IPB
> Error exporting .SFV
vvikkass
post Oct 13 2016, 13:44
Post #1
Member
Group: Full Members
Mp3tag Version: 2.78
I am getting this error,
Trying it in folder containing .m4b files.
Please help.
Go to the top of the page
+Quote Post
ohrenkino
post Oct 13 2016, 15:14
Post #2
Member
Group: Full Members
Mp3tag Version: 2.85
Please help.
Looks like an authorization error.
Check actual owner of the file and access permissions to folder and files.
+Quote Post
vvikkass
post Oct 13 2016, 18:18
Post #3
Member
Group: Full Members
QUOTE (ohrenkino @ Oct 13 2016, 19:44) *
Hi, thanks for your time.
I ran the application as admin, and having full rights to edit the files in that folder.
+Quote Post
ohrenkino
post Oct 13 2016, 18:27
Post #4
Member
Group: Full Members
So you are not the owner?!
To my experience, it is not enough to be admin, you either have to be the owner or full access has to be granted to everybody.
+Quote Post
vvikkass
post Oct 13 2016, 20:36
Post #5
Member
Group: Full Members
QUOTE (ohrenkino @ Oct 13 2016, 22:57) *
Ohh I see, contacting my VPS person.
+Quote Post
vvikkass
post Oct 13 2016, 22:20
Post #6
Member
Group: Full Members
OK so I have finally worked with sfv, but now there seems another problem. I am using these placeholders in the file,
CODE
%_filename_ext% %_file_size% %_crc%
....and it outputs only a checksum data for single .m4b file. Can you help sir?
+Quote Post
vvikkass
post Oct 13 2016, 22:52
Post #7
Member
Group: Full Members
ok I did this and it worked.
CODE
$loop(%_filename_ext%)%_filename_ext% $loop(%_file_size%)%_file_size% $loop(%_crc%)%_crc%
$loopend()$loopend()$loopend()
Now can I add %_crc% value in the end of filename? for example like this:
CODE
001-chaosmage-7639b96d.m4b
This post has been edited by vvikkass: Oct 13 2016, 23:07
+Quote Post
ohrenkino
post Oct 14 2016, 10:14
Post #8
Member
Group: Full Members
QUELLTEXT
I get a little dizzy from all these loops.
IMHO the inner loops are not necessary as you get only one file size and only one crc value per file, there is nothing to loop.
So,
$loop(%_filename_ext%)%_filename_ext%,%_file_size%, %_crc%
$loopend()
should do just fine.
You could export the result to batch file instead of a simple text file and then execute the batch file.
The batch file would use command shell commands to rename.
$loop(%_filename_ext%)ren %_filename%.mp4 %_filename%-%_crc%.mp4
$loopend()
Or you import the data from the text file into the mp4 file again into a user-defined field and then rename the file with the convert function Tag-Filename or an action of the type Format value.
+Quote Post
vvikkass
post Oct 14 2016, 12:00
Post #9
Member
Group: Full Members
QUOTE (ohrenkino @ Oct 14 2016, 14:44) *
So,
$loopend()
$loopend()
One thing I want to ask, can MP3TAG run .bat file or will I have to run it manually? Also is their a way to save that batfile outside the audio folder. Enjoining it with %_foldername% is saving it inside the folder.
Thanks for all the help.
+Quote Post
ohrenkino
post Oct 14 2016, 12:09
Post #10
Member
Group: Full Members
If you save it somewhere else than the current folder, you have to add the path to the file. Otherwise it will not work.
If the file has always the same name, you can add it as a tool ...
So I would prefer the data re-import into the tags and then rename the file with the Convert function or an action.
+Quote Post
vvikkass
post Oct 14 2016, 12:37
Post #11
Member
Group: Full Members
QUOTE (ohrenkino @ Oct 14 2016, 16:39) *
Thanks a lot sir, I am having new issue while saving cover. Will open a new thread about it.
Thanks a lot again for your precious time. Most of the things got resolved.
+Quote Post
0 Members:
RSS Lo-Fi Version Time is now: 24th November 2017 - 12:13
