IPB
30 Pages V  « < 26 27 28 29 30 >
> beatport.com scripts by stevehero (search & direct) - jaimz mod, rips cover, album, year, date, catalog #, publisher, genre, www + more
djepeto
post Apr 13 2017, 22:11
Post #406
Member
Group: Full Members
Mp3tag Version: 2.81
Yes, I checked that. I haven't folder.jpg. When I make this file, mp3 without cover get that cover picture. That is ok.
In WMP:
Add local media files to library when played - unchecked
Add remote media files to library when played - unchecked
Only, but only BP pictures for files tagged in last month have problems in wmp.
club music makes me happy
Go to the top of the page
+Quote Post
ohrenkino
post Apr 13 2017, 22:25
Post #407
Member
Group: Full Members
Mp3tag Version: 2.85
In WMP:
I think that you can set the behaviour of saving graphics after the execution of a web source script in the Utils-Menu that is hidden in the button at the bottom of the web sources dialogue.
Perhaps you have unchecked the option to save the picture not only in the files but also in the file system and you have modified the default file name for artwork from folder. jpg to something else.
+Quote Post
djepeto
post Apr 13 2017, 23:34
Post #408
Member
Group: Full Members
Bottom of web source dialog:
Save image to tag - checked
I have changed nothing in file system, because everything works very well.
Shorter description:
WMP (Now playing mode) shows covers for files tagged with discogs script.
WMP (Now playing mode) shows covers for files tagged with BP script except for files tagged in last month.
VLC and winamp shows covers for all files anyway.
When I manualy add picture from BP and save tag, wmp doesnt show the cover again, except if picture from other source is.
+Quote Post
ohrenkino
post Apr 14 2017, 11:14
Post #409
Member
Group: Full Members
To be honst: WMP does not remember the tag sources that you have used for tagging.
And as I cannot look over your shoulder and find out what the differences are, you have to be as cunning as possible to find the cause.
I would check the tag versions that are in the files (APE usually causes trouble), I would check the files themselves for integrity, and I would check if there are more than one embedded picture in the files and perhaps one of them is invalid/empty, whatever.
Or the picture type is not quite right: bmp instead of png or jpg.
+Quote Post
djepeto
post Apr 14 2017, 16:15
Post #410
Member
Group: Full Members
Yes, you're right about everything. My pictures in tags are jpg and only one picture. Tag version is ID3v2.3. Mp3 files is full correct, checked in mp3val.
Please, for test, if you could manualy put any beatport cover picture to any mp3 file (drag and drop way) and play it in wmp to see what will happen?
+Quote Post
ohrenkino
post Apr 14 2017, 18:10
Post #411
Member
Group: Full Members
ZITAT(djepeto @ Apr 14 2017, 17:15) *
... and play it in wmp to see what will happen?
This is what happens:
I d&d (which I usually never do) a picture from BP to Mp3tag's tag panel and save the modification.
The file has now 2 embedded covers.
I delete the old one in MP3tag.
I switch to WMP - it still shows the old picture.
I delete the track only from the library.
I restore deleted files.
(The preview now shows already the new picture)
I play the track and see the new picture in the "now playing" window.
+Quote Post
djepeto
post Apr 14 2017, 19:50
Post #412
Member
Group: Full Members
Thank you very much!
I see I have problem with only JPG from beatport.
For testing I used image resizer and I converted that jpg to another jpg, I used new jpg file, and finally I can see cover in wmp. My new converted cover has same size 500x500, and amost same file size - about 3 KB more.
Conclusion is everything works very well, but still dont know why my new files get different type of jpg from BP whether I use the BP script or manualy put the cover directly from BP.
+Quote Post
zizka90
post Apr 14 2017, 23:05
Post #413
Member
Group: Members
Hey. Thanks for your script. Very satisfied.
Can I change [IndexFormat]? I tried it at me it does not work.
For example, can I delete the first two columns?
Thanks for help.
This post has been edited by zizka90: Apr 14 2017, 23:06
+Quote Post
Palma Beats
post May 30 2017, 14:00
Post #414
Member
Group: Members
Mp3tag Version: 2.82
Thanks so much for this script. So helpful.
This post has been edited by Palma Beats: May 30 2017, 14:05
+Quote Post
ms6676749
post Jun 2 2017, 06:44
Post #415
Member
Group: Full Members
Mp3tag Version: 2.75
QUOTE (zizka90 @ Apr 15 2017, 00:05) *
[snip]
Thanks for help.
Easy, just set [IndexFormat] to
CODE
[IndexFormat]=%_URL%|% ↓ RELEASES%|% ↓ ARTIST/S%|% ↓ REMIXER/S%
Then under "[ParserScriptIndex]=..." comment out (#) sections with # YEAR and and # OUT ON (three lines each).
+Quote Post
C-Dog
post Jun 4 2017, 20:31
Post #416
Member
Group: Full Members
Thank you for that great script! Good work!
Beatport has recently added some new (more accurate) genres like "Uplifting":
https://www.beatport.com/release/destinatio...d-remix/2032449
The script uses the classic version of the webpage, which does not contain the new styles and also not the key of the songs:
http://classic.beatport.com/release/destin...d-remix/2032449
Is there a way to get those two fields (genre + key) information without rewriting the whole script?
+Quote Post
stevehero
post Jun 5 2017, 01:08
Post #417
Member
Group: Full Members
Mp3tag Version: 2.84
QUOTE (C-Dog @ Jun 4 2017, 20:31) *
It already does.
Change:
CODE
   set "INITIALKEY"
to
CODE
#   set "INITIALKEY"
It explains all that in the readme file.
TO EVERYONE
Sorry, I've no plans to do a new beatport version. Over the last 6months, I done a little experiment and placed a donate button beside the DL button and not one single person has given anything. Why should I continue support if no one thinks it's of any value whatsoever? Over the last 5 years and multiple updated versions of this script, it has had 50k+ downloads.
It took a lot of man-hours to learn and write this. I'm pretty happy that it hasn't broken in over 3 yrs now but truth be told I'm sick of people begging on here.
I suppose the same could be said for the dev. of this amazing app. I bet most of the people on here haven't contributed to him. Yet they're the first people to complain and request stuff.
Rant over.
+Quote Post
C-Dog
post Jun 5 2017, 10:21
Post #418
Member
Group: Full Members
Thanks! I just downloaded your script yesterday for the first time and missed that line for the initial key which removes the tag. Now it's working :-)
I used Discogs as source before, but I'm gonna switch to your script now, because there are almost all digital releases available at Beatport and it gives many additional information.
I left you a little donation for it and I hope that others will follow. Very helpful script, keep it up! :-)
+Quote Post
stevehero
post Jun 5 2017, 12:44
Post #419
Member
Group: Full Members
QUOTE (C-Dog @ Jun 5 2017, 10:21) *
If it does come to the point where the script breaks then I'll rewrite the script for BP Pro. I would like the style added myself but it just doesn't warrant a complete rewrite just yet.
+Quote Post
DJJeffHax
post Jul 1 2017, 13:34
Post #420
Member
Group: Full Members
Mp3tag Version: 2.57
Am looking for a script that changes the BPM field.
Currently tags will be written the BPM as a full digit number.
I would like to change it with a action simple script to 1 digit behind the point.
For example 125 should become 125.0
Am tagging with the Beatport Pro tool (working faster for me on Mac and keeps the PC free for other things to do in between) but cleaning up tags and changing fields with MP3Tag.
Anyone?
+Quote Post
0 Members:
RSS Lo-Fi Version Time is now: 24th November 2017 - 06:19
