but can't seem to get rid of it without removing the 0's from the front of the number of the single tracks, so the best i can get is
1
2
3
4
but I want to keep the 0's in front of the single tracks...
Hope this makes since...
You've made it so much easier to catalog my music smile.gif Thank you
+Quote Post
stevehero
post May 3 2012, 18:53
Post #36
Member
Group: Full Members
QUOTE (Purpleasbestos @ May 3 2012, 17:30) *
where I am trying to remove the 04 from each track number, but I have tried adding the # in front of the totaltrack's output and also removing the # at the bottom of the script from the totaltracks, but can't seem to get rid of it without removing the 0's from the front of the number of the single tracks.
If you want TRACK to be 01, 02, 03 etc
See code after # TOTALTRACKS (Delete the lines that are strikedthrough)
# TOTALTRACKS
outputto "totaltracks"
sayregexp "(\d+)$"
# TRACK / TOTALTRACKS
outputto "beatport stevehero track / totaltracks temp"
sayuntil "|"
say "/"
sayregexp "(\d+)$"
if "|"
do
say "|"
movechar 1
sayuntil "|"
say "/"
sayregexp "(\d+)$"
while "|"
endif
unspace
sayregexp "(\d+)$"
say "|"
# TRACK
outputto "beatport stevehero track temp"
sayrest
say "|"
# TRACK FIX: TRACK
outputto "Title"
sayoutput "Tracks"
outputto "Track"
sayoutput "beatport stevehero track temp"
set "beatport stevehero track temp"
If you want to remove the
TOTALTRACKS output simply block out the lines here like:
# TOTALTRACKS
# outputto "totaltracks"
# sayregexp "(\d+)$"
This post has been edited by stevehero: May 3 2012, 19:02
+Quote Post
stevehero
post May 8 2012, 15:37
Post #37
Member
Group: Full Members
New version up. Problem with release below where there was no track key. Thanks to Pone for spotting it.
V2.1
FIXED: Releases with missing keys (see example www.beatport.com/release/you-know-what-its-like/892120).
SEE STARTING POST HERE
+Quote Post
lalaland
post May 10 2012, 18:56
Post #38
Member
Group: Full Members
Mp3tag Version: 2.49b
Hello stevehero, thanks again for excellent add on. I have suggestion: can you make the settings like R E M O V E F I E L D S will be global to all scripts (ie. in external file)?
This post has been edited by lalaland: May 10 2012, 18:57
+Quote Post
stevehero
post May 10 2012, 20:31
Post #39
Member
Group: Full Members
QUOTE (lalaland @ May 10 2012, 18:56) *
You mean like Pones External settings?
My knowledge of doing such a task isn't quite there yet and I think I probably won't end up doing such settings because I think the script works fine without them.
The best I can do is point you in the direction of a very usefull freeware app notepad++. It's like notedpad, but better.
Steps in changing settings quick:
1. Download & Install notepad++ HERE
2. Open all my scripts at the same time.
3. Highlight the line for example '# set "catalog #"'
4. Hit Ctrl+H
5. Type in the 'Replace box' ' set "catalog #"'
6. Click 'Replace All in All Opened Documents'
This will deactivate ALL the CATALOG # fields if you want.
This post has been edited by stevehero: May 10 2012, 20:36
+Quote Post
lalaland
post May 12 2012, 19:00
Post #40
Member
Group: Full Members
QUOTE (stevehero @ May 10 2012, 21:31) *
That is okay for me, thanks for tip.
Also, I found a little problem: if genre consist of two words it is stored in tag inversely (ie. "Tech House" becomes "House Tech".
+Quote Post
stevehero
post May 12 2012, 20:41
Post #41
Member
Group: Full Members
QUOTE (lalaland @ May 12 2012, 19:00) *
That's fully intentional. I prefer it that way because I can have all my housey genres easily sortable within any music software.
But for your needs delete all the replace functions which are striked-through:
# GENRE
outputto "Genre"
findline "</label>" 1 1
moveline 1
unspace
if "<genre "
joinuntil "</genre>"
replace "Deep House" "House Deep"
replace "Electro House" "House Electro"
replace "Minimal" "House Minimal"
replace "Progressive House" "House Prog"
replace "Tech House" "House Tech"
replace "Vocal House" "House Vocal"
findinline "<name>"
sayuntil "</"
endif
say "|"
This post has been edited by stevehero: May 12 2012, 20:42
+Quote Post
lalaland
post May 13 2012, 09:59
Post #42
Member
Group: Full Members
QUOTE (stevehero @ May 12 2012, 21:41) *
Oh, I see. Thanks for solution!
+Quote Post
The Zyc
post May 23 2012, 20:13
Post #43
Member
Group: Full Members
Mp3tag Version: v2.39
Hello Stevehero...
at first, big thanks for you and a huge praise for the script.
so far I have edited my collection with the discogsscript and changed it for my taste
i had merged the LABEL (First Information) and CATALOG (second information) in the column "CONTENTGROUP" with square brackets
Example: [Strictly Rhythms / STRV06D]
I had trying to change it but unfortunately without success
Please can you help me?
Sorry for my bad english...
+Quote Post
stevehero
post May 24 2012, 01:55
Post #44
Member
Group: Full Members
QUOTE (The Zyc @ May 23 2012, 20:13) *
at first, big thanks for you and a huge praise for the script...
Thank you for your kind words. I can understand your needs okay. Make sure you place the code below between the headings below in the script while keeping the existing lines of code.
CODE
#        .:: C U S T O M I Z A T I O N    S T A R T S ::.        #
# CONTENTGROUP
    outputto "Contentgroup"
    say "["
    sayoutput "publisher"
    say " / "
    sayoutput "catalog #"
    say "]"
#        .:: C U S T O M I Z A T I O N    E N D S ::.            #
You should find this section towards the bottom of the script.
+Quote Post
The Zyc
post Jun 3 2012, 13:21
Post #45
Member
Group: Full Members
+Quote Post
0 Members:
RSS Lo-Fi Version Time is now: 17th January 2018 - 22:51
