IPB
> Notice!
> Failed to authenticate using OAuth (1)
a23bed
post May 20 2016, 13:49
Post #1
Member
Group: Full Members
Mp3tag Version: 2.77
Today, turned on pc, tried to update some of my mp3s and this is what I got when trying to connect to discogs with pone and the default script.
See Attached picture.
Nothing has changed from yesterday! Nothing new installed/uninstalled.
I've tried the recommendations here;
http://forums.mp3tag.de/index.php?showtopic=19182
Changed
[WordSeperator]=+ (was %20 and back again)
[Encoding]=utf-8 (was url-utf-8 and back again)
Then I tried my own things;
Logged into my discogs acc and revoked the app authorisation.
Hoping mp3tag will ask for it again.
Deleted mp3tag.cfg (backed it up first, ofcourse)
Cleaned the Registry with CClean
Updated Windows
Update Windows Time Server (to europe.pool.ntp.org, time.windows.com was always iffy)
In between all these steps loads of coffee.
AND NOW I AM COMPLETELY OUT OF IDEAS.
Prior to this, I would occasionally get a "Discogs 401 error" if the tag contained stange charecters, especially on pone, but I would work around it.
But this one seems fatal.
It was a fun and productive couple of weeks with mp3tag.
Is this end for me with discogs and mp3tag?
Any help/ideas greatly appreciated.
mp3tag 2.77
Windows 7 Pro SP1 x64, totally up to date!
Go to the top of the page
+Quote Post
Fettler
post May 20 2016, 18:44
Post #2
Member
Group: Full Members
Mp3tag Version: v2.75
Exactly the same is happening with me today on Win 10.
EDIT:
Actually, I just found that I can get to Discogs when I use the general Discogs setting. I just can't get onto Discogs when I try to use any of the Pone settings. How odd.
This post has been edited by Fettler: May 20 2016, 18:50
+Quote Post
giraffelord
post May 20 2016, 20:16
Post #3
Member
Group: Full Members
Mp3tag Version: 2.75
Yep - same thing Error connecting to server: www.discogs.com 401: UNAUTHORIZED
And I've been on it pretty much constantly the last week. Presume it is a change at Discogs end
QUOTE (Fettler @ May 20 2016, 18:44) *
EDIT:
+Quote Post
GaryG45
post May 20 2016, 21:54
Post #4
Member
Group: Full Members
Mp3tag Version: v2.80
Everything was working fine a couple of hours ago. Now I'm getting:
Failed to authenticate using OAuth (1) >> 403: Forbidden
Using Win 10, Mp3Tag 2.77. Occurs with Mp3Tag Tag Source discogs>release Id extended and with Pone Updated 4.4 Direct by Discogs ID. Looks like Discogs made a change.
Gary
+Quote Post
a23bed
post May 21 2016, 05:59
Post #5
Member
Group: Full Members
Some good news.
Just tried to connect to discogs with the default script. Was asked to authorise the app, and every thing worked normally.
But pone will not connect with any combination of options, even pure ascii characters in the tags.
I get a 403: Forbidden error. Not the usual 401 error.
Maybe something on the dsicogs end?
+Quote Post
GaryG45
post May 21 2016, 14:17
Post #6
Member
Group: Full Members
I found a fix in the Pone mod Web Sources Scripts thread that works for me in both the Mp3tag Discogs script and the Pone Mod Direct by Discogs ID script. You have to edit the source for the script and after the line
[SearchBy]=$if2(%DISCOGS_RELEASE_ID%,$if2(%DISCOGS_RELEASE_ID%,$if2(%DISCOGSID%,%DISCOGS-ID%)))
Add the following line
[UserAgent]=1
Thanks to clouseau for the fix.
Gary
+Quote Post
Fettler
post May 21 2016, 19:03
Post #7
Member
Group: Full Members
QUOTE (GaryG45 @ May 21 2016, 14:17) *
[UserAgent]=1
Gary
Fantastic, Gary.
I also just tried opening the Pone scripts and placing your idea in the rest of them.
Basically, I added the line [UserAgent]=1 underneath ALL the other Pone script lines that start with [SearchBy=]
I can now get it to work with the Standard Search, Discogs ID and Discogs URL scripts.
It would seem that this method doesn't work with some of the other scripts though - the ones with 'album', 'artist', 'label' etc in the title.
Any updates gratefully received but for now, I'm very happy with the Standard Search, URL and Discogs ID.
Thanks again for that tip @ Gary.
This post has been edited by Fettler: May 21 2016, 19:03
+Quote Post
a23bed
post May 21 2016, 21:16
Post #8
Member
Group: Full Members
QUOTE (Fettler @ May 21 2016, 21:03) *
Same situation here.
Can't find most things as before.
My work around is to use the Advanced search in discogs and use the Discogs ID in the script;
https://www.discogs.com/search/advanced
Very long winded but at least we can connect.
Thanks guys for the heads up.
+Quote Post
Kaicho
post Mar 21 2017, 11:46
Post #9
Member
Group: Members
Mp3tag Version: 2.79
As per discussion:
https://www.discogs.com/forum/thread/5444a5...ba9e8171880b347
If you go in to your .src files and change 'http' to 'https' so, using the '&discogs#Search by Artist + Al&bum.src' as an example, the script reads:
CODE
[IndexUrl]=https://api.discogs.com/database/search?type=release&per_page=100&artist=%s
[AlbumUrl]=https://api.discogs.com/releases/
Pone successfully connects to Discogs.
Edit: Making sure [UserAgent]=1 is added below the [SearchBy] command.
This post has been edited by Kaicho: Mar 21 2017, 11:49
+Quote Post
0 Members:
RSS Lo-Fi Version Time is now: 24th September 2017 - 07:44
