IPB
7 Pages V  « < 5 6 7
> Export or backup all tag fields
dano
post Jul 13 2014, 10:47
Post #91
Moderator
Group: Moderators
Mp3tag Version: 2.84c
Copy the path from the explorer at the top.
It willl probably be
S:\Tools\Mp3tag\CJ addons\Mp3tagCompleteTags\
Go to the top of the page
+Quote Post
chrisjj
post Jul 13 2014, 22:02
Post #92
Member
Group: Full Members
Mp3tag Version: -
QUOTE (dano @ Jul 13 2014, 10:47) *
That's S:\Tools\Mp3tag
With that, executing the tool apparent does nothing. Where should look for the output?
Same problem.
Also, when I use \Tools\Mp3tag to keep the inatllation portable across drive letters, I get:
+Quote Post
dano
post Jul 13 2014, 23:40
Post #93
Moderator
Group: Moderators
Yes correction, it's the path of the Mp3tag dir and it must end with a backslash:
S:\Tools\Mp3tag\
I don't know if relative paths will work.
+Quote Post
chrisjj
post Jul 13 2014, 23:54
Post #94
Member
Group: Full Members
Mp3tag Version: -
QUOTE (dano @ Jul 13 2014, 23:40) *
S:\Tools\Mp3tag\
Thanks. That gives:
Where should I look for the output?
+Quote Post
Victor Kostas
post Aug 28 2016, 08:21
Post #95
Member
Group: Full Members
Mp3tag Version: 2.80c
QUOTE (dano @ Dec 22 2011, 21:50) *
Dano,
1. Maybe you should foresee a replacement for the tab character inside the tags. I know it is weird someone has TAB inside lyrics or comments but it is not unlikely.
Personally I add $char(9),\t at the end of your $replace function.
2. First two columns are path (folder+filename) and filename.
Did you intend to export folderpath instead of path? Having full filename and filename int the result file is kind of odd.
3. One problem with mte files is the difficulty to manage "endless" lines due to carriage return limitation (it would be output in the result file).
Well, there is a trick for that ($puts command).
CODE
code code code$puts(dummy,ignore the characters including carriage return until right parenthesis
more comments
more comments
)continue code in same output line
This code would just ignore the "block" $puts(dummy,....). Carriage return(s) would be assigned to dummy variable value.
Thx.
+Quote Post
7 Pages V  « < 5 6 7
2 User(s) are reading this topic (2 Guests and 0 Anonymous Users)
0 Members:
RSS Lo-Fi Version Time is now: 23rd January 2018 - 05:07
