IPB
> Notice!
> Is is possible to have mp3tag do a "walk"?
ms6676749
post Mar 19 2017, 03:24
Post #1
Member
Group: Full Members
Mp3tag Version: 2.75
Every track in a directory has a unique refid that is tied to a DB containing per song metadata. I figured out how to do issue a no-confirm command (unchecked "show message after save" and issued the appropriate key strokes [two enter keystrokes]) and would like to perform a "walk" down the list. Can mp3tag do this or can direct me another forum post here or elsewhere where a 3P program, say autohotkey or something, can do the trick?
EDIT: Here's a quick autohotkey script that does the trick, but it is an infinite loop and the break key isn't responsive. Does anyone have any other suggestions?
EDIT 2: I removed the infinite loop and replaced it with a prompt asking the number of tracks which to run the script. It should be number larger than the number of tracks on the album.
CODE
#q::
    BreakLoop = 1
    return
#s::
#IfWinActive ahk_exe Mp3tag.exe; for &A music source#&1 &Song Info.src
InputBox, times, Number of tracks (more than on album)
    if (times > 0); test if it is a number
        Loop % times
            if (BreakLoop = 1)
                break
            Send !s; alt+s to bring up tag sources menu
            Send a; Select &A music source
            Send s; Select &Song Info
            Send {Enter}
            Send {Enter}
            Sleep 1000; Pause for server lookup
            Send {Down}; Next file
        }    return
Video of the autohotkey in action: https://youtu.be/itrzHlqzs9U
This post has been edited by ms6676749: Mar 19 2017, 23:50
Go to the top of the page
+Quote Post
ohrenkino
post Mar 19 2017, 10:24
Post #2
Member
Group: Full Members
Mp3tag Version: 2.81b
I think that some mouse drivers have an auto-scroll function when you press the mouse wheel.
+Quote Post
ms6676749
post Mar 19 2017, 16:28
Post #3
Member
Group: Full Members
QUOTE (ohrenkino @ Mar 19 2017, 11:24) *
+Quote Post
ohrenkino
post Mar 19 2017, 16:35
Post #4
Member
Group: Full Members
ZITAT(ms6676749 @ Mar 19 2017, 16:28) *
Does not really help.
Perhaps you have a look at your description and explain it again if the answers are not what you expected.
For me a "walk" looks a lot like scrolling through the data. That is why I gave that answer.
This post has been edited by ohrenkino: Mar 19 2017, 16:35
+Quote Post
Florian
post Mar 19 2017, 18:00
Post #5
Developer
Group: Admin
Selecting the next file (i.e., "walk") can be done via the [Ctrl+N] keyboard shortcut (or via Edit > Select next file).
By the way, you can disable the notification message after saving tags at Options > Messages.
Kind regards
– Florian
+Quote Post
ms6676749
post Mar 19 2017, 20:07
Post #6
Member
Group: Full Members
QUOTE (ohrenkino @ Mar 19 2017, 17:35) *
I guess I should've been clearer since a "walk" AFAIK typically means a command/task will be executed on each item on a list.
Here, the "list" is the tracklist in mp3tag's main window and the task to be executed on each track in sequential order is a websource script querying a unique SONG_ID associated for each track. So, I cannot select-all and run the websource script because the results will only reflect that of what mp3tag queries from the first track on the list.
I forgot that I asked a similar question last year (in greater detail) at a time I was coming to grips with mp3tag's scripting language: https://forums.mp3tag.de/index.php?showtopi...ost&p=91338
Your reply back then, even if it was honest, wasn't too helpful and I gave up and found a way to tie keystroke sequences to mouse gestures. Unfortunately, I still had to manually press the down arrow to process the next track. It was fine for a single artist album, but I balked at doing it for large box sets (>100 songs each). The autohotkey idea came from troubleshooting someone's issue in another forum and I decided to try it out and it appears to have worked.
QUOTE (Florian @ Mar 19 2017, 19:00) *
Kind regards
– Florian
Hi Florian,
That's good to know. You are correct that confirmation messages can be disabled under settings (I found the information here via google). I didn't know about the CTRL+N shortcut. Thankfully, the 3P programs I used support sending [down arrow] keystroke inputs to mp3tag.
I had a problem delaying the [down arrow] keystroke when assigning a keystroke sequence to run a web source script via a mouse gesture (strokeit). The [down arrow] input when the sequence is executed is washed out since the metadata lookup takes a second or two. StrokeIt's documentation doesn't say if certain keystrokes can be delayed.
However, this is not a StrokeIt support forum and thankfully I found out just the other day that Autohotkey does support delays between strokes (see the 1st post). As you probably guessed by now, I believe I answered my own question with the help of Autohotkey. I just wanted to share the autohotkey hotkey I wrote in case somebody else finds it useful.
For example, someone might use it to call a last.fm websource run through the tracklist to obtain per track moods and other song-specific metadata as the hotkey works its way down the entire tracklist.
Cheers
This post has been edited by ms6676749: Mar 19 2017, 20:08
+Quote Post
ohrenkino
post Mar 19 2017, 21:47
Post #7
Member
Group: Full Members
ZITAT(ms6676749 @ Mar 19 2017, 20:07) *
... I didn't know about the CTRL+N shortcut....
Here is a list of keyboard shortcuts for functions:
http://help.mp3tag.de/main_keyboard.html
+Quote Post
ms6676749
post Mar 19 2017, 23:36
Post #8
Member
Group: Full Members
QUOTE (ohrenkino @ Mar 19 2017, 22:47) *
I've seen that page before and referred to it numerous times but I never looked for a short-cut for next file because the programs I used supported sending a down_arrow keystroke to a running instance of mp3tag. Still, it wouldn't hurt to try it.
Anyways, FWIW, here's my autohotkey "walk" down a list of files adding per track mood data and reviews: https://youtu.be/itrzHlqzs9U
This post has been edited by ms6676749: Mar 19 2017, 23:37
+Quote Post
0 Members:
RSS Lo-Fi Version Time is now: 30th March 2017 - 07:43
