IPB
11 Pages V  « < 9 10 11
> [WS] Import lyrics from websites, web sources scripts
Paul98
post Feb 6 2016, 15:08
Post #151
Member
Group: Full Members
Mp3tag Version: 2.70
Good day.
I use this script:
My music collection primarily consists of hip-hop or rap songs, so i use this script and therefore genius.com because there are almost all of the lyrics to my songs.
Following problem:
Example:
I want to import the lyrics of "Deep Cover (feat Snoop Doggy Dogg.) - Dr Dre"
Now if I want to import the lyricswith this script, I have the problem.
Now the Scipt search for "Dr. Dre-Deep Cover (Feat. Snoop Doggy Dogg)-lyrics".
But now I have to remove manually "(Feat. Snoop Doggy Dogg)"because otherwise no result is found.
Wrong Search "Dr. Dre-Deep Cover (Feat. Snoop Doggy Dogg)-lyrics"
It would be correct, "Dr. Dre-Deep Cover-lyrics"
How do I have to change the script so it automatically remove the brackets and the content in the brackets (the featuring) ?
This post has been edited by Paul98: Feb 6 2016, 15:10
Go to the top of the page
+Quote Post
poster
post Feb 7 2016, 09:09
Post #152
Member
Group: Full Members
Mp3tag Version: 2.85k
QUOTE (Paul98 @ Feb 6 2016, 15:08) *
You have to change the row:
[SearchBy]=$caps(%artist%)-$replace($caps(%title%,'(' ),&,%%26,Feat)-lyrics
to your needs. As the search string depends on the values of your tags ARTIST and TITLE, what you have to change depends on how these both tags are filled.
This post has been edited by poster: Feb 7 2016, 09:10
+Quote Post
DetlevD
post Feb 7 2016, 10:38
Post #153
Member
Group: Full Members
... remove manually "(Feat. Snoop Doggy Dogg)" because otherwise no result is found. ... How do I have to change the script so it automatically remove the brackets and the content in the brackets (the featuring) ?
Because of the same question in the german forum, you can find additional answers over there ...
https://forums.mp3tag.de/index.php?showtopic=20811
DD.20160207.1038.CET
+Quote Post
Mihawk90
post Mar 12 2016, 15:42
Post #154
Member
Group: Full Members
Mp3tag Version: 2.80
I don't know if it's something that should be added to the lyricWiki script by default, but I had a little issue with the ’ sign in titles (imported from MusicBrainz cause it's the convention there...), so I added another replace in Line 17:
from
CODE
[SearchBy]=$caps(%artist%,- ):$regexp($replace($caps(%title%,'('- ),&,'%26',?,'%3F'),( '')(\l),$1\u$2)
to
CODE
[SearchBy]=$caps(%artist%,- ):$regexp($replace($caps(%title%,'('- ),&,'%26',?,'%3F',’,$char(39)),( '')(\l),$1\u$2)
This post has been edited by Mihawk90: Mar 12 2016, 15:43
+Quote Post
DetlevD
post Mar 12 2016, 15:55
Post #155
Member
Group: Full Members
QUOTE (Mihawk90 @ Mar 12 2016, 15:42) *
... I had a little issue with the ’ sign in titles (imported from MusicBrainz cause it's the convention there...), so I added another replace in Line 17:
from
[SearchBy]=$caps(%artist%,- ):$regexp($replace($caps(%title%,'('- ),&,'%26',?,'%3F'),( '')(\l),$1\u$2) ...
It seems better to be read and understand ...
when writing the problematic character ’ as $char(146) ...
[SearchBy]=$caps(%artist%,- ):$regexp($replace($caps(%title%,'('- ),&,'%26',?,'%3F',$char(146),$char(39)),( '')(\l),$1\u$2)
... or ...
[SearchBy]=$caps(%artist%,- ):$regexp($replace($caps(%title%,'('- ),'&','%26','?','%3F','’','%27'),( '')(\l),$1\u$2)
... hopefully without colliding with the apostrophe, which is used as the string delimiter within Mp3tag.
DD.20160312.1616.CET
This post has been edited by DetlevD: Mar 12 2016, 16:16
+Quote Post
Mihawk90
post Mar 12 2016, 23:35
Post #156
Member
Group: Full Members
Yeah, I used $char(39) because I had some issues with the regular apostrophe. Might as well use the $char function for the first character too, good point.
+Quote Post
jonathan99
post Apr 23 2016, 20:31
Post #157
Member
Group: Members
Mp3tag Version: 2.69
The LyricWiki did not work anymore for me.
Looks like the <script> tag is gone.
I made some adjustments which works for me.
This post has been edited by jonathan99: Apr 23 2016, 21:06
Attached File(s)
+Quote Post
marjiea1
post May 5 2016, 07:29
Post #158
Member
Group: Members
Mp3tag Version: 2.68
Update for MetroLyrics
Won't work for multiple artist names, you will have to manually remove one and any separators in the query box that comes up before you search.
+Quote Post
dweller
post Jun 9 2016, 20:35
Post #159
Member
Group: Members
Mp3tag Version: 2.57
Is there available script or anyone willing/able to make script for AZlyrics.com or sing365.com?
+Quote Post
Victor Kostas
post Aug 24 2016, 23:17
Post #160
Member
Group: Full Members
Mp3tag Version: 2.80c
QUOTE (dweller @ Jun 9 2016, 21:35) *
Here it is AZlyrics for you. Fresh based on dano's scripts.
Attached File(s)
+Quote Post
l0bzt3r
post Oct 21 2016, 16:39
Post #161
Member
Group: Members
Mp3tag Version: 2.79
QUOTE (Kien @ Jan 15 2016, 06:39) *
I have updated the code for Genius.com , replace the <div class="lyrics_container"> in the original script (previously posted by @tbum20) to <div class="song_body"> and seems like it's good to go
[attachment=6395:Lyrics_GENIUS.src]
I have updated the code for Genius.com , replace the "<div class="song_body">" in the original script (previously posted by @Kien) to "<div class="song_body-lyrics">".
Added removal content in div avoid-selection class.
Tested working on 2016-10-21.
Attached File(s)
+Quote Post
Alessander
post Aug 5 2017, 09:52
Post #162
Member
Group: Members
Can someone make a script for Musixmatch ?
like this page
https://www.musixmatch.com/lyrics/Cheka/Querida
+Quote Post
blobber
post Oct 1 2017, 17:57
Post #163
Member
Group: Full Members
Mp3tag Version: 2.84a
QUOTE (Alessander @ Aug 5 2017, 10:52) *
like this page
I just started scripting yesterday and tried to create some scripts for missing but useful websites for lyrics. Also musixmatch.com wink.gif
So here are the scripts for lyrictranslate.com, golyr.de and musixmatch.com. As I just started scripting with this framework yesterday, I'm up to tips and improvements from your side! smile.gif
Note: musixmatch.com worked for me for maybe the first 200 songs. After that google blocked my IP from using the site and asked for a captcha to prove that I'm not a bot. dry.gif I'm not sure how to solve this yet, apart from using another IP.
Attached File(s)
+Quote Post
0 Members:
RSS Lo-Fi Version Time is now: 17th January 2018 - 22:48
