IPB
11 Pages V  < 1 2 3 4 > »
> [WS] Import lyrics from websites, web sources scripts
Starman
post Dec 13 2006, 19:20
Post #16
Member
Group: Members
Mp3tag Version: 5.3
I'm having trouble adding this script. When I look for the folder .../Application Data/mp3Tag, I can't find it. I have hidden folders/files shown turned on, and I've also tried to go to the folder directly by typing in the generic path in the address window. I'm using mp3Tag version 5.3 Build 3.73. Is there something I've haven't done correctly in the installation of mp3Tag? It appears to work fine.
Go to the top of the page
+Quote Post
dano
post Dec 13 2006, 19:42
Post #17
Moderator
Group: Moderators
Mp3tag Version: 2.84c
Sorry but you are using a different program.
This here is about http://www.mp3tag.de/en/
+Quote Post
ikaritw
post Aug 11 2007, 20:40
Post #18
Member
Group: Members
Mp3tag Version: 2.39
Hi dano
Thank for the Mp3tag.It`s a great programe to make the tag-editing easiliest.
I get some trouble while use the web-source function.
I try to find the lyrics for the album Invincible of Michael Jackson
there is the script i write to parses:
http://so61.com/bin/cgi/find.php?album=Invincible&singer=Michael%20Jackson
After parses i get the [ParserScriptAlbum] will be :http://so61.com/bin/db/album.php?a=1011102JE
it`s quite easy to set the first lyric to the "UNSYNCEDLYRICS",
but when it put the 2nd lyric into the "UNSYNCEDLYRICS",
it`s fail to put the whole lyric into "UNSYNCEDLYRICS",
Do the "UNSYNCEDLYRICS" has the max queta?
And,
Is the "findline" function can`t recognize the chniese char?It`s seem not to parses the chniese char.
The scrpit is write for collect the all lyric of one album to the select songs.It might work if the queta problem is solved.
Attached File(s)
+Quote Post
loswillios
post Sep 13 2007, 14:19
Post #19
Member
Group: Members
I have c'n'p together a script for seeklyrics.com. It displays only the first 20 hits cause I don't know how to handle "next" :P Also, ID3-Tags with hyphens aren't parsed correctly.
thanks for the great framework!
PS: I need a good site to parse for punk lyrics. anyone?
This post has been edited by loswillios: Sep 13 2007, 14:25
Attached File(s)
+Quote Post
Elfo
post Oct 8 2007, 16:01
Post #20
Member
Group: Full Members
I just wanted to say thank you for this wonderful program, and in particular for these lyric src's. They've made my life much easier.
+Quote Post
icelus
post Dec 5 2007, 22:15
Post #21
Member
Group: Full Members
Mp3tag Version: 2.47a
I'm just starting to get the hang of using this program, so perhaps I'm doing something wrong, but...
Using the Magistrix source for lyrics, is it not possible to get more than the first fifty results? For instance, I was trying to snatch the lyrics for "Awake" by Josh Groban, but the first fifty results end in the D's.
+Quote Post
dano
post Dec 5 2007, 22:54
Post #22
Moderator
Group: Moderators
Yes the limit currently is 50. The site allows 100 maximum.
You can change it to 100 if you open the file in a text editor and search for pagelen=50 and change it to pagelen=100
I can also make a version that searches by title and artist which should give more accurate results.
+Quote Post
DetlevD
post Dec 5 2007, 22:56
Post #23
Member
Group: Full Members
Mp3tag Version: 2.85
I suggest to make a small change in the file "Lyrics#magistrix.src":
CODE
#[IndexUrl]=http://www.magistrix.de/lyrics/search?title=%s&lang=0&artist=&pagelen=50&text=&order=artist&submit=Suche+l%E4uft+...
[IndexUrl]=http://www.magistrix.de/lyrics/search?title=%s&lang=0&artist=&pagelen=100&text=&order=title
DD.20071205.2256.CET
This post has been edited by DetlevD: Dec 5 2007, 22:57
+Quote Post
icelus
post Dec 18 2007, 02:28
Post #24
Member
Group: Full Members
+Quote Post
icelus
post Feb 14 2008, 03:27
Post #25
Member
Group: Full Members
The script for Sing365.com doesn't seem to be working anymore. I removed the :8080 part from the search URL, but... whenever I get results, it says "UNSYNCEDLYRICS <Error>"
+Quote Post
dano
post Feb 14 2008, 14:02
Post #26
Moderator
Group: Moderators
Update for sing365
+Quote Post
Talyn
post Mar 3 2008, 15:15
Post #27
Member
Group: Members
Mp3tag Version: 2.43
I'm apparently not understanding how this one works, or I've got something setup wrong...
I've installed the Sing365 .src so far and added UNSYNCHEDLYRICS to my tag panel but when I use the web source I only get the very first line, usually the writer credits, not the full lyrics.
+Quote Post
dano
post Mar 3 2008, 16:42
Post #28
Moderator
Group: Moderators
Again update for sing365
Talyn, please download it again, it wasn't working properly any more.
+Quote Post
icelus
post Nov 2 2008, 23:46
Post #29
Member
Group: Full Members
I can't seem to get any results from either sing365 or Magistrix anymore. Actually, none of the lyrics sources available here on the forum seem to work for me at all... sad.gif
+Quote Post
Germini
post Nov 20 2008, 04:36
Post #30
Member
Group: Members
Mp3tag Version: 2.42
+Quote Post
0 Members:
RSS Lo-Fi Version Time is now: 17th January 2018 - 22:42
