IPB
11 Pages V  < 1 2 3 4 5 > »
> [WS] Import lyrics from websites, web sources scripts
The_Original_Inv...
post Jan 22 2009, 11:30
Post #31
Member
Group: Full Members
Mp3tag Version: v2.49
I have a problem with the Lyric Wiki script, and I'm not sure how to correct it.
It's from Dano and I downloaded it last week
It seems to find the song lyrics OK but they don't appear in the "Additional Information" box in the "Adjust Tag Information" form.
I know that it's finding the lyrics I'm after because when I click the link to "This album on Lyric Wiki" it displays the XML file
Any help greatly appreciated
Lee
This post has been edited by dano: Jan 22 2009, 11:46
Go to the top of the page
+Quote Post
dano
post Jan 22 2009, 11:48
Post #32
Moderator
Group: Moderators
Mp3tag Version: 2.84c
Lyrics Wiki script needs at least Mp3tag v2.42a
+Quote Post
The_Original_Inv...
post Jan 22 2009, 12:20
Post #33
Member
Group: Full Members
QUOTE (dano @ Jan 22 2009, 10:48) *
Yep. Downloaded 2.42c and working fine. Thanks very much!
Lee
+Quote Post
gnor
post Apr 5 2009, 01:29
Post #34
Member
Group: Full Members
Mp3tag Version: 2.46
Hello,
I want to unterstand the "Lyrics#leoslyrics.src" and there are 2 things I don´t understand.
1. What does "regexpreplace "&#xD;" "\r\n""?
2. Why mp3tag reads the two spaces as a newline?
(I think \r\n are symbols for newline. Probably there is a connection between these two questions.)
gnor
Probleme bei Windows: REBOOT, Probleme bei Linux: BE ROOT
+Quote Post
ahughes
post Apr 29 2009, 15:45
Post #35
Member
Group: Members
Mp3tag Version: 2.43
I'm not sure how the scripting works, but is it possible to be able to grab lyrics from http://www.ohhla.com/? There is no search function, so perhaps it is not doable. However, if it is possible, I would greatly appreciate it.
Thanks for all of your work.
AH
+Quote Post
DetlevD
post Apr 29 2009, 17:07
Post #36
Member
Group: Full Members
Mp3tag Version: 2.85
Should be simple work for the src coders.
On http://www.ohhla.com there are some directory pages with lists of artists:
#: http://www.ohhla.com/all.html#xx
a: http://www.ohhla.com/all.html#a
b: http://www.ohhla.com/all.html#b
c: http://www.ohhla.com/all.html#c
d: http://www.ohhla.com/all.html#d
e: http://www.ohhla.com/all.html#e
f: http://www.ohhla.com/all.html#f
g: http://www.ohhla.com/all.html#g
h-o: http://www.ohhla.com/all_two.html
p-z: http://www.ohhla.com/all_three.html
Once you have found an artist that exists you can build the accesspath to the artist:
http://www.ohhla.com/anonymous/assassin/
... then to the album:
http://www.ohhla.com/anonymous/assassin/homicide/
... then to the text file:
http://www.ohhla.com/anonymous/assassin/ho...abylone.ass.txt
Get the textfile and ready.
DD.20090429.1806.CEST
+Quote Post
ahughes
post Apr 30 2009, 17:42
Post #37
Member
Group: Members
Thanks DetlevD for looking into the directory structure. Hopefully this can be programmed for all of us hip hop fans (however many there are).
AH
+Quote Post
icelus
post Aug 17 2009, 11:39
Post #38
Member
Group: Full Members
Mp3tag Version: 2.47a
LyricsWiki seems to no longer support Web Source Scripts:
"Unfortunately, due to licensing restrictions from some of the major music publishers we can no longer return lyrics through the LyricWiki API (where this application gets some or all of its lyrics).
The lyrics for this song can be found at the following URL:
some url
(Please note: this is not the fault of the developer who created this application, but is a restriction imposed by the music publishers themselves.)"
Currently I'm having no luck with any of the available lyrics script.s sad.gif
This post has been edited by dano: Aug 17 2009, 11:57
+Quote Post
dano
post Aug 17 2009, 13:35
Post #39
Moderator
Group: Moderators
I made an update for lw, now it's uploaded.
+Quote Post
Mycow
post Sep 12 2009, 02:14
Post #40
Member
Group: Members
Mp3tag Version: v2.44
Unfortunately the darklyrics script is not working properly...
It is a really helpful script and it works perfectly sometimes, for example the band Blind Guardian, but with others it doesn't, like Grave Digger or Annihilator, even though the lyrics are on the website and when I click on "This album on Darklyrics" it redirects me to the correct page. It shows under additional information: UNSYNCEDLYRICS <Error>.
+Quote Post
dano
post Sep 12 2009, 08:53
Post #41
Moderator
Group: Moderators
I have updated Darklyrics.
This post has been edited by dano: Sep 12 2009, 08:55
+Quote Post
disaster
post Sep 20 2009, 14:27
Post #42
Member
Group: Full Members
Mp3tag Version: 2.44
I had a problem with getting the lyrics for this album (DarkLyrics):
http://www.darklyrics.com/lyrics/dawnrider...callingpti.html
For whatever reason the html code of that pages misses a blank line after the <br><br> line break tags (as assumed by the darkLyrics script), so the following line of code dind't work for me in this case:
CODE
    moveline 2 1
To solve my problem, I replaced the code with the following lines:
CODE
    moveline 1 1
    unspace
    ifNot "<a "
        moveline 1 1
        unspace
    endif
This should be edited in both, the if "<FONT"- and its else-statement.
Greetings,
Christian
BTW. What is the second parameter of moveline for?
This post has been edited by disaster: Sep 20 2009, 14:31
+Quote Post
dano
post Sep 21 2009, 14:38
Post #43
Moderator
Group: Moderators
Thanks, I used a little different fix.
QUOTE
If moveline goes into an empty line, it will cause an error.
With the second parameter I can ignore this error.
+Quote Post
disaster
post Sep 21 2009, 19:32
Post #44
Member
Group: Full Members
Thanks for the answer and for the great DarkLyrics script of course! Sad it's the only possibility for tagging complete albums...
+Quote Post
RoksVempire
post Nov 15 2009, 21:43
Post #45
Member
Group: Members
Mp3tag Version: 2.38
Hi!
Thx for this fantastic script!
So, one question, how to get lyrics of the entire album...
Song by song is a little long work...
+Quote Post
2 User(s) are reading this topic (2 Guests and 0 Anonymous Users)
0 Members:
RSS Lo-Fi Version Time is now: 25th November 2017 - 08:48
